Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
The starter gear is worn. can i turn the gear over and use the other side?
  • 297 Answers
No the starter gear is chamfered, so as to allow smoother entry into the ring gear. If you are going through the effort to remove the starter and retainer and spring, why not just replace the 3 dollar gear? Note the possition of the spring before you remove the gear.
Hope this helps, Matt
Posted on Dec 31, 2010
2003 toyota camry 4cyl.engine doesnt turn over but starter does.starter ck. and is ok , just makes starter whining noise
if starter motor runs (hear it??) but doesn't turn engine , then it needs to be replaced also at same time , the gear it contacts with on flywheel edge ,needs to be visually inspected (easy with starter removed) for any missing or bent teeth , as a engine this old is bound to have some worn or missing teeth, if gear is missing teeth or are very worn (teeth looks like a shark fin with hook to them) then engine and transmission will need to be separated to be replace the gear , most shops will just remove engine to allow for this , but this isn't always nessacary
Dec 14, 2016 | Toyota Cars & Trucks
Starter Motor spins but will not engage flywheel
First the battery fully charged? If not then starter can turn but just not fast enough to drive the gear up to engage the flywheel.
If the starter is turning at full speed then it depends if the starter drive gear is worn out or not. If the gear is okay then starter clutch maybe bad. If the clutch is bad then your better off just replacing the whole starter drive.
Jul 31, 2014 | Snapper Garden
Raptor 80 started turns but does not engage motor
sounds like the starter clutch is bad. the rollers get worn or the sprag gear gets worn so it will not grab and start the motor. check that out. you will have to take the engine side cover off to see it.
Apr 27, 2014 | ATVs
Hi ,I have got a 1992 vmax , when starting the starter turns, but the engine is not turning over , sometimes i can rock the bike in gear and then it might turn over .
Either your starter is bad, or the gear that the starter turns when it engages is worn. It is also possible that when the starter engages, it is pushing out too far, requiring a shim for the correct gear placement.
Apr 16, 2013 | Yamaha V-Max Motorcycles
My 2004 chrysler sebring its a 2.4 liter engine when I turn it on the engine makes a weird nose like if sumthing in the engine isnt rotating right what could it be
look for loose or missing starter bolts,the starter drive pinion gear either worn or damaged or flywheel gear teeth worn or broken. noise you hear if it sound like starter grinding noise check starter mounting bolts could be loosen or 1 missing or drive pinion gear or flywheel gear teeth worn or broken.
Feb 11, 2012 | 2004 Chrysler Sebring
One day my 1994 aspire will start fine the next it wont how can i fix this?
If I understand correctly the starter motor turns but does not cause the engine to turn over. If this is the case then the ring gear on the flywheel or flexplate is worn out, or the teeth on the starter motor are worn out. The starter gear does not engage the flywheel. With the starter removed the teeth of the flywheel can be viewed. turn the motor over by hand and look for worn spots; the gear teeth will be noticably shorter. If you find worn spots then the transmission will have to be removed to replace the ring gear. Another possibility is the starter is not pulling in correctly, thus the gears would not engage.
Nov 22, 2011 | 1994 Ford Aspire
I have a 2003 Utilimaster truck powered by a 5.7 Chevy 350. Last week it was turning over, but struggled to turn over. It started finally and I had no trouble cranking it for the rest of the day. The...
Sounds like you have a bad starter drive gear assembly (the gear on the starter that engages the flywheel gear). The drive gear has a one way clutch to prevent spinning the starter with the flywheel on engine start. When the clutch goes bad it does not spin the starter drive gear. If that's the case you can replace the starter drive rather than the whole starter, and you should also check the flywheel gear teeth to make sure none are broken or worn excessively.
Jul 24, 2011 | 1999 Chevrolet 3500
Grinding when starting, replaced starter one month ago engages well sometimes, but now will not engage flywheel could the flywheel teeth be worn or broken?
The flywheel is worn in that specific area. Engines tend to stop in the same one or two positions, and it is those teeth that get cachunked every time you turn the key. This is ok if the bendix does a good job of threading the gear into the flywheel teeth, but the problem is that now that the teeth are half worn away, the starter attempts to mount its gear to the teeth, but before the gear is fully seated, the contacts in the motor make, the motor starts to turn, and the not-yet-seated gear bounces off of the flywheel teeth. This is what causes the teeth-grinding sound (your teeth grinding in your mouth too!) when you turn the key. . There are two solutions: The first is to, of course, replace the ring gear. . The second is hard to explain, but a good starter rebuild center (if there is such an accessible animal around anymore) will know what I'm talking about: The starter gear must have the lagging edge of each tooth ground so that each tooth will look like a chisel. The "pushing" side of each tooth must be straight and come to the point (and not be beveled). The "non-pushing" lagging side of each starter tooth should have the bevel ground in on that side. This grinding is done easily by a small angle grinder or a Dremel Tool with a cutoff wheel. . This does one thing: It assures that the gear will "spin in" without bouncing. If ground correctly (it's not hard to do), you will get successful starts every time. This is a common fix for Toyota 4-cyl with this horrible all-too-common problem. Good luck.
Nov 25, 2009 | 1987 Chevrolet S-10 Pickup
I have a Murray Rider Mower with a Briggs & Stratton Engine Model number 287707. The Electric Starter gear turns, is not worn, but will not rise and meet the engine gear to turn the engine. Is...
try some wd40 on the shaft the gear rides on. work the gear by hand alittle it may just be stuck. usually if you dont have the power to spin the gear up the starter wont run at all
Nov 04, 2009 | Cars & Trucks
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
261 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
