SOURCE: do not have my user
Avery Berkel IX100 IX202 - IX series
The information contained herein is the property of Avery Berkel Limited ...
http://www.quicksupply.net/ix100-m.pdf
SOURCE: I have a Avery Berkel
this means the loadcell (weight sensor) is damages and needs replacing,this is best done by an avery dealer as you ned to know how to set up the calibration and trade approval,bob
SOURCE: Lost manual to programme new
http://www.averyberkel.com/download.aspx?did=2793
That will allow you to download the manual, you will need adobe acrobat to view the file.
SOURCE: avery berkel g227 instruction manual
Hello
Try these links
www.onepos.com/resources/scales/Avery_Berkel6700_L.pdf
65.39.72.142/Term.aspx?t=33186&org=50
www.posguys.com/download/pos6710_l.pdf - United States
SOURCE: Avery H500/L200 Avery Weighing Scales For
The zero capture is out of the 2percent tolerance so the cell is either faulty or requires zeroing. Open the unit and press the micros itch on the left of the board. The display flashes s. Press the zero key to change to flashing E. Press store to scroll to zero balance. Press semi auto tare. This captures zero without clearing the span calibration. The display will scroll around for a short period when complete press store.. Release the micro switch and scale will go thru warm up routine then display zero. Hope this helps, regs Darren.
