Question about Toto Toilets ST784S 12 Sedona Beige Clayton Toilet with Traditional SoftClo
How to stop running water in tank - Toto Toilets ST784S 12 Sedona Beige Clayton Toilet with Traditional SoftClo
  • 7,482 Answers
Replace the "Ball ****" ...it is non-repairable...it is the part that regulates the water level in the toilet tank...also check the "Flapper Valve", if it is worn it will cause the toilet to leak.
Please rate me
Posted on Dec 31, 2010
How do I know the water is turned off? I flipped the small switch at the top of the tank but it doesn't say on or off. The water is running out the drain. How long will it take to drain?
THE small switch you are referring to is the overflow valve. It will drain the tank, depending on how big the tank is. this will not tell you the water is turned off. If you want to turn the water off, there should be a pipe running into the tank, which would be your supply line to provide water to be heated, There should be also a pipe for the cold water. Unsure of how your system is set up. but just draining the tank will only do just that, drain it. It will eventually stop when there is no more water, but you should not drain the whole tank.
Jan 26, 2018 | Water Water Heaters
Rowenta Pro Precision won't stop steaming until the tank runs dry.
Rowenta irons have a propensity for leaking. Most users do not add water to the tank but instead use a spritz bottle to dampen the fabric and then use the dry iron.
Jul 16, 2017 | Rowenta Irons
Kohler 4634aa is running and I've already changed the flapper, could it be the valve?
Yes it could be valve just cause you changed the flapper doesnt mean that you stop water from filling in tank the valve that shuts water of can still be running the water will go down the bowl fill tube that is were the black tube goes that connects to the top of white pipe the simple whey to find out is just push down on black float and water will stop add in tank let off black ball and water should stop or just lift up on float arm and water should stop bend float arm if necessary.
Jun 28, 2014 | Kohler Highline - Comfort Height Two-Piece...
Beko dryer
i have had this problem and its usually the pc board is faulty
Mar 28, 2014 | Dryers
Sounds like the water tank keeps filling
2 possibilities.1. The water level is set higher the the overflow tube. This will cause the water to run into the overflow continuously. You should be able to see this. 2. The large seal - bottom center of the tank - is leaking. This will cause the water level to slowly drop after a fill. The water tank will start to run again after flushing - BUT NOT CONTINUOUSLY. You should see if there is a small amount of water flowing from the rim to the bowl 15 seconds after the water has stopped running after a flush.
Aug 09, 2012 | TOTO ST743S#01 Drake Toilet Tank, Cotton
How to stop it from spluttering
The sputtering may be caused by a calcium build up the water system. To solve the problem do the following.
Turn the unit OFF and unplug it.
Empty any remaining water from the tank.
Mix a 50/50 solution of Distilled White Vinegar and Bottled Distilled Water (enough to fill the tank).
Pour solution into the tank and allow it to sit for 1 - 2 hours.
Plug the humidifier in and turn it ON. Allow it to run until the tank is only half full. If the sputtering has not stopped, turn the unit OFF and allow the unit to soak over night.
The next morning, turn the unit On and run for 20 minutes. Turn the unit OFF & unplug it. Pour out the remaining solution and refill with Bottled Distilled Water. Run the unit for an hour. This will flush out the lines. After that, it should run normally.
I would highly recommend using Bottled Distilled Water in the future, rather than Tap Water.
Hope this helped you to solve the problem.
Jul 11, 2011 | Vicks V150SG 1 Gallon Humidifier
Saeco Exprilia showing error E05 wont start. tries to prime water circut but then stops....help
Put vinegar in the water tank about 1/4 of a tank and 1/4 of tank water then turn the machine on with the water tank out ( so you don't get the priming message ) then it should tell you fill water tank put the tank in for 5 second and pull it out do it 3 - 5 times ones the vinegar gets in the system let in stay for a wile and then run the rest thrue the hot water and stem works for me I have real hard water at home
Apr 15, 2011 | Saeco Coffee Makers & Espresso Machines
On my eljer toilet, I get continuous running of the water. If I shut valve off and pump the tank, the running stops (but only for a week or so). Suggestions? model 150-403 power flush pf/2
I don't know what you mean by "pumping" the tank. If the toilet runs, then either the fill valve is defective or the seal on the flush valve is defective. First, check to see that when you move the float, the toilet stops running. If it does not, then replace the fill valve. If it does, then inspect/replace the seal on the flush mechanism at the bottom of the tank. If this seal is bad, you can usually see water continuously flowing (slowly) into the bowl. You will see ripples on the surface of the water in the bowl.
Jun 01, 2010 | Eljer Home
I have a saeco incanto classic I have tried to descale 2 times and the red light will not go off, is there a reset buttton?
Hi
In order for the light to go off, the machine has to stop pumping on its own, both in the descale and the rinse mode. If you stop it before its done it will still be in the descale mode.
Once it stops on its own, the lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle (putting water in the tank and closing and then reopening the steam knob)until all the red lights go away and you only have a green blinking light. Now your finished descaling a compact without a digital display.
May 04, 2010 | Saeco Incanto Classic Espresso Machine
Solis Palazzo - dreaded ventilate problem
Hi
Your machine is still in the descale mode. You haven't finished. If you have run the descaler through, the water is ermpty the pump will still keep going until it stop on its own. If it doesn't stop on its own, the computer thinks its still in the descale mode. remove the water tank and turn the machine back on. The pump will run and then make a lot of noise, then stop. This can take up to 5 minutes. Let it run until it stops. You will get blinking lights on the panel. Put the water tank back on and close the steam knob then open it again. The pump will start the rinse mode. Let it stop on its own. Computer can't see that you ran a whole tank of water, but it can see when the flow meter stops that there is no water left. If you have already rinsed the machine start the pump flowing and just lift the tank off. When the pumps stops the rinse cycle the descale light will be gone but you will have the heater light blinking and the water light steady. Put the tank back on and close the steam valve then open it again. This will clear the water light and the machine will start to heat again.
Apr 15, 2009 | Saeco Incanto Classic Espresso Machine
Toto Toilets ST784S 12 Sedona Beige Clayton Toilet with Traditional SoftClo Logo
423 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
