Question about Whynter FX-6SB Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D
Sunbeam water dispenser Model YLR2-5-90HZ3 Ser# 2003 0406928 cold and hot settings on 4 After 24 hours with a 5 gal water bottle placed on this hot/cold dispenser, I woke up to find water all over the garage floor. Apparently the water boiled over (perhaps bad thermostat?) and came out of the top of the unit from around the bottle. Anyone experience this problem?
  • 1 more comment
  • bobbysbus801 Jan 17, 2009
    I have the same problem. leaks on the right side. I also would like to buy a part for my cooler
  • staffing Jan 26, 2009
    I have the Sunbeam cooler hot and cold. Can you shut off the hot water side so you just have the cold.
  • PaulEWu Apr 27, 2009
    Same problem. Sprung a leak. Called Sumbeam and they dont make make or sell the dispenser anymore. Called a couple repair shops they sa throw it out its a piece of poo and not worth fixing. warantee is over by six months so cant get my money back. You can guess where im going with this. Sunbeam is zero in my books.
LEAKS
Posted on Sep 02, 2010
Water leak from inside the refrigerator
Posted on Jul 16, 2008
We had the same problem...If the water bottle has a hole in it the water will leak out of the unit.Check the bottle
Posted on Jul 14, 2008
The small pan under the spouts are missing. we would like to order
Posted on Dec 18, 2010
Same problem which melted the seal plate causing the leak. Thought it was the thermostats not shutting off the heat, but the heat was coming up through the overflow pipe and into the bowl. Talked with Elite Group in Montreal and they suggest draining out the system with the drain plug in the back of the unit, then try again. They say the steam has no where to go if the overflow pipe is full.
Posted on Feb 16, 2010
I took the thing apart to wash the bowl and forgot which way the thing goes back together
Posted on Jul 05, 2009
Sunbeam hot/cold water dispenser is leaking from looks like copper tubing that goes to tank. Model # ylr-5-87h3 what could my problem be
Broken solder connection.
Continual expansion and contraction of metal due to hot and cold extremes will cause metal fatigue. The most vulnerable place is at the join. Other places can fail, but usually the solder join will fail first.
Buy another one and support economy.
Make sure next unit is connected to cold water line, and not hot water line. If hot water dispenser is connected to Hot line, then it will cause water heater to run each time water is drawn through dispenser because cold water immediately enters tank.
http://waterheatertimer.org/Water-heater-dip-tube.html
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html#h-c
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#pot
You might also consider installing small tank under counter. Tanks are less glamorous than hot water dispensers but tanks are more reliable long term than instantaneous water heaters.
May 28, 2013 | Water Heaters
Hot/cold water dispenser. Why is cold indicator blinking and no cold water dispensed?
We typically service Hoshizaki, but you may not be getting water into the resivior. Depending on model, you may need to remove bottle and probe and check the silicone seal, reseal and re attach. Also be sure that hoses are connected and fully pushed into the connectors. And of course make sure you have a water supply. Could take up to an hour for water to re chill again. Hope this helps. Check out our site for other product and tips! Thanks! www.whiteswarehouse.net
Jan 18, 2011 | Whirlpool GI15NDXTSS
The plastic liner that holds the gasket in the water tank area where you place the 5 gal bottle over the spigot and spigot screw down to hold this plastic lid onto plastic gasket is warped and lets water...
you will have to get the parts to be replaxced if the gasket is cracket or the inner plastic is cracked you will have to first check out and order that particular part as this parts are not very costly but its not repairable.many users face the same problem of leak when the gasket gets pushed in the plastic and cracks .this creates leak when water passes through that area. -------------- you can get the required parts from -- http://www.repairclinic.com/SSPartDetail.aspx?s=a12i868872&PartID=868872 ------ just click the link directly. ---------- you can also click this link directly and contact sunbeam service center to replace the parts http://www.householdappliance.com/hot_shot.html ---------------- this will help.thanks.please do rate the solution.thank you for using fixya.keep updated.
Oct 13, 2009 | Sunbeam Hot Shot Hot Water Dispenser...
The plastic handles that dispense the water are broken
Where can I buy the spigets for a Sunbeam water cooler. I need one for hot and one for cold water. These handles are not strong enough plastic to last the lifetime of the unit. They should be made from metal. If the taps on our kitchen sink was made from plastic you can imagine how long they would last.
May 27, 2009 | Sunbeam Refrigerators
SUNBEAM WATER HEATER/COOLER WITH WATER FILTRATION BOOTLE
i am having the same problem and i lost the model number for it but can you please share the modle number if you have it because i call sunbeam and they need it so they can find it for me! thaky e mail @ hateandlove_1988@yahoo.com
May 23, 2009 | Whynter FX-6SB Free Standing Hot & Cold...
Sunbeam Model YLR2-5-90HZ3 hot/cold water dispenser w fridge
HOW CAN I REPLACE THE PART MINE IS DRIPPING WATER CONSTANTLY.
Oct 05, 2008 | Whynter FX-6SB Free Standing Hot & Cold...
Whynter FX-6SB Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D Logo
7,943 people viewed this question
Top Whynter Water Filters & Coolers Experts
Tom Chichester
Are you a Whynter Water Filter and Cooler Expert? Answer questions, earn points and help others
