Question about Akai LCT2701TD Television
Akai LCT 2701 TD - Red Blinking lIngt
L have an Akai LCT 2701 TD purchased at Costco +- 2 years ago. Red light on bottom just flashes can not get anything to work
  • 1 more comment
  • moineau Aug 04, 2008
    I have the same problem
    I change caps and zener diode but no effect..
    I am also interesting by the solution.
    thanks
  • Anonymous Nov 19, 2008
    Mine has not worked for a year, possibly two; think it may need system reset, and can not find reset for system listed on outside of case; think I have to pull back to get to system reset button, or need to know how to reset system from outside without killing power
  • SBTesq Nov 23, 2008
    I have the same exact problem and am mad as hell. This TV is less than 2 yrs old. Have you gotten any response from the manufacturer? What does Costco say? I am very frustrated with the lack of response.'\
  • 2,326 Answers
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Posted on Nov 26, 2008
Akai lct 2070 tv switch does not turn on tv-no sound-no tv
Most failures on this TV are due to defective power supplies. If the TV does not turn ON, you should replace the power supply.
Check this website to buy the power supply adapter and hopefully that should fix the TV.
Jan 21, 2009 | Akai LCT2070 20 in. EDTV-Ready LCD...
Lcd akai 2715 blinking red light
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
Nov 19, 2008 | Akai LCT2715 27 in. LCD Television
Blinking red lights
The failure of a blinking light is from a defective power supply. It could be a zener diode that is faulty, rectifier and a few capacitors as well.
I repair these power supplies. If you need more info send me an email to jah2mil@hotmail.com
May 29, 2008 | Akai LCT2701TD Television
AKAI LCT2701TD SMPS Failure: Red flashing light
I do not think there aren't any new power supplies available to fix these LCDs. The only way to make the LCD work again is to have someone to repair the power supply.
You could send me an email to jah2mil@hotmail.com for more info.
May 16, 2008 | Televison & Video
Flashing RED Light
Our AKAI also shut off & the red light started to blink...got no help from AKAI, but did from COSTCO. We bought the set before the 90 day warranty they have in place now, so they referred us to COSTCO Concierge Services: 1-866-861-0450. We were referred to a repair service & after discovering what the problem was found out that AKAI not longer has parts for this model. COSTCO replaced our TV---talk about satisfaction guaranteed.
May 14, 2008 | Akai LCT2701TD Television
No picture ; no sound
the red blinking light usually has a pattern that gives you a code to the possible problem.
Maybe you have a bad power supply board. You have to open the panel and do a few tests on the power supply's outputs to be sure.
It produces a variety of voltages for different parts of the tv ie. the plasma display panel and the audio system. The components supplying power to the audio system may have failed a year ago and recently the pdp.
plasma tv's are expensive to repair, most of the time you can get a better tv for the same price. You can reduce that cost by learning and troubleshooting it yourself.
Feb 23, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
No picture
I bought my Tv at Costco and all I did was take it back! without a box and a receipt, but they did check my Costco member card after all was done they gave me store credit. Then I bought a better brand and I really hope it will last me more then TWO YEARS!!!! Good Luck...
Dec 27, 2007 | Akai LCT2701TD Television
AKAI LCT2701td TV No Picture
I had the same problem; the blinking light problem is caused by a bad power supply. It try’s to power up but senses a failure so it shuts down and just keeps repeating this process. I troubleshot the problem and found that zener diode Z3 (27volt 1 watt) was shorted and zener resistor forgot designation (2 surface mount 10 ohm resistors in parallel) were open. The zener is under a heat sink so it is hard to see. Also there were 4 1000uf capacitors that were bulging so I changed them as well. I got the parts from digikey for 20 bucks and its now working fine. This was a lower cost TV at the time of purchase so it seem the manufacture used low quality parts and I would suggest trying to return the TV to Costco before fixing it. Good luck.
Dec 24, 2007 | Akai LCT2701TD Television
WOn't turn On
I talked to an Akai certified tech who told me the problem is a bad convergence module. The part alone is $400. Fortunately, I purchased mine from Costco 3 years ago. Costco has a 100% guarantee policy that I was not aware of. I called them asking if I had an extended warrenty and they gave me the full purchase price as a refund ! If any Costco purchasers are experiencing this problem and you purchased the TV prior to March 2007 (when Costco changed their policy), you may be able to take it back and get the full amount you paid for it. I turned around and purchased a new, larger Panasonic for under $150 more. It has a 5 year warrenty.
The Akai service number (to reach a certified repair place) is 1-800-726-4405. The Akai people are very good and can direct you to options. For those near Pittsburgh PA, Contact Rosewood Audio in New Castle 724 654-3023.
KW Pittsburgh
Dec 24, 2007 | Akai PT5598HD 55" Rear Projection...
Authorized Repair Centers for Akai Flat Panel TV
My 42 inch Akai is about 6 months old,, and is showing green where black should be..
BUt there is help for you all.. Call Verizon, sign up for their "Expert Care" program. it's $10.00 a month, and active after the third month.
with a $75.00 deductable. THey will fix or Replace (give you choice of three alternate models/brands).
Free services under this plan are adjustments, and One FREE remote per year!.
i recomend you sign up for this program, and after 90 days. call for service. They more than likely will replace your TV's.
This is what they did with mine..
ALSO.
it doesn't matter how old your TV is, the plan is applicable to all TV's in your household. So one plan, one monthly payment of $10.00, covers all the TV's you own!!
Dec 09, 2007 | Televison & Video
Televison & Video Logo
567 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
