Question about Soyo 19" LCD Flat Panel Monitor
Hi there i have a flat screen monitor that is flashing at the power supply and causing the screen to flash in sync with teh green led can you tell me if it is the power supply or the monitor itself the model is dylm019a manufacture date is 051210
  • 11,361 Answers
One way to find out if it is the power supply or not is to use light bulb as a load, load it up to the current rating of the power supply to see if it will maintain the output voltage as indicated on the power supply.
I could not find the spec of this regulated switching power supply so I do not know the exact rating of this power supply.
Post more info about the power supply will help.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Dec 31, 2010
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
Falshing green power biutoon.
Verify all cables are secure, try reseating them. If the power led continues to flash, this usually means the power supply in the monitor is bad.
Oct 03, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Dec 19, 2008 | Acer AL1715 17" LCD Monitor
17 in dell monitor
Please disconnect the Monitor Data cable from Computer.
If you see Dell Colored bars, it means, monitor is working fine,
If still black, please ask for replacement, since Monitors have 3 years of warranty if not purchased with the computer.
Now connect the cable back to computer and turn the computer off by holding the power button on computer and turn it back on...
Blinking Green shows that computer is in sleep mode......
Hope this should resolve the issue.
Nov 06, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Green led light flashing on 700p proview flat panel and no picture
I have a similar problem.
Switching the screen off (front panel button) and on again after waiting a few seconds fixes it.
This is a recent problem, so I'm expecting it to get worse and worse until one day!!!!!!
Oct 03, 2008 | Hanns.G Corporation JW-199DPB 19" LCD...
Any high switching power supply of the same voltage and amperage rating will work for you. You may have to cut the end off of your old one and wire it to the new one to make it work but don't waste your money buying a specific power supply.
Good Luck!
Feb 16, 2008 | Computers & Internet
Power Led (Green) Flashing
Inorder to verify that the problem is with the monitor have you tried the monitor with another CPU could you please try it because it might be a problem with it the signal may not be reaching with monitor
Jul 26, 2007 | Dell E151FP 15" Flat Panel LCD Monitor
Cornea 15" monitor
If possible, try a new video cable. If it does not correct itself with a new cable, the problem is not serviceable. Flat screens do one of three things: inverter will go out (no light), line input board signal failure and power supply low volts on 12v B+.
Mar 28, 2007 | Cornea CT 1503 (Black, White) 15 in. Flat...
Soyo 19" LCD Flat Panel Monitor Logo
96 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
