Question about Bosch 24 in. SHX57C05UC Stainless Steel Built-in Dishwasher
PUMP WILL NOT TURN OFF - Bosch 24 in. SHX57C05UC Stainless Steel Built-in Dishwasher
    President:
  • 1,140 Answers
It's highly likely that the flood-protection (Aqua-Stop) system on your dishwasher has been activated. This is usually due to water having leaked under the washing compartment or a faulty sensor / float switch. It could also be caused by a faulty control module.
The first thing you should do is to check for water under the washer. Turn the power off at the breaker first, then remove the kick-plate from beneath the door (remove two screws) and have a look inside the base of the washer (use a torch if necessary). If you can see water in the bottom, then you have a leak which requires further investigation.
You can also check for water by removing the dishwasher from under the counter and tilting it forwards or backwards slowly by about 15-20 degrees. If there is water in the bottom, it will run out on to the floor so it is also advisable to put some old towels down on the floor before doing this.
Please note: The washer is heavy and the bottom can slide out if you tilt it too far. For this reason, it is safer if there are two people doing this.
Please check for water under the washer first and then post back for further assistance.
Regards,
BElectric
Posted on Dec 31, 2010
Why does the fuel pump relay don't click when i turn the key to run? and why there is no power at the fuel pump relay?
the operation of most fuel pumps is controlled by the fuel pressure regulator
when the fuel pump gets to set pressure , the pump is switched of by the ECM at the relay level
maybe nothing wrong with your system just the system working as designed
if you have pressure in the fuel manifold when you turn the ignition on then the pump will not run but will if there is a fuel leak somewhere and the pressure drops off
Oct 25, 2016 | Cars & Trucks
How do you backflow a pool pump?
I assume you mean backwash the filter. The pump will always pump in one direction.
I am also assuming that you have a sand filter with a filter control valve.
If your filter's waste discharge needs a hose attached to route the discharge to a ditch or other suitable location, be sure to attach the hose before beginning this process.
Turn the pump off. Set the filter control valve to the backwash position. Turn the pump on and run for 30 sec to 1 minute until the water being discharged looks clear. If your filter control valve has a Rinse setting, turn the pump off, set it to Rinse and run the pump for about 30 sec. Turn the pump off. Set the Set the filter control valve back to Filter and turn the pump back on.
Jul 23, 2014 | Pool & Spa
How to use back wash
backwash is easy. dont let it scare you.
here are the steps:
-turn off pump
-roll out backwash hose
-push down on handle and rotate to backwash
-turn pump back on
-depending on type of filter, run for minimum 2 minutes (watch discharge water. run until it is clear) if there is a glass vial, you can watch that until water is clear.
-turn off pump
-push down on handle and rotate to rinse
-turn on pump and run for 30 seconds (water will leave discharge hose)
-turn off pump
-push down handle and rotate to filter
-you can run pump immediately
May 20, 2014 | Hayward SAND FILTER, PRO SERIES
How do you backwash your pool
if you have a sand filter or de filter turn system off then turn multiport to back wash turn back on let run until the backwash glass is clear turn off then turn to rinse turn back on for about 20 sec then turn off then turn multiport back to filter then turn back on
Oct 20, 2013 | Pentair 1.0 Hp Whisperflo Pump
When my fuel pump didn't turn on, my truck wouldn't start, if it did turn on it started right up. I replaced the fuel pump and it starts every time, but the fuel pump doesn't turn on every time. Is...
the fuel pump don't turn on every time . first when the pump as prime or if system is prime the pump will not turn on
the PCM give a ground to fuel pump relay for 2 sec and while the engine is cranking the pump is running all the time.
but pcm don't prime each time
Oct 10, 2013 | 1998 Chevrolet K1500
Not sure how to backwash
if its a pool,the filter shud have a rotary selector.turn pumpOFF rotate selector to backwash.turn pump on and run for 2 mins or till water runs clear.turn pump OFF and selest rinse.turn pump on for 30-45 seconds and turn pump off.with pump OFF select filter and turn pump on.take note of water pressure before n after backwash
Jul 30, 2012 | Pool & Spa
Why will my car turn over but won't start
COULD BE FUEL PUMP,CHECK FUEL PUMP FUSE AND RELAY. LISTEN FOR FUEL PUMP OPERATION IN FUEL TANK WHEN YOU TURN IGNITION ON POSITION YOU SHOULD HEAR FUEL PUMP RUN FOR 3 SECONDS AND TURN OFF.
Jul 05, 2011 | 2001 Chevrolet Malibu
My polaris PB4-60 booster pump does not turn over.
I was able to save a service call by doing the following in under 8 minutes:
1.Switch off electric to pump.
2. Turn off valve on supply side of pump so water does not flow during this procedure.
3. Turn offf filter.
4. Unbolt the six bolts (1/2" socket) on the front side of the pump.
5. Carefully separate the pump from the front panel which contained the six bolts.
6. Grasp with both hands the black round thin disk (impeller) which is part of the pump and turn it either clockwise or counter clockwise. It may be slightly difficult initially but once it it freed it will move easily.
7. Reassemble.
8. Open valve and turn on filter and the power to booster pump.
Any questions e-mail me at bbgreg@optonline.net good luck
May 16, 2009 | Polaris Pb4 - 60 Booster Pump
Bosch 24 in. SHX57C05UC Stainless Steel Built-in Dishwasher Logo
203 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
