Question about Crosley WCK05W Compact Refrigerator
Refrigerator nor Freezer is cooling properly. Conservator by Crosley side by side with ice/water in door.
  • 213 Answers
SOURCE: refrigerator stopped cooling
the back panel inside the freezer has screws in it. take out the screws to remove that panel. the coils are behind that. melt all the frost. youll see one or 2 heating elements in there also. replace the elements. its a common ge problem. this will fix the problem
Posted on Nov 28, 2007
  • 226 Answers
SOURCE: neither the freezer nor the refrigerator is cooling properly
Check the evaporator coils on the back to see if they are warm. The cooling coils are supposed to be real cold. Sounds to me like you are low on refrigerant, and have a very small leak somewhere. I can't fix that from here, but service tech can find leaks, and recharge, but find cost first as you might just want to buy a new one as the other one is 10 yrs old. Hope this helps you, Rick
Posted on Apr 26, 2009
  • 363 Answers
SOURCE: refrigerator not staying cold,freezer runs fine;not icing up
i would replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Posted on Jul 30, 2009
woodchuck789
  • 4066 Answers
SOURCE: 253 55682402 Kenmore Side by Side Refrigerator Not
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Aug 21, 2009
Testimonial: "Thank you"
woodchuck789
  • 4066 Answers
SOURCE: crosley conservator is freezing, fridge not cooling
No, it is not normal. The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Posted on Oct 05, 2009
My Crosley Conservator Ice maker will only produce crushed ice, HELP!
Ensure the Wire Signal Arm is not in UP position. • Ice maker should produce 2.5 to 3 pounds of ice in a 24 hour period. • Water supply is turned off. • Water pressure is too low. • The freezer is not cold enough.
Apr 15, 2015 | Crosley Refrigerators
Fridge freezer door won'tstay closed
Faulty door seal.The seal that holds the door has a grip and a magnet on other side.May be that needs to be replaced.Or any fringe section tray is not completely fitted,to its end causing these.
Replacement parts can be purchased at any of the following web sites:
pcappliancerepair.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Frigidaire Refrigerators
Continuous beeping
Either any door is not closed properly or door sensor is not working,its not sensing the door closed.Or the problem is no defrost.The defrost is causing over ice in fridge or freezer section.
Reset the refrigerator by disconnecting it from wall outlet for 12 hours,then reconnect and see if still the same problem is there.
On some cases its issue with fan not working.There are two fans,one in freezer section and one in fridge section.If either of the fan is not working the controls will flash.
These will help.
Thanks,.
Dec 22, 2012 | Fisher and Paykel Active Smart E522B...
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
The freezer door is not sealing properly and seems to be off the track.
the spare seals are available,if the seals are not sealing,then may be its got worn out/ over stretched so it has to be replaced.
These will help.
Thanks,.
Dec 22, 2012 | LG LFX25971ST Bottom Freezer French Door...
Ice build up on the floor of the freezer. A water leak on the water line supplying the ice maker and water dispenser??
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 15, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ice side seems to be cooling fine. The normal cool side isn't cooling properly
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | Amana 22.6 cu. ft. Side-By-Side...
REFRIGERATOR FREEZER SIDE ICEING UP
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Nov 25, 2010 | Maytag MSD2351HEB 33" 23 Cu. Ft....
Freezer runs constantly, refrigerator not cold freezer ices up, does not defrost
heatman101
Oct 03, 2010 | Maytag 22.7 Cu. Ft. Side-by-Side...
Crosley WCK05W Compact Refrigerator Logo
Top Crosley Refrigerators Experts
Charles T Nevin
Charles T Nevin
fta777
Colin Stickland
Colin Stickland
Are you a Crosley Refrigerator Expert? Answer questions, earn points and help others
