Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
Factory Reset doesn't reset anything
I have attempted to reset my SBG900 multiple times now, because I need to reset all of the security things. However, every time I press a toothpick or pushpin into the reset button hole, the modem doesn't reset.
I was reading another solution on here about the SBG900 (http://www.fixya.com/support/t346868-wep_key), in which the person who answered describes what would happen to the lights when the modem is resetting. What happens when I attempt to reset mine, however, is that none of the lights go out. I hold the button for thirty seconds, and about three seconds after letting go, the lights finally start going off. The middle three stay lit for a few seconds, and then all of the lights go off. Then everything starts coming back on.
But even once this has all happened, the settings for my network have not changed. It still has the custom name I gave it and it still has the security settings that I am attempting to reset.
Does anyone have any idea how to get my modem to reset? Thanks for any help you can provide!!
  • 1 more comment
  • Anonymous Jul 22, 2008
    Yep, I'm having the exact same problem, this f#%$$#%ng thing doesn't work!!
  • Anonymous Nov 29, 2008
    Same here
  • Anonymous Feb 17, 2009
    Same ha`ppens to me!!!!
Did you try the reset with the cable and ethernet cables disconnected?
Posted on Aug 10, 2008
Trying to secure my wep, tried the loggin admin, motorola but will not log me in.
Couple of things you can do....
In the User ID field, type admin (case sensitive) and press TAB. In the Password field, type motorola (case sensitive) and click Log In to display the SBG900 Setup Program main window
If you are still having problems, try the following:
  1. Press the reset button on the rear panel. Resetting may take 5 to 30 minutes
  2. Try the login again, if that fail try from a different browser.
Mar 06, 2011 | Arris SURFboard SBG900 Wireless Router...
My SBG900 router's NAT type is set to moderate when checked on xbox live connection, I tried typing the IP adress into a web browser and can only get to the log-in page, I read that the log-in is naturally...
Try user as "admin" and passwords as "admin" or blank or "password" or "1234" then check. If still not able to access then you need to RESET it. For that press RESET button for 10 seconds reset button is in the back side of router. Then check. Let me know if you need further assistance. Thanks for using FixYa.
Aug 03, 2010 | Arris SURFboard SBG900 Wireless Router...
How do I reset the sbg900 to factory user name and password
This pdf is the manual for your modem:
http://broadband.motorola.com/consumers/products/SBG900/downloads/SBG900_User_Guide.pdf
Page 7 on the document contains a picture of your modem's back side. You'll notice a recessed button that will RESET the modem back to the default values, which include username and password. Press this for at least 5 seconds.
Jul 28, 2010 | Arris SURFboard SBG900 Wireless Router...
How do you reset lost password?
Straighten one end of a Norwegian paper-clip, and insert it into the small "reset" hole in the back of the modem.
This will reset the modem to the "factory" settings.
Then, reconfigure your modem, as if it were "day one" that you got the modem.
May 29, 2010 | Arris SURFboard SBG900 (49402201900) Modem
How do I reset the password on the motorola sbg900
You acn hard reset the device. there will be little pin hole. insert any pen or pin for 20 seconds. lights will flash and the device will be reset to the factory settings
May 02, 2010 | Arris SURFboard SBG900 Wireless Router...
I dont know the key
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Dec 26, 2009 | Arris SURFboard SBG900 Wireless Router...
What do i do if i forget my router security
Do a factory reset. This will clear the password.
Oct 12, 2009 | Arris SURFboard SBG900 Wireless Router...
Can't connect to the internet wirelessly
Well, to avoid confusion, I'd start by doing a factory reset. Insert the straightened end of a paperclip into the reset hole and power up the device to do this. From there, the device should begin broadcasting the default wireless network with the name (SSID) of "Motorola." The DHCP server should also be enabled and if your computer is configured to receive an automatically assigned IP address your wireless network interface should pick up an IP. The security for the "Motorola" network is disabled by default.
Basic troubleshooting from there would be to try to see if you can connect your wireless computer to another wireless network that is know to be working well. Either buy and return another wireless access point or router from a retailer or head to a Starbucks or other establishment that offers free wireless. If the wireless computer is hooking up nicely with the secondary wireless network, you can refocus on the SBG900 as the likely source of the problem.
If after attempting the aforementioned procedures you find that the wireless computer continues to fail to connect to the SBG900 you might have to consider that you have a faulty device. At that point I would consider consulting the manufacturer's documentation.
Apr 05, 2008 | Arris SURFboard SBG900 802.11g/b...
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
675 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
bobkoure
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
