Question about Samsung Washing Machines
Hi I have a samsung SW52ASP washing machine and it leaking near the filter cap what could be the problem and how to fix it
  • 1294 Answers
SOURCE: whirlpool awm049 washing machine
Would help if you were more specific.....
Posted on Apr 12, 2007
  • 619 Answers
SOURCE: Bosch Maxx WFL2860 filter leaking
unplug the power before you do something leak first check and then clean filter, replace some hose available in appliance center.
Posted on Jan 07, 2008
  • 3 Answers
SOURCE: if filter cap is broken how do i open it on my bosch washing mach
I had the same problem. If it's stuck you may want a tool. I ended up using a pair of pliers on this plug. You may want to use a pair of vice-grip locking pliers and put a piece of thick metal on each side so you don't break the plug any worse (about 1/2" X 2" plate). MAKE SURE YOU TURN COUNTER CLOCKWISE! Wiggle it back and forth as you may have a wire or hairpin half in and half out of the pump filter area. It takes 2 full turns to get past the threads in order for the plug to come out. I had an underwire from a bra that gave me the worst problem. I worked on it for almost an hour. I have found change, jewelry, hairpins, BBs, small rocks, and a 4" long underwire from a bra. Please rate my solution if this gives you enough details to complete your task. THANKS!!
Posted on Apr 16, 2009
barkencoa
  • 3463 Answers
SOURCE: unable to unscrew cap on filter on washing machine
You should be unscrewing anti-clockwise to remove it, if it will not come out, then there is probably somethiung stuck in the filter preventing it from pulling out.
Try moving it from side to side as you are unscrewing and pulling.
Posted on Mar 17, 2010
  • 17 Answers
SOURCE: Hi my washing machine samsung
because the function of filter is to block the small particles or dirty things including grease or oil etc., before disposing the water, and to avoid the clogging of floor drain and even sewage line. And after you used it you should check the filter if theres a some dirt, and grease or oil to clean up to avoid clogging and unclean water from your washing machine
Posted on Feb 06, 2011
After removing debris filter for cleaning, its leaking. even when i try to remove the filter it was making 'kurk' noice and have use plyer to pull it and after fixing it water is leaking....
There maybe or was an oring on the drain cap. Make sure it is in place and use a light vegetable oil on it when you put it back in to make sure it is not binding
Dec 20, 2017 | Samsung Washing Machines
Wat area is the pump filter on my Samsung washer and dryer combo
How do I clean the debris filter in my front loading Samsung washing machine?. Open the filter cover(A) by using a coin or key.Take one end of the emergency draining tube (B) out.Open the emergency drain cap (C) by pulling it. Allow all the water to flow into a bowl. Note: hold the cap at the end of the emergency draining tube (B) and slowly pull it out. Note: you may need to drain several bowlfuls of water. . Prepare a dry cloth. Wash any dirt or other material from the debris filter. Make sure the drain pump propeller behind the debris filter is not blocked.Replace the debris filter cap tightly.Reinsert the emergency drain cap and the drain tube.ake sure to replace the debris filter and emergency drain cap after cleaning it. If they are not reinserted properly your washing machine may leak or otherwise malfunction.Close the filter cove
Sep 30, 2016 | Samsung Washing Machines
Error code 5E keeps coming up on my Samsung SW52ASP washing machine.
You need to really check the noise from where the correct inference could be made. Seems that the drum or the moving system is under friction and needs a reset.
Nov 20, 2013 | Washing Machines
Iasked hpw to fix my Samsung SW52ASP washer with error code dE and was supplied this link to the fix. The link doesn't work and I cannot find a place to contact anyone. Can you assist please? This is...
Here is the solution direct ;-0)
'dE' stands for 'door Error' indicating that there is a problem either with the lid lock or the lid locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 15, 2011 | Samsung SW62ASP Top Load Washer
My machine is not spinning dry It is an SW52ASP I lookied in the back but couldnt see any problen. I wonder if a nylon sock has got somewher in the guts.
If the socks has caught into the system then the SPINNING SPEED would have dropped.
So please check if the motor/ motor drive is free if not the assembly can be taken out and checked.
Please find tips to remove the drum and assembly:
http://www.espares.co.uk/advice/washing-machines/a/7
Jul 19, 2011 | Samsung Washing Machines
Samsung frontload washer fashing nd code
The ND code means not draining
The older versions of this machine did not have a debre filter, but in later versions a drebe filter was added . It is on the bottom right of the front panel. Open the door. Pull the cap off the drain hose and drain water into pan. Remove filter cap. Wash filter off and don't block propeller when replacing filter cap. Insert cap back in drain tube.
Jun 04, 2011 | Samsung WF328AAW Front Load Washer
Washing machine Airturbo stops at 17 minutes and 7 minutes and error code SE appears. what is to be done washing nachine is one year old only
  1. Open the filter-cover near the bottom of the machine. Unscrew emergency drain cap by turning it to the left and drain off all the water. Unscrew the filter cap and take it out. Wash any dirt or other material from the filter. Make sure the drain pump propeller behind the filter is not blocked. Replace the filter cap. Replace the filter-cover.
  2. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
  3. If the water only trickles out of the draining hose, pause the washer and blow air down the hose, you should hear the water inside the unit bubble a few times. If you don't hear bubbles, the hose is still blocked.
  4. Drain the load, empty the washer of clothes and try running a rinse & spin cycle. You should repeat this until the water runs clear from the drain hose.
  5. If the machine still fails to drain, you may need to replace your Drain pump.
Feb 26, 2011 | Samsung Washing Machines
DRAIN IS BLOQUED I NEED FIX
Hi not sure about your particular model but it has been the same on all washing machines i have owned and judging by the photograph it looks like it, so to clean your filter for your drain pipe is very easy on the front near the bottom right hand side there is a cover or flap,remove this it should come away easy then you should see the filter and a screw cap ,make sure that before you open the screw cap that you place something underneath to catch a fair amount of water as the drain pipe may well still have some water in it,then proceed to undo the screw cap when the water has drained into the tray you have placed underneath you will see the filter which should just pull ou,clean ,replace all parts ,your done,hope this helps
Dec 05, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Jan 03, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Zanussi FX 1265 W washing machine
You can seal the cap by some tape, but it is better to get a good replacement, for the filter needs periodic maintenance. Your machine will not drain well if the filter is clogged.
Nov 09, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Washing Machines Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
