Question about Ariston Technologies AWD120 13 lb. Washer / Dryer Combo
Where is the lint filter on Ariston AWD 120?
My washer/dryer unit no longer dries my clothes. I wasn't sure if this might be related to the heating element or the fact that I have never cleaned out the lint filter. Nowhere in the instructions does it indicate there is even a filter.
4 Suggested Answers
  • 251 Answers
SOURCE: Ariston AWD 121 wont work
make sure the water supply is turned on , a small red and blue tap usually under the sink
Posted on Nov 11, 2009
SOURCE: Ariston AWD 120 Door Handle is Loose
unplug it.
open the top lid.
reach down inside and feel a plastic sensor/release behind where the latch is.
towards the left center of that sensor, feel for a metallic manual release (you'll just feel the nub of it).
Push this in and to the side to manually release the door lock.
Call Ariston and complain about this common problem.
Posted on Nov 09, 2007
barkencoa
  • 3463 Answers
SOURCE: Hi, Where can I find the repair manual for ARISTON
It is not normal practice for you to obtain a repair manual for these washers, as they are generally only available to the engineers working for the company.
Best thing to do is to try and obtain the information you require through sights such as this one, there are others on the net .
Posted on Nov 15, 2010
Dryer is taking a longer time than normal to dry unless we switch it to timer. Replace sensors?
  • Remove and clean the lint filter each time it is used. The filter can be washed with warm soapy water to remove fabric softener residue from the screen.
  • Check the household fuses and circuit breakers. Most household dryers use two fuses or circuit breakers. It is possible for only one of them to trip and the dryer still tumble, but not heat.
  • The washer controls may have been improperly set. If the clothes are wetter than normal, coming from the washer, this could be the difficulty. If the gentle speed is selected for a normal load the washer will not spin adequately. High speed or extended spin removes more water from clothing decreasing drying time
A lint filter that is full of lint will restrict airflow and lengthen dry times. To keep your dryer working correctly, clean out the lint folder after each and every use. Check the lint filter for any buildup of fabric softener that will restrict airflow and wash with soapy water to clean. If the filter is damaged then replace it.
Nov 09, 2017 | Dryers
Takes longer to dry clothes
Most of the time when your dryer is taking longer and longer to dry the clothes it is due to a clogged dryer vent. Just take the vent off and clean it. If the dryer cannot vent it cannot circulate the air inside the dryer
Jul 15, 2011 | Amana Maytag Dryer Lint Filter Screen...
My dryer is not drying clothes, if they are dry takes 3 hours. No lint in lint trap and the inside around the motor and elements is filling with the lint. I can see a broken seal but no sure what it is. I...
Sorry to read about your problem, I hope this helps you out.
you have defective high heat coils, or a clog in your vent from the wall to the outside of house
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Hotpoint Ariston A45V Electric Dryer
Our Kenmore HE2 dryer seems to be taking a very long time to dry clothes (120 minutes on Medium High to dry towels/jeans) . It is producing heat, but it also seems to be producing water/steam. The filter...
you need to clean out the vent line and the dryer.unplug the dryer,pull out the filter,remove the bottom panel and then remove the duct that the lint filter slides into and clean it out,vac out the inside of the dryer,if you have a shop vac you can blow all the lint from the back and then vac it up,make sure you blow off the motor,alot of lint gets built up around and inside it,pull out the dryer and pull off the vent line,if it's a long run i use a leaf blower to blow out the vent line,first go outside and make sure the vent is clear so when you blow out the vent line nothing is blocking the lint from coming out.this will take care of your problem,do this once a year and your dryer will last longer,you'll need less parts changed out over the years because the dryer won't over heat,you'll save on electricity,your clothes willl dry on time and most of all you won't have any fires
Sep 26, 2010 | Kenmore Dryers
Drying cycle working but not drying clothes
First clean filter for lint - next be sure the temp sensor at blower if free of lint - next, in the heater contrl unit, two solinods contrl the heating process - I hope it's the first two ideas - Try it - Good luck
Oct 15, 2009 | Bosch Exxcel WVT 2850 Front Load Washer /...
Lint problem
You must GRARANTEE full and free ari flow outside of the building. Typically this type of complaint is related to restricted air flow outside of the machine...normally there is lots of lint, and it exits through the filter, but when flow is restricted, lint remains inside.
Sep 14, 2009 | Kenmore 98702 Stacked Washer/Dryer
Maytag dryer not heating up thus not drying clothes
This is usually a simple heating coil malfunction. The coil may have breaks in it causing it not to work. It could also have something to do with 1 of several heating sensors that may be broken, telling the dryer's heating coil that the dryer is too hot, in effect turning off the heating coil. If your dryer has a round lint filter in the rear of the drum, it was 1 of 2 models of Dependable care dryers produced in the 1970's. If this is the case, i supose it would be up to you whether you want to try and get it repaired or not. If you have one of the more recent models,,, the lint filter is directly behind the door, at the front of the drum. and in this case it would probably be a good idea to get it looked at it as Maytag is a relatively dependable brand.
Mar 13, 2009 | Maytag Dependable Care LAT9706
Estate Dryer takes too long to dry load
Since you say the vent is clear, Make sure that the lint filter is cleared before each load. Make sure the door shuts close and is reasonably sealed. If the dryer draws air past the door, it is not fully drawing heat from the element or burner. Also make sure the washer is doing it's job in the spin cycle. It takes much longer to dry fabrics that are still soppy wet. You might try resetting the washer in the spin cycle to further evacuate the water from the clothes before placing in the dryer. See if that makes a difference. Maybe the washer spin is just being lazy. If it's a top loader it may have a loose belt causing the problem.
Dec 16, 2008 | Estate Dryers
Dryer is heating but not get clothes dry...
make sure you have a strong air flow from the dryer it self take hose off and run the unit it should force your hand away if not your dryer is stopped up you will have to take fan casing off and clean (the metal going to hole for vent hose) if you do go outside and make sure you vent outside is opening and free of lint also wash your lint filter with warm soapy water fabric sheets stop them up and cause longer drying time
Nov 12, 2007 | Roper REX4634KQ Electric Dryer
Ariston margherita 2000 advantage AWD10
Push the sun symbol button and set it on the time/or the function of the dryer. Thats it. I believe you were using the drying function without heating:)
Regards
Jan 24, 2007 | Ariston Technologies AWD120 13 lb. Washer...
Washing Machines Logo
543 people viewed this question
Top Ariston Technologies Washing Machines Experts
Darren Moxam
Darren Moxam
Gerry Harvey
Gerry Harvey
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
