Question about Sharp R-1874 Convection/Microwave Oven
Why does the microwave only run for 1 minute at a time on any setting?
  • Sharp Master
  • 9,047 Answers
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded them to our site here
and here
to help you.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Posted on Jan 02, 2011
2 Suggested Answers
WhIzAtIt
  • 136 Answers
SOURCE: Clock will run down to 1 second of the minute and microwave will stop
Yes the timer is prob the culprit. You probably had a brown out that caused the whole thing to go haywire.
Posted on Sep 21, 2007
Everythimg works but when I press start food still cold
LOL then every thing does not work . and unless it runs food will be cold . have to set in a time for it to cook , unless there are preset times as 1 would be 1 minute and so on
Sep 14, 2015 | Microwave Ovens
AFTER SETTING TIME COOK TO 1 MIN 60 SEC AND PUSHING START BUTTON 4O SECS MORE IS ADDED, I.E. TOTAL 2 MINS SHOW ON DISPLAY. CAN I RESET THE THE COMPUTER.
There are sixty seconds in a minute, so 1 min 60 sec is the same as 2 min. If you want 40 seconds less than 2 minutes then set it for 1 min 20 sec or for 80 sec.
Oct 03, 2013 | Danby DMW139 Microwave Oven
Need to st clock on panasonic nne281mm
follow the steps and fix it. God bless you
1) Press the "Stop" button on the microwaveicon1.png to reset the digital display to the clock setting.
2) Push the "Clock" button once. Locate the "Hour" button and press it once for each hour of time. For example, if the current time is 5:15 p.m., press the Hour button five times.
3 )Press the "Minute" button to set the second half of the time. For the example above, you would press the Minute button 15 times to set a time of 5:15 p.m.
4)Push the Clock button to saveicon1.png the time setting. Check the time on the microwave's digital display.
Feb 07, 2013 | Panasonic Microwave Ovens
What is the highest power setting? choices are low, defrost, medium, roast and reheat. no high???
Most microwaves run high at default, if roast and reheat are given that is your high setting, take one cup of water and run for 1 minute in each setting, the water that is the hottest is the high setting.
Mar 19, 2012 | Emerson MW8625W Microwave Oven
I have a GE sensor microwave oven. Tried to heat food and sensor eror came on. Everything is running even the timer but no sound but the timer is running. Cant this be reset pls help
HELLO.
This is the solution to reset your microwave.
1 Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
1. Set the clock by pressing the "Clock" button.
2. Turning the dial on the GE sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
3. Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the GE sensor microwave oven.
4. When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
5. Press the "Start" button to allow the clock to begin on the GE sensor microwave oven.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have never used the power feature and now I need to and cant find manual. How does the power feature work. I need to operate the microwave on medium power for one minute.
1 Use the number buttons to set a cooking
time. You can set a time from one second to
99 minutes, 99 seconds. To set a time over
one minute, enter the seconds too. For
example, to set 20 minutes, enter 2, 0, 0, 0 .
2 If you want to set the power level to
something other than High, press the Power
Level button, then use the number buttons
to enter a power level.
Power Levels:
Level Cooking PL
1Warm10
2Low20
3 Defrost 30
4Medium Low40
5Medium50
6 Simmer 60
7 Medium High 70
8 Reheat 80
9 Saute 90
10 High Hi
Hope that helps.
Mar 01, 2011 | Emerson MW8107WA Microwave Oven
Setting clock on EM-G2567S
1. If you press the 'Delay Start' button, the time display will go blank.
2. Now enter the correct time, using the 'Minutes' buttons to set the hour, and the 'Seconds' buttons to set the minute.
3. Now press 'Clock'
4. Sorted!
Nov 25, 2009 | Sanyo Microwave Ovens
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
Microwave clock and duration won't set
Good Morning,
Unplug the oven and wait 3 minutes then plugit back in and check to see that it operates normally. Do not run the oven empty - place a cup of water in it. Let me know if this helps and thank you for using FixYa!
Mar 30, 2009 | LG Microwave Ovens
Convection oven stops every 5 minutes and won't continue
to trouble shoot hold the door securely shut for longer than 5 min to see if it runs longer if it does the you should replace the interlock devise
Dec 25, 2008 | Sharp R-930AK Convection/Microwave Oven
Sharp R-1874 Convection/Microwave Oven Logo
311 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
