When I plug the photo key chain into my USB port nothing happens
  • 11,800 Answers
In that case the memory chip inside your key chain has failed because it has been used too many times. Nothing you can do, it's dead so replace it.
Posted on Dec 31, 2010
My computer no longer recognizes my nikon coolpix L5.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Aug 19, 2012 | Nikon COOLPIX L5 Digital Camera
Digital photo album - keychain
The message "No Photo Viewer Found, program termined" will happen unless you have the keychain plugged into the USB port in syncronization mode not charging mode. It's just saying it can't find a Photo Viewer plugged in to sync with. That should solve your problems. You can't update you image library unless it is plugged in
Regards
Balisonu79
Feb 16, 2008 | Digital Products Monaco Ezcolor Photo...
When I try to install the coby dp 151 it says: cant find photoviewer or program that owns it. the program will exit. ?? confused
The error you describe, is also mentioned in the Setup Guide for the DP151.
When you connect the Key Chain to the USB port of your computer, on the Key Chain will prompt the message to select: USB charge or USB update.
For proper function of the Chain Key:
0) Before connecting the Chain Key, have the Photo Viewer software installed:
You need adminstrator rights to perform installation of programs.
Install the photo viewer from the CD or download this program
from the Coby support site:
> enter cobyusa.com in the address bar of internet explorer
> enter DP151 in the Product Search bar
now all support for the Chain Key will show
> run the DP151_PhotoViewer zip file directly or save the zip file onto your computer, unzip and run the setup.exe file later
1) Connect the Chain Key and Select USB update on the Chain Key.
Again, to be able to update, you need adminstrator rights.
2) Run the Photo Viewer on the computer.
Aug 15, 2010 | Computers & Internet
Photo viewer device not found
I got a key ring for Christmas too ...when the keyring is on 'charge' mode it doesnt show on computer ...you have to remove the lead from key ring, switch off key ring then replace lead and switch to 'update' mode. Now if you double click on icon it should work!!!
Nov 22, 2009 | Fuji Electronics - Others
Microsoft wireless mouse 3000; put in new battery, still nothing
nikcorra2488,
try this: plug in the USB key & check for the green light. Then go to start, control panel, & double click mouse (with whatever mouse works). Check the hardware tab and see it the computer is recognizing that the mouse is there. If it is there, it should be working fine. If not, then perhaps you need to reinstall the USB port drivers. Sometimes this will happen when you've upgraded from 1.0 to 2.0 USB ports.
Hope this helps.
-samson39
Jul 26, 2009 | Microsoft Wireless Notebook Optical Mouse...
Digital Royal Key Chain - How do I download pictures?
Hi, the Digital Royal Key Chain has a mini USB port located somewhere, this should also be the port for the adapter to the built in lithium battery inside. There after, just plug in your computer and Plug and Play software should detect it. Then you can move your picture files, (.jpg, .mpeg, .gif, etc) and drag them in the drives folder. They should display then.
Mar 15, 2009 | Coby DP-768 7-Inch Widescreen Digital...
When I plug in the M407 camera nothing happens
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Mar 15, 2009 | HP Photosmart M407 Digital Camera
Installing coby digital keychain software
Start from scratch, uninstall everything and pretend your installing for first time:
1. have keychian unconnected from usb
2. install software
3. DONT RUN SOFTWARE YET
4. connect keychain to usb
5. on keychain select: USB update
6. Run software
7. well-ah, intelligence > poorly organized device - enjoy everyone
Dec 14, 2008 | Coby DP-5588 5.6-Inch (4:3) Clock &...
Coby Digital Photo Keychain DPKEY
Getting Started- VERSION DPKEY and 151SX
STEP-1
-INSTALL The Photo Viewer Software
Download & Install The Photo Viewer Software From Our Web Site:
The Driver CD files (Setup Guide, Manual and Photo Viewer Software) can be downloaded from
our web site. Click on the link below
http://www.cobyusa.com/?p=prod&prod_num_id=80&pcat_id=3001
NOTE:
Find your Photo Key Chain version and Download the Driver CD files along with all the latest
updates.
The version is listed on the back of the Photo Key Chain as 151SX, DPKEY or 151MP.
To Download & Install The Photo Viewer Software From Our
Web Site:
a) Create a folder
on your desktop before downloading the file from our website. To create
a folder on your desktop, go to your desktop and RIGHT click on your mouse. A set of
menus will appear. Select “New” and then “Folder” (you will notice a new folder will
appear on your desktop), give it a name, example DP151.
b) Click on the below link and select “Download”.
c) Click on your Photo Key Chain Version to start the Download. The version is listed on the
back of the Photo Key Chain (151SX, DPKEY or 151MP.
d)
After clicking on your version, you will prompt with a pop-up screen “Do you want to save
or open the file”. Select Save.
e) Another screen will prompt you to save the file on your computer. Save the file on your
“Desktop”, in the “DP151” folder and select “Save”.
f)
Once the download is completed, go to your desktop. Double-click on the DP151 folder.
g) To install the Photo Viewer software, Double-click on the Setup.exe file. Click NEXT on
all prompts.
h) After the installation. The Photo Viewer Software icon will appear on your desktop.
i) Done! ……Continue with “STEP- 2
STEP-2 CONNECT the Key Chain to your computer using the supplied USB cable. Upon
connecting the Key Chain to your computer, the Key Chain will prompt you to set the
device to “USB Charge or USB Update”. Select USB Update by pressing the Right
button and then the Middle button.
STEP-3 RUN the Photo Viewer Software to transfer photos to the Key Chain. Double-click on
the Photo Viewer icon located on your desktop. Once the Photo Viewer opens, it will
give you a message indicating “Upload Completed”. Click OK. (This message
indicated that the Photo Viewer Software has made connection with the Key Chain). If
you have received the “Upload Completed” Message, Skip STEP-4 and continue with
STEP-5
STEP-4 If you have NOT received the “Upload Completed” message, then you are
encountering the below error message:
Can’t Find any Photo Viewer, or
another program owns it. The
program will exit!
*Set the Photo Key Chain to USB update. SEE “STEP- 2”.
*Make sure the USB Cable is connected properly, you should hear a “clicking”
sound when the USB Cable is connected properly in the USB Port.
*The Key Chain should also appear under “MY COMPUTER” as a removable
disk. If not, switch the USB Port or replace the USB Cable.
STEP-5 LOCATE the images on your computer (See Diagram)
STEP-6 HIGHLIGHT the images files that will be transferred to the Key Chain (See
Diagram)
STEP-7 SEND the highlighted images to the Device Panel (See Diagram)
STEP-8 TRANSFER the images from the Collection panel to the Key Chain (See Diagram)
Disconnect the Key Chain from your computer. Done!
Nov 04, 2008 | Tao 1.5-inch Square Polished Silver Photo...
Photo keychain problems
What you do is drag the picture from your computer into the drive letter assigned to the key chain and see if that works.
Jun 22, 2008 | Symantec WinFax Pro for PC
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
