Question about InFocus Play Big IN76 Multimedia Projector
When I turn the projector on, it goes about 2 minutes, the picture (lamp) flickers and then it shuts down. I can pull the power cord and when I plug it back in, it will start up again but repeates the shutdown. The lamp has just under 400 hours on it. When it was new, the power supply failed and was replaced under warranty. Any ideas? Glenn Nellist gnellist@fmtcswb.com
  • 3 Answers
This is a little late but these models had an issue where they would over heat and even catch fire. Infocus ignored the problem. I need a new power/ballast board for mine. Look at the videos on YouTube to see what happens to these boards. Search for IN74 fire.
Posted on Oct 08, 2013
I also had the same problem and finally we heard some glass shattering sound. I opened the projector cover and found signs of burning and one part separated ?diode or what I do not know. I can see a small hole on the board possibly where the wire got broke and the piece became separated and resulted in a shattered noise, I suppose.
Posted on Jan 14, 2011
  • afourtrack Sep 20, 2011
    It sounds like the power supply board is faulty. I think they may be out of production now which is a pain. The component that fires is a capacitor, C512, if I recall correctly. Replacing the capacitor may resolve your issue. I think its a .47uf 450 volt metallized polyester if I can recall correctly.
    I've just found an old supply and the value written on that cap is:
    474k450
    NIS V02
    This may work, I don't know, good luck!
Benq MX761 stays on for only 2 minutes and then shuts down after genuine Benq lamp replacement. Picture flickers colour just before shutdown. Lamp timer has been reset to zero.
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If you see any, replace them all in the power board section. Check to see if your TV is still under warranty first though.
Nov 29, 2014 | BenQ Projector Lamp for MX760 MX761...
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
How do you install new light bulb
The Projector will detect the lamp life itself. It will show you a warning message renstrike_1.jpg
When you see this message, change the lamp as soon as possible. Make sure the projector has been cooled down for at least 30 minutes before changing the lamp
  1. Switch off the power to the projector by pressing the Power/Standby button.
  2. Allow the projector to cool down at least 30 minutes.
  3. Disconnect the power cord.
  4. Use the screwdriver to remove the screw from the cover. (1)
  5. Push up and remove the cover. (2)
  6. Remove the 2 screws from the lamp module. (3)
  7. Pull out the lamp module. (4)
To Replace the lamp module, reverse the previous steps,
Feb 28, 2011 | Optoma EP716 Multimedia Projector
Projector powers up, after 2 minutes image goes away, projector goes into cool down, then shuts off. why?
FAULT: lamp of your projector is faulty.
Experience: when lamp life is near to end and environment temperature is too low you are facing the same problem and if you are facing this problem in normal temperature then also lamp is faulty.
Sulotion: Just replace the projector lamp
Jan 07, 2011 | Panasonic PT-AX100U-EC DLP Projector
Dell 1800mp projectors turns on for a few seconds then turns off and lamp light stays solid orange...what's the problem. New bulb?
Hello
If the Lamp light and power lights are blinking orange, the lamp driver has failed, and the projector will automatically shut down. Unplug the power cord from AC mains wall socket, wait for three minutes and replug and see whether it helos you. If not, contact Dell service center.
OK.
Nov 19, 2010 | Dell 1800MP Projector
I press the power on and the lamp led not the
Hello :
Try to change the bulb .
Here is how :
1:Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, replug the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp.
please rate !
Apr 12, 2010 | ViewSonic PJ458D Multimedia Projector
Projector screen displaying "Searching" message. Does not recognize computer. Worked with one of your associates (Guru?) and we tried a number of solutions but none worked. She asked that I come back to...
If you are connecting to a laptop then you may need to hold the function button down and press F1, F2, F3 etc. there should be a sign with the latop on there and a sign with an external device (monitor,PROJECOR)
hope this information was useful to you.
Jan 21, 2010 | InFocus Office Equipment & Supplies
How do I remove the lamp on a optoma ep716?
Lamp Replacing Procedure:
  1. Switch off the power to the projector by pressing the Power/ Standby button.
  4. Use a screwdriver to remove the screw from the cover.
  8. Replace the lamp module in reverse the previous steps.
Nov 11, 2009 | Optoma EP716 Multimedia Projector
Replace bulb in housing for Infocus IN24.. i want instructions how to remove old bulb from housing.
1 Turn off the projector and unplug the power cord. 2 Wait 60 minutes to allow the projector to cool thoroughly. 3 Turn the projector upside down on a soft cloth so that the lamp door is facing you. 4 Slide the lamp door off. WARNING: Be extremely careful when removing the lamp housing. In the unlikely event that the bulb ruptures, small glass fragments may be generated. The lamp housing is designed to contain these fragments, but use caution when removing the lamp housing. Before replacing the lamp, clean the lamp compartment and dispose of cleaning materials. Wash hands after lamp replacement. Hg ? Lamp contains mercury. Manage in accordance with local disposal laws. 5 Detach the lamp connector from the projector by depressing the locking tab on the connector and lightly pulling it free. 6 Loosen the captive screw that attaches the lamp housing to the projector.Carefully remove the lamp housing. Dispose of the lamp in an environmentally proper manner. 7 Install the new lamp housing and tighten the screw. 8 Re-attach the lamp connector to the projector. The locking tab should engage when the connector is fully plugged in. 9 Replace the lamp door by sliding it into place. Be sure the lamp connector wires are not in the way. 10 Plug in the power cord and press the Power button to turn the projector back on. 11To reset the lamp hour timer, navigate to the Settings>Service menu and select Reset Lamp Hours.
Nov 09, 2009 | InFocus Office Equipment & Supplies
Hp projector
This is caused by the color wheel sensor failure. The sensor is mounted very near the lamp and suffered extreme temperature. This problem can be corrected by installing the redesigned color wheel sensor. You also need to refocus the sensor due to different focal length. HP also recommended to replace the temp sensor cable. If you still have the projector, I can fix the problem for you.
Jan 08, 2008 | HP vp6320 Multimedia Projector
InFocus Play Big IN76 Multimedia Projector Logo
244 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
