Question about Technics SL-1200MK2 Turntable
Theres no power in my turntable. upon opening it, the fuse looks good, and everything seems at first glace to be connected. but it does not turn on when plugged in.
  • Technics Master
  • 6,694 Answers
check the power cable first . then check the on off switch. also check the transformer. do one more thing remove the fuse from the holder and then refix it. may be chance for contact problem.
ok
Posted on Dec 31, 2010
No Light and the turntable is not working
Open your microwave completely unscrewed but make sure it is disconnected from the power; check all the other fuses inside, if it doesn't fix the issue then take it to a pro to get this fix.
Jan 03, 2014 | Emerson MW8102SS 1100 Watts Microwave Oven
Dishwasher doesn't seem to be getting power. Breaker looks good
first check the power connection behind the toe-kick pane,then theres a fuse in the control panel to protect the electronics which can open and kill power to the unit
Aug 02, 2011 | Viking DFUD042P Built-in Dishwasher
Won't turn on, plug fuse changed but no power on. is there a fuse inside? many thanks chris
The most obvious cause is the power switch might have broken. Most turntables open from the bottom, so just go in and look!
Jan 27, 2010 | Technics SL-1210MK3 Turntable
No lights or responce (power issue)
If you do not see fuses on the smaller pc board, next to the main PC board, underneath the turntable platter, then you don't have any. Not all 1200s series turntables have these fuses. So, that means you more than likely blew the Technics power supply / transformer.
Not an easy fix, and I don't recommend you do this, as seeing how you did not replace the pop-up light correctly, it seems you lack the experience. When you saw that spark, that means that you did not shield the pop-up light wires properly, a big mistake. It more than likely touched the cabinet, and created a short - very common. This short is enough to take out he power supply.
You will have to take your unit to an authorized repair center for repair.
Good Luck!
- OPTiC
Master Tech, 1200s.com
Technics Parts : DJ Gear Repairs
May 29, 2009 | Technics SL-1200MK2 Turntable
Turntable wont spin
If everything seems ok with the power , there is usally a small microswitch that sends power to the motor when the tone arm is moved to the start of the record.
The switch might be bad or the lever that actuates it (connected to the tone arm) might be sticking. You may have to take the bottom cover off or remove the platter to see it.
Also make sure the belt is looped over the motor shaft. If the motor runs but the belt still doesnt turn, belt might be bad.
Mar 10, 2009 | Technics SL-BD22 Turntable
JVC L-A10 Turntable won't turn on
there should be a fuse on the circuit board close to where the power cord connects, check to see if its good
Feb 03, 2009 | Audio Players & Recorders
My game boy color doesn't turn on
theres a broken connection somewhere if even the LED doesn't even come on. I doubt theres even an internal fuse on the gameboy.
The only thing you might be able to fix was a faulty on/off switch - have you tried shorting the switch contacts with something metal?
Dec 01, 2008 | Nintendo Game Boy Color Console
No power
no power, 1st you need a tester tester (range 1000vac) first the convinience outlet if there a voltage 2nd test the power cord if there a continuity(range your tester into resistance x10) put it in to the tip to tip of the C.O power cord of your turntable(the reading will have contunuity) if still no power check the fuse inside the turntable" remove the platter and the plastic be carefull trace where the power cord connect inside the circuit(maybe the fuse blown) if the fuse is still ok 4th check the contunuity of the transformer the input and output line(in tester there will have a reading supposed to be) after all if theres still aproblem just email me..hope i can help that way..
Aug 10, 2008 | Technics SL-1200MK2 Turntable
Turntable Issues
Check to make sure that your voltage setting is set correctly. Look under the turntable platter. You'll see a voltage selector. Make sure it's properly set for your area (115V or 220V).
If this does not solve the problem, or you have a turntable that does not have the voltage setting feature, then you might have a faulty turntable drive issue or an issue with the power, which means something is wrong on the main board (located underneath the turntable platter).
- DJ PRO AUDIO
www.DJPROLAB.com
Mar 17, 2008 | Technics SL-1200MK2 Turntable
Will not turn on (no rotation of turntable)
theres not much to a turntable if belt is on and you can turn the table freely then i would guess there be a blown fuse inside
Dec 31, 2007 | Denon DP-29F Turntable
Technics SL-1200MK2 Turntable Logo
96 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
