Question about LG WM-2277HW Front Load Washer
My whaser is getting error code 0E. What can I do to fix it?
    Top Expert:
  • LG Master
  • 9,472 Answers
Here is a link to the information on your OE error.
Posted on Dec 31, 2010
Have a samsung washer model WA17XAR showing OE code and makes grinding sound and does not start
Hi this is a link to a short youtube video showing error code 0E, This washing starts and stops as well and the guy fixes it.....CHEERS..
https://www.youtube.com/watch?v=YOvFYcaLp8w
Mar 18, 2016 | Samsung Washing Machines
Error code 0E on LG WM1290 FHB ?
The error code 0E stands for obstruction error, meaning that the drain line is obstructed. This is why the spin fails as all the water is not being drained. Check the drain hose for kinks and clean the drain filter. If they are not the problem, there could still be an obstruction in the drain hose in or about the drain pump.
Dec 28, 2014 | LG Washing Machines
LG washing machine error code 0e....filter clean and machine level but still have error code
The drain pump on the machine could be faulty. This pump cannot be repaired it will have to be replaced if found to be faulty.
Sep 08, 2014 | LG Washing Machines
BIOS FLASH
This is quite a common problem. HP made malicious BIOS: http://h30499.www3.hp.com/t5/Notebook-HP-ProBook-Compaq-Slate/6735s-BIOS-Errors-After-Update/td-p/5587995
Jul 11, 2012 | HP Compaq 6735s Notebook
Docuprint C3290FS error code 0e
At this point I haven't had a chance to remove the lament flooring. I'm planning on removing it this morning so I can pull the dishwasher out and take a better look at the drain line. I didn't think it made any sense that it would drain well is the line was low but wouldn't if I raised the line. I was thinking the pump might be putting out low pressure but I wasn't sure how to determine if that was the case.
for more help visit CBR Tech Solutions
Jan 30, 2012 | Xerox DocuPrint C3290 Printer
I have an lg wd12650tp and it has stopped full of water with the code OE showing. I've tried emptying the filter at the front but it still wont drain? Any suggestions? btw apparently the code means...
Hi.
Error 0E is drain error.
Access the drain pump, located behind the service door at the base of the machine, in the front side, right below the washer door.
Disconnect power before starting the procedure.
Open the door and undo the pump attachment. Have a container ready to collect a good amount of water.
If that does not fix the problem, then there may be a fault. Further blockage, faulty pressure switch and faulty drain pump are the faults that can trigger error code 0E.
You can find parts and diagrams for most models using the link below:
Where do I find parts and diagrams?
Please click here to read an article showing how to fix common drain problems.
Regards.
Oct 21, 2011 | Washing Machines
Error code 0E
OE is OUTLET ERROR.
More often than not, a blockage is in the pump(not that easy to get to and quite a long step by step process)
You might also find the blockage at the end of the drain hose, where it connects to the drain pipe- remove the hose clamp and inspect hose and spigot.
May 04, 2010 | LG 24 in. LD-12BW5 Free-standing...
Maytag-Neptune stopped part way though cycle. Error code 0E shows on LCD panel. Powering down does not reset. I can't enter service mode as described in the washer manual the 0E code remains.
In general this error code is the main control.
Resetting by pulling out the plug may help, but I wouldn't count on it.
This would require a new main control board.
May 14, 2009 | Washing Machines
Starview codes 30 nov please telepest
codes for 30th nov 2008
00= B7 19 92 E2 9B 15 AF 06
01= C6 64 1D EF 47 5A 0E EF
Nov 30, 2008 | StarTech.com StarView SV211K 2-port KVM...
I need codes for telewest 5a 01,27 th nov 10:30 am
e8/25/93/b2/6a/90/0e/a2
16/cf/0c/a7/a7/14/d2/22
27/11/08/t/w/v/m/s/v
Nov 27, 2008 | StarTech.com StarView SV211K 2-port KVM...
LG WM-2277HW Front Load Washer Logo
112 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
