Question about Cameras
Hello, I connected my DCR-HC54 (minidv) to computer using USB cable (come with camcorder). latest PMB is installed on windows 7 64-bit home premium. It gives following message: Cannot find the Handycam (Tape). Check the i.LINK connection to the Handycam. What to do? If USB cable is not used, why sony gives it with camcorder?
    Genius:
  • 1,177 Answers
This type of camera usually downloads better with a Firewire (DV) connection. Sony call this "i.Link". Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. According to a list on the Sony site, your particular model is not one that can use USB for video transfers to computer.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other.
Sony have a help page for your camera, with tutorials and downloads, at THIS LINK
Posted on Dec 31, 2010
    Problem Solver:
  • 15 Answers
Hey , Mahmoud EL ashmoni here .i have a solution for this problem .Go to Start Menu .chose All Programmes then chose Movie Maker ^^ After that press on "Capture from video device" u will see ur camera Model Press Next then Start Capture Enjoy ur videos.... :)
Posted on Mar 30, 2011
I have DCR-HC 36E and as the PMB given as an alternative for Windows 7 comes with an ilink connection which is not there i n my computer. is there any USB driver for this camcorder.
This solution is only applicable for the selected camcorder models. You can follow the steps mentioned below for the DCRHC36 models.
  • Turn on the computer.
  • On the computer, install the USB driver from the CD-ROM supplied with the camcorder.
Only the USB driver included on the supplied CD-ROM will properly enable the camcorder for USB streaming. The USB Streaming Driver can only be installed from the supplied Software CD.
  • Turn the camcorder on to the PLAY/EDIT mode.
  • Turn on the USB streaming feature in the camcorder menu. P-MENUPICT.APPLI.MenuUSB SELECTSTREAM
  • Connect the USB cable to the camcorder.
  • Connect the other end of the USB cable to the computer.
  • Cue the video to the beginning of the video footage to be transferred.
  • Start the video capture software on the computer. You can try Software like Windows Movie Maker
o NOTE: The computer must have compatible video capture software to complete this procedure. Many video editing software applications include a capture function. If you have video editing software, you might not need a separate video capture application.
  • Begin playing the recorded video in the camcorder.
  • Begin importing the recorded video with the capture software.
Good Luck
FixYa
Nov 19, 2010 | Sony Handycam DCR-HC36 Mini DV Digital...
Panasonic Camcorder USB Driver for Windows 7 OS
Support site http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Camcorders/MiniDV-Camcorders/model.PV-GS500
User manual here http://service.us.panasonic.com/OPERMANPDF/PVGS500-MULTI.PDF
The USB driver gven by the manufacturer is not installing on the Laptop. you should NOT need a USB driver with windows 7 - the USB should automatically detect the camera
Apr 21, 2010 | Panasonic Palmcorder PV-GS50 Mini DV...
Sony Handycam DCR-HC42 Mini DV not recognized by Windows 7
win vista and win 7doesn't support usb streaming. the usb driver for this model would not be compatible with your computer's OS. although, you were able to download PMB still this wouldn't work, it's basically an alternative software that you can use with the newer OS. still the device driver would not be installed. and you would get a message that "ilink connection is not detected". the reason you get that is bec the camcorder and the software is intended for use with the dv (ilink or ieee1394) connection. so if your computer has an ieee1394 card and you have a compatible ilink cable,then your good to go,it should be a plug-and-play connection (no drivers required). all you need then would be a video capturing software (like win moviemaker) to transfer videos from tape to PC. hope this helps. thanks :)
Mar 28, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
My computer does not recognize the camcorder on the USB Drive Port.
did you install the cd driver camed with you camcorder to your pc? install it so that it recognizable the camcorder to your pc.
CHARCOIS
Sep 05, 2008 | Sony HVR-A1U Camcorder
Compatibility of Sony DCR-HC19E with Windows Vista
a firewire cable works but i have this from sony that might help others with vista as i contacted them direct and they sent me this for vista, http://support.sony-europe.com/dime/downloads/pmb/pmb.aspx?site=odw_en_GB&m=DCR-HC19E.
hope it helps you out
Aug 24, 2007 | Sony DCR-HC19E Mini DV Digital Camcorder
Cameras Logo
354 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
