Question about Ridgid 10"Wet Tile Saw with Laser and Stand
Cannot keep water on the blade of my 10" Rigid wet
  • 29 Answers
If waters not getting to the blade you will see the powder of what ever your cutting coming off the back of machine,i like to put my pump in a bucket of water under the drain plug instead of puting the pump in the water tray,you can run bigger tubing up to the blade and reduce it down and it will give you better presure,good luck
Posted on Mar 01, 2011
Looking for the blade guard arm.
Search Results
    7" Job Site Tile Saw with Laser - RIDGID Professional Tools
    https://www.ridgid.com/us/en/7-inch-wet-tile-saw-with-laser
    Ridgid7" Job Site Tile Saw with Laser. ... Heavy Duty Arm - prevents flexing while keeping the blade aligned; Guard Baffle - reduces air turbulence to help keep water ...
    [PDF]7" BRIDGE TILE SAW
    manuals.harborfreight.com/manuals/97000-97999/97360.pdf
    7" BRIDGE. TILE SAW. WITH STAND. Owner's Manual & Safety Instructions. Save This Manual .... that has an outlet that looks like the one illustrated above ... Use saw-blade guard and spreader for every .... arms and shoulders. To reduce the.
    [PDF]10" INDUSTRIAL TILE/BRICK SAW Owner's Manual ...
    manuals.harborfreight.com/manuals/69000-69999/69275.pdf
    parts. Nonslip footwear is recommended. Wear protective hair covering to contain long hair. 11. ALWAYS USE ... an outlet that looks like the one illustrated above in Figure A:... For Your Own Safety Read Instruction Manual Before Operating Saw. 1. Wear eye ..... Connect the clear water Hose from under the arm of the Motor ...
    SKIL 7" Wet Tile Saw 3540
Dec 16, 2015 | Blade Saws
Rigid tile saw. Can I use a wood blade?
Tile saws are designed to use a diamond blade, and to keep it wet. That's not something you want with a wood blade, nor with wood. The speed of a tile saw is much slower than a good wood saw. I wouldn't try it.
May 27, 2015 | Blade Saws
Where is the blade brake on the miter saw
The brake on electric motor driven tools is the field & armature. When running the switch provides power to both sides/poles of the field through the brushes and armature. When you release the switch half of the field is powered pulling the armature to a stop. If your bladed continues to spin when the switch is released, you need to replace the switch. The Ridgid part number for the proper switch is 503317000.
Mar 06, 2012 | Ridgid Reconditioned 12 In. Compound Miter...
I have a wts2000l and i have noticed that it is burning through blades. The water is pumping through but isn't hitting the blade at all. The water is spraying in opposite directions, I can't seem...
you just have to lift the blade guard and tweek the direction of the outlet, point them so they're spraying towards the blade. Not right at the blade but just so they're getting plenty of water spraying onto the tile. Don't put a bucket and catch the water "over flowing" from the tray, just drain the pan and put the bucket under the drain hole to catch the water. A lot less messier that way.
Aug 05, 2011 | Ridgid Wts2000l 10" Wet Tile/stone Saw...
How much water do I put in the reservoir?
The rule of thumb here is to have enough water so that the blade picks it up, cooling the blade, but not so much that it floods the machine. If you lift up the grate, you may see an overflow tube that keeps you from having too much water in the sump. If you don't have an overflow tube, then turn on the saw and add water until the blade picks it up, plus a little more. When you notice that the spray of water is diminished, add more water.
--W/D--
Jan 20, 2011 | Qep 60084A 4Inch Portable Wet Saw
Rigid wts2000l WEt saw is not sending water to blade even though it is in on position
look for weak pump, or blocked pump pick up.
I have a similar saw, and the pickup at the pump gets pretty grimey, and ned to blow it out once in a while to keep it clean and of cake like tile paste. also check the hoses for splits and/or cloggs.
Jan 07, 2011 | Ridgid Wts2000l 10" Wet Tile/stone Saw...
Crooked cuts
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
Jan 04, 2009 | Dewalt Heavy - Duty 10" Wet Tile Saw -...
Ridgid 10"Wet Tile Saw with Laser and Stand Logo
431 people viewed this question
Top Ridgid Saws Experts
ken skalski
John Trevino
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
