Question about Syntax Olevia 537H Television
537H-B11 For the first 20-30 seconds no response to remote. Using tuner input only analog channels work. Trying any digital channel input yields a blue screen (no signal). Using channel up/down mutes the sound. All other inputs Composite, Component, S-video, HDMI etc work fine.
  • tewks52527 May 12, 2011
    I've discovered if I use one of the other inputs for a couple of days, like a component or HDMI input from another source and then randomly go back to the tuner as the source it mysteriously begins to work again and may work for a few hours to a few weeks. I believe it is a solder joint on the main tuner board possibly around one of the 3 terminal regulators in the tuner area of the board. Mine has been working for about 3 weeks now since the last time it acted up. Al
  • tewks52527 Aug 10, 2011
    Finally got tired of it randomly not working so I ordered a replacement Main board and swapped it out so hopefully it is fixed. I has been working for 3 days so far. I still believe it to be a cold solder joint on the main board but I haven't located the area on the board to resolder. Not that it is working I'm less motivated to try and fix it.
I have the same exact problem, it's so damn frustrating.
Posted on May 12, 2011
No TV broadcast picture. Is this a tuner problem?
yes it does seem to be a tuner problem , I also wonder what happens when you use the auto channel finder and tuner usually found in the set up section of the menu ? As well as was your TV working before and receiving input via the antennae but has now stopped working in this regard ? I also noted that attaching an analog to digital converter box worked fine , so your TV is capable of receiving a signal via that method , dose the converter box use your antennae input jack or a video jack to send the converted signal into your TV ? if it is using your antennae jack then it may not be a tuner problem .
Jul 19, 2014 | Sony Grand Wega Kdf-50we655 50-inch Lcd...
How do we scan/program in local tv channels. We bought an external antenna, but get no picture. Typically, there is a protocol for scanning channels into the set. Model is Sansui TVS2746B, and the set was...
Okay, does this tv have a built in DIGITAL tuner? Most tv's only have an analog tuner. You can tell the difference while you are changing the channels. If the channel indicates 2.1 or 2.2 and so forth, it is on a digital channel mode. If you change the channel and it indicated 2, 3, 4, etc. it is analog. If it has digital capability change the input until you see 2.1, 3.4 etc. If you cycle through all the inputs on the tv like, input 1 (TV) input 2(DVD) input 3(HDMI) and so forth and you never see the digital channel you most likely do not have a digital tuner. You will need to purchase a digital converter which will convert it to analog and you can watch it by placing you tv on analog channel 3 just like the old vcr's. Hope this helps and please don't forget to rate this solution.
Jan 22, 2011 | Samsung TSL2793HF 27" TV
Trying to set up Digital Labs 19''LCD TV/DVD combo and only gets limited cable channels (old tv on same cable gets lot more). Have completed auto scan and pick cable as reciever however only gets limited...
The remote control that came with my Digital Labs tv/dvd combo worked for about 2 seconds and never really worked correctly. Now, I'm trying to find a universal remote that will be compatible. Please help.
Dec 26, 2009 | Televison & Video
Locked out of digital antenna in setup. I had it
1. ensure that you are on the TV tuner when you are trying to scan channels
2. if analog tuner works, but you cannot access digital tuner....the digital tuner is broken
When you turned channels before, did it switch between analog and digital channels seamlessly or did you need to press a button to acces digital channels seperately?
If you accesed digital channels seamlessly, #2 is not likely
If seperately, #2 is very likely.
Jul 10, 2009 | Sharp Televison & Video
I am trying to set up the "favorite channels" function on my harmony 880 remote and I keep getting an error message that the channel numbers are not valid. On my TV, for example, NBC is 05-1 (that's what I...
I have seen channel designations like this when using a satellite TV provider. From what I know (which is not a lot, I'm afraid) is that some affiliates offer analog and digital and digital sub channels so an example would be:
05 (main analog channel)
05-1 'digital' (depending on the receiver)
05-2 'digital sub channel'
05-3 'digital sub channel'
etc
So, you may want to try just putting in the main channel '05' when using the Logitech software to program your favorites. Below is a link to a good post on the Logitech forum that tells how to program your favorites. Hope this helps!
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9691
Mar 24, 2009 | Logitech Harmony 880 Universal Remote...
Hitatchi 42HDF52 only receives channel 5 and 6 on analog RF input
If you have tried autoprogramming and have found nothing it may be a bad tuner. Is your VCR is hooked up via coax or into a video input? If it is hooked up via video and is working but the coax connection direct isnt it will be a bad TV tuner. Easiest cheapest fix is to use you VCR to change channels or get a Digital Cable Terminal from you cable provider and hook it into video or compnent.
Jan 29, 2009 | Hitachi 42HDF52 Television
Determining if TV has a digital tuner
No! this TV will need a converter box!
Please rate my quick response!
thank you!
Jan 13, 2009 | Televison & Video
Marantz SR-5200 - Analog inputs only play the right channel
please invert your cable and watch if the problem moved the problem in your cable change it with new one.from any radio shack near you or any electronic store.
Jul 05, 2008 | Marantz SR-5200 Receiver
Pic n pic
can get my pc n pic to work. it says can not view same channel please clarify problem in more detail thanks
Sep 09, 2007 | Mitsubishi WS-65615 65" TV
Delay in built in tuner is unacceptable
Because it has a built in tuner there will be a delay since the tuner has to process all bands for each channel for analog and digital signal.
Dec 20, 2006 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Syntax Olevia 537H Television Logo
143 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
