Question about Xerox Office Equipment & Supplies
Work centre xd 100, error code c1 - Xerox Office Equipment & Supplies
    President:
  • 2,072 Answers
C1 indicates the paper is not feeding out of the main tray, your rollers are most likely slick or very dirty.
You can try cleaning them with a soapy cleaner such as fantastic or 409, but I would recommend replacing them.
Not hard to do, you can order them by googling a business called The Parts Drop, either e-mail them or call and ask for Britt.
No I don't work there, they are just someone I found to be excellent and reasonable to deal with parts wise.
Posted on Jul 08, 2008
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
Tip
Get hot water from your Rheem tankless during a code 76 error
This doesn't always work, but on the Rheem tankless Gas/Propane water heater, if you're experiencing a code 76 error; disconnect the remote control unit (either from the water heater or the remote) by lifting the wires for the remote connection. Typically you'll get a C1-C8 error code, followed by a code 76; if you're getting a straight code 76 and nothing else, this procedure probably won't work.
Code 76 is a total power supply failure on the printed circuit board (PCB) assembly, which is the communication/power supply for the remote control unit. But, if you're getting a supplemental code (C1-C8) this procedure will most likely supply you with hot water until the replacement PCB arrives.
on Dec 01, 2009 | Rheem Tankless water heater for 1-2...
What means c1 on aeg oko lavamat 74500
Hello!
Error C1 on AEG Lavamat usually means that there is a trouble with water filling. The required water level is not reached.
I reccomend you contact your local Service
Force Centre.
Here is the link to a manual of a similar AEG Lavamat waching machine (a "trouble shooting" part). Hopefully, it will help!
http://manualsbrain.com/ru/manuals/1793433/?page=30
Aug 20, 2014 | Washing Machines
Mobile password
Unlocking Nokia C1-01 by code is very simply . It is also safest and non-invasive method of unlocking your phone. Code to unlock Nokia C1-01 will be receive after entering IMEI number. You can get Your Nokia C1-01 IMEI number by typing *#06# or after removing the battery. IMEI is also written on the information label
For unlocking Nokia we need to know correct IMEI number and network that phone is currently working.
Giving correct network name and country of origin is very important. By choosing wrong network You risk receiving wrong unlock code.
Download Nokia Software Updater/OV I Suite from here>>>http://www.nokia.com.bd/support
Use Software Updater to update your Nokia C1-01 from v3.30 to v4.40
Don't use OVI Suite to updateyour Nokia C1-01 because it sends an error report when your update is reached to finished
Dec 11, 2011 | Nokia C101 Cell Phone
I have a Xerox XD 100 work centre showing a H-4 code what is the problem?.
The H4 code on these machines is almost always a false code. Especially if you have had any power fluctuations or failures.
Here is the text from my tip to solving this problem here on Fixya:
To reset the H3 or H4 condition on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This procedure will work on all Xerox XD and XC models.
Sep 03, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
Lost instructions. How do you change value of tax
The c1, c2, & c3 are for exchange rates. To set the c2 exchange rate press AC. Press the MODE M/EX button till EXCH appears in the display. Press and hold the SET/% button for a few seconds until SET EXCH appears in the screen. Press c2, C2 SET EXCH RATE should be displayed. Enter the desired echange rate. For instance, today, Thai Baht is 32.8677. Once you enter your desired exchange rate, press the SET/% button.
To convert 100 dollars using the exchange rate you set on c2, make sure that EXCH is in the display by toggling the MODE M/EX button. Press AC, enter 100, press c1 then c2. Using 32.8677 as the exchange rate 100 dollars would be 3286.77 THB.
To convert 100 THB to dollars you would enter 100, then press c2 and then c1 yeilding 3.04 dollars.
You can also program a different exchange rate into the C3 button. To convert to that currency, you press c1 then c3. To convert from that currency, you press c3 then c1.
Hope that helps
Dec 23, 2009 | Casio MS-80TV Scientific Calculator
Error code c1
Error code C1 indicates a problem with drive motor-thermal protector or the motor controller
may be due to overloading
Press( stop/cancel) to clear the display.
Hope this helps
Dec 23, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Getting error code c1
Hi
Error code C1 indicates problem with drive motor-thermal protector-or motor controller
Overloading may also cause the problem.
Hope this helps
Nov 24, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
What does j2 mean on a xerox work centre xd 100
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}H4 is a power failure code. To reset the errorplease press in the following order:
CLR - AUTO - CLR - AUTO
(this puts the unit in tech mode).
Enter 14 (as if asking for 14 copies)
Press "PRINT"
Your unit should reset itself and start working
Feb 19, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
149 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
