Question about Compaq Computers & Internet
Everything has disappeared from the desktop. Even the taskbar isn't doing anything
    Guru:
  • 2,178 Answers
Restart the computer and before it boots to Windows, hit F8 several times until you get the emergency start-up screen - select "Last Known Good Configuration".
Posted on Dec 31, 2010
How to move icons from left side to bottom of screen
On all windows apart from Windows 8, you drag them from the desktop (left hand side) to the bottom (taskbar) with the mouse.
If the taskbar gets full up the icons might disappear.
The double bar at the end of the taskbar must be moved to the right for more of the taskbar to appear.
Mar 14, 2015 | Lenovo Computers & Internet
Windows 7 start bar disappearing
I see that you are having issues with your Taskbar/Startbar disappearing.
I believe that it is just a setting that we may need to change on your windows7.
click on the properties to see the next window settings
male sure that the auto hide is unchecked on this properties window, click on apply then OK this should set everything for your taskbar not to disappear anymore.
and one more thing right click on an open space on your taskbar this should give you other different options
then click on Lock taskbar to see below image
this should prevent changes to happen on your taskbar.
I hope this helps you, have a great day.
Mar 28, 2011 | Computers & Internet
I cannot locate my toolbar on my screen and also how do i recall items i minimized. they disappeared.
Press the windows key from the keyboard. It will help you to locate the task bar, then right click on the taskbar go to properties at the very top you will have three options uncheck the option that says auto hide the taskbar click on apply and ok.
That should do it, in case of any further help please reply back.
Mar 18, 2010 | Dell Vostro 220 Desktop Computer
Toshiba Tecra - model PTA40U-14001D Problem:
Right click on your desktop, and from the selections that pop up, select "view". That should bring up a secondary list. What you need to do is make sure that there is a checkmark next to "Show Desktop Icons". Also make sure your taskbar is not being "Auto-hid". Bring your cursor as far down as it will go toward the bottom of the screen and see if a "new" taskbar raises up-it means that "auto-hide the taskbar" has been selected. (These are signs that someone has pulled a prank on you and you are looking at a screenshot on your desktop.)
Hope this helps.
Jan 12, 2010 | Toshiba V000080510 - Tecra A4 Series...
The taskbar disppears. I have it locked so that it should always be on top of everything else but when it goes into hibernation and it restarted it disappears.
I'm had the same problem with my system. if the 'Start' button is still visible, so you can right-click that, select 'Properties' and change the TaskBar settings.select the 'Autohide the Taskbar' and applying that change will result in the Taskbar appearing again (at least when the mouse pointer is positioned by the Taskbar).
if the above one does not work a simple solution that will work:
1. Hit CTRL+ESC to show the Start menu.
2. Right click the menu at the bottom for Properties.
3. Select the Taskbar tab.
4. Check Autohide Taskbar and click the apply button.
5. Uncheck Autohide Taskbar and click the apply button once more.
Your taskbar should reappear when you've completed these 5 steps.
Please give this a try before messing with registry or recovering your machine!
If the taskbar does not show up when you press CTRL+ESC then explorer.exe may not be running. To correct this press CTRL+SHIFT+ESC which will bring up the task manager. Click File, New. Find explorer.exe and open it.
Go into Task Manager. Find explorer.exe and end the process. Restart explorer.exe. If your taskbar magically reappears, you've found the issue. Here are some other symptoms:
After a Windows Vista-based computer has been running for an extended period of time, the desktop screen may stop updating correctly. For example, you may experience any of the following symptoms: • Parts of the screen may go black. • Parts of the screen may become transparent. • The toolbar may disappear. • The toolbar may appear at the top of the screen instead of at the bottom of the screen.
If you add the GDI Objects column for the Explorer.exe process in the Task Manager console, you see that the GDI Objects column has reached the maximal number that is defined in the GDIProcessHandleQuota registry entry.
A hotfix is available from Microsoft: http://support.microsoft.com/kb/932406
Jan 07, 2010 | ASUS Eee Box EBXB202-WHT-E0002 Intel Atom...
The taskbar on my inspiron 1525 disappeared and i cannot get it back. I have no idea what happened. i can't access the start menu or anything. HELP
I may be able to help you but need some information from you first, can you access the control panel from you desktop or anywhere else?
Aug 01, 2009 | Dell Inspiron 1525 Notebook
DELL INSPIRON 1300 DESKTOP ICONS and Taskbar flashes on and off gone most of time
Try a system restore if it will allow you. If not you may need to run a system repair with your recovery or operating system disc.
Jul 18, 2008 | Dell Inspiron 1300 Notebook
After startup, all icons and taskbar disappear...
start your machine in safe mode and if you have any antivirus installed in it and is updated then scan it , your laptop is infected with virus . so scan it
Apr 25, 2008 | HP Pavilion dv6000z Notebook
Sounds like Spyware or Adware causing your issues. Try scanning it using http://superantispyware.com/ or AGV Free.
Joe
Dec 17, 2007 | Joy Satellite M55 S3314 Laptop PC
Loss of volume button
click on start then go to setting then control panel in control panel go to sound and audio devices i n that you will see volume tab in volume ther is option called place volume icon in the task bar just select taht and apply it it will show spk icon on your task bar but be sure that your sound card is properly installed. pls get me back if you need further assistence. bye
Sep 24, 2007 | HP Pavilion a815n (PS512AA) PC Desktop
Computers & Internet Logo
27 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
