Question about Amana Dryers
Pulley off where does it go? - Amana Dryers
  • Amana Master
  • 7,482 Answers
The pulley with the arm will attach to the base of the dryer...look for a worn spot on the base to mount the pulley arm.
I will also include a belt hook up diagram.
Please rate me
http://www.applianceaid.com/images/belt-config.JPG
Posted on Dec 31, 2010
Knocking noise when printing
Check the following:
1. DC motor assembly.
Make sure all the motor plate mounting screws are tight.
2. Idler pulley - DC motor assembly.
Make sure the idler pulley is not binding on the pulley shaft. Check the pulley for wear. Check the idler pulley shaft on the motor mounting plate for damage or contamination.
3. Drive pulley.
Check the drive pulley for wear, binds or damage to the pulley or pulley shaft. Make sure the pulley turns freely on the pulley shaft.
4. Motor drive belt - tray drive belt.
Check the DC motor drive belt for damage. Make sure the belt is tracking correctly on the drive pulley, idler pulley, and motor pulley. Check the tray drive belt for damage. Make sure the belt is tracking correctly on
Dec 11, 2012 | Lexmark X646e Laser Printer
Serpentine belt routing for 2001 ford taurus
what engine? Please rate if this helps. Took a lot of time to dig out.
here's 2002 3.0L 2 valve
Item Part Number Description 1 10346 Generator pulley 2 8678 Belt idler pulley 3 3A733 Power steering pump pulley 4 8620 Drive belt 5 2E884 A/C clutch pulley 6 6B209 Drive belt tensioner pulley 7 6312 Crankshaft pulley 8 8509 Water pump pulley
4 valve
Item Part Number Description 1 3A733 Power steering pump pulley 2 8620 Drive belt 3 2E884 A/C clutch pulley 4 6316 Crankshaft pulley 5 6B209 Drive belt tensioner pulley 6 10344 Generator pulley
water pump 4 valve
Item Part Number Description 1 6A359 Camshaft drive pulley 2 8K543 Drive belt 3 8509 Water pump pulley 4 8W508 Drive belt tensioner pulley
Dec 20, 2010 | Ford Taurus Cars & Trucks
Belt diagram
Accessory Drive adobe.gif Printable View (62 KB) Component Locations 3.0L (2V)a0007698.gif
Item Part Number Description 1 10346 Generator pulley 2 8678 Belt idler pulley 3 3A733 Power steering pump pulley 4 8620 Drive belt 5 19D784 A/C clutch pulley 6 6B209 Drive belt tensioner pulley 7 6A312 Crankshaft pulley 8 8A528 Coolant pump pulley
Item Part Number Description 1 3A733 Power steering pump pulley 2 8620 Drive belt 3 19D784 A/C clutch pulley 4 6A312 Crankshaft pulley 5 6B209 Drive belt tensioner pulley 6 10344 Generator pulley
Item Part Number Description 1 6A359 Camshaft drive pulley 2 8K543 Drive belt 3 8A528 Coolant pump pulley 4 8W508 Drive belt tensioner pulley
Nov 28, 2010 | 2004 Ford Taurus
Serpentine belt configuration
Accessory Drive
3dde941.jpg Item Part Number Description 1 10346 Generator pulley 2 8678 Belt idler pulley 3 3A733 Power steering pump pulley 4 8620 Drive belt 5 19D784 A/C clutch pulley 6 6B209 Drive belt tensioner pulley 7 6A312 Crankshaft pulley 8 8A528 Water pump pulley
Component Locations 3.0L (4V)
I posted the serp belt configuration for both engines. thanks
Sep 24, 2010 | 2003 Ford Taurus
2001 ford tarus belt diagram picture
Please rate highly if this helps. Good luck.
3,0L 2 Valve
3.0L 4 valve
Sep 09, 2010 | Ford Taurus Cars & Trucks
Serpentine belt diagrm
Not sure if you have the 3.0L 2V or the 3L 4V so heres both. Hope it helps.. Cobra,, :-)
Item Part Number Description 1 3A733 Power steering pump pulley 2 8509 Water pump pulley 3 2E884 A/C clutch pulley 4 8620 Drive belt 5 6312 Crankshaft pulley 6 6B209 Drive belt tensioner pulley 7 10346 Generator pulley
Jun 05, 2010 | 2000 Ford Taurus
Serpentine belt diagram 2002 ford escape picture of serpentine belt pattern
CLICK on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/2002/make/ford/model/escape/2002_ford_escape_drive_belt_routing_diagram.htm
Feb 27, 2010 | 2002 Ford Escape
Belt diagram
2 valve
Item Part Number Description 1 8679 Belt idler pulley 2 10344 Generator pulley 3 8620 Drive belt 4 3A733 Power steering pump pulley 5 6312 Crankshaft pulley 6 8509 Water pump pulley 7 2E884 A/C clutch pulley 8 6B209 Drive belt tensioner pulley
4 valve
Item Part Number Description 1 19A216 Belt idler pulley 2 10300 Generator clutch pulley 3 8620 Drive belt 4 3A733 Power steering pump pulley 5 6316 Crankshaft pulley 6 8A528 Water pump pulley 7 19D692 A/C clutch pulley 8 6B209 Drive belt tensioner pulley 9 19A216 Belt idler pulley
Oct 26, 2009 | 2003 Mercury Grand Marquis
Surpentin belt
if you have a car quest their they can show you or print a belt routing pic
Oct 12, 2008 | 2000 Oldsmobile Intrigue
Serpentine belt diagram for a 5.9 diesel with air and 9 pulleys
5.9L DIESEL
196759.jpg The 5.9L diesel engine accessory drive system (with a/c) consists of :
  1. Generator Pulley (1)
  2. Water Pump Pulley (2)
  3. Idler Pulley (3)
  4. Power Steering Pump Pulley (4)
  5. Radiator Fan Pulley (5)
  6. Crankshaft Pulley (6)
  7. Automatic Tensioner (7)
  8. A/C Compressor Pump Pulley (8)
CAUTION: When installing the accessory drive belt, the belt must be routed correctly. If not, engine may overheat due to water pump rotating in wrong direction. Refer to or for correct engine belt routing. The correct belt with correct length must be used.
1. Position drive belt over all pulleys except water pump pulley. 2. Attach a 1/2 inch ratchet to tensioner.
196757.jpg The 5.9L diesel engine accessory drive system (without a/c) consists of :
  3. Idler Pulley (3)
3. Rotate ratchet and belt tensioner clockwise. Place belt over water pump pulley. Let tensioner rotate back into place. Remove ratchet. Be sure belt is properly seated on all pulleys.
Sep 13, 2008 | 2008 Dodge Ram 3500
Dryers Logo
44 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
