Question about Panasonic PT-52LCX65 44" HDTV
Help!backlight on tv is showing through the screen!
It looks as if the red backlight on our Panasonic DLP is showing through the screen. Its small bright red area on the right of the screen when you are facing the television.
Contact panasonic directly, they will authorize a repair without cost to you. Just mention you heard that the set is in need of a (EPROM UPGRADE).....You have to have this done by a authorized repair center, Panasonic will set this up for you.
Posted on Jul 30, 2008
Tv has sound but no picture, nothing shows with the flashlight test, all inputs have sound but no picture, installed a new t-con card with no results ?
Use a voltmeter to verify the different voltages on the power supply board are present within tolerance. Look for discolored , puffy or domed capacitors. Repair kits and complete replacement boards can be had from: TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 17, 2016 | LG Televison & Video
My tc14p2se.. no screen but u can hear the sound..what should i check and replace any parts.plz help
Hi sound and no picture usually leads to your backlight inverters or your backlights thenmselves. Most likely the backlight. When you say no picture I assume you have a black screen with no lights.
You can get parts for this TV at www.interliquidparts.com
Feb 29, 2012 | Televison & Video
My samsung 55" DLP television
I looked up how to fix red horizontal lines on a Philips flat-screen tv. It turns out it needed the Y buffer upper replaced. I am not sure if this problem would be similar but it might help. I am also searching how to fix a fuzzy screen on a DLP tv. Hope you find what you need.
Nov 26, 2010 | Samsung DLP HL-P5663W 56" TV
I believe the blue lamp in my 57H81 is going bad.
You need to replace convergence out chips in your Toshiba 57H81 tv by qualified tech because 3-D look picture in rear projection tv shows some thing wrong with convergence output chips.
Your tv model number shows it is rear projection tv that use 3 tubes to make color picture on front screen where as dlp tv use one lamp as back light source to present picture at front screen that is generated in light engine.
Mar 25, 2010 | Toshiba 57H81 57" Rear Projection...
Panasonic LCD TV with cracked screen
Sorry,not repairable,because the LCD,PLasma,and DLP screen are limited produced.Replacing the tv pannel screen will cost the same as a new tv.Might even cost more after the labors.The tvs screen is about 90% of the tv,that why when is broken or damage,now it only use for it electronics boards parts,or sell for it electronics boards parts that it.
Mar 15, 2010 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
My tv no longer shows the color red. No idea what
I have sound but my tv screen is black. Sometimes when I turn on the tv I get a picture but after 15 minutes or so the screen goes black again.
It's a 4 year old LCD.
Nov 23, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Panasonic PT-52LCX16 DLP TV color problem
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Apr 26, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic Viera TH-50PZ80U No sound no audio only buzz.
Found the screen had a small crack and was shorting the video circuit.
Jan 03, 2009 | Panasonic Viera TH-50PZ85U Plasma TV
Computer vga to tv
I'm guessing you've resolved this by now, but, if this is a laptop computer, it is actually a function of the computer that you are looking for and not the TV. Typically there is a key function assigned to directing the display to the laptop only, the tv only, or both simultaneously. On my current laptop it is fn+F8. On my old Dell I think it was ctrl+F8
Hope this helps, sorry so late.
Aug 06, 2008 | Panasonic PT-44LCX65 Television
Panasonic PT-52LCX65 44" HDTV Logo
69 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
