Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
Unit never revs up to 10,000 rpms it tries about four or five times then stops and gets a blue blinking light.lacie d2 quadra 500 gb
    Scholar:
  • 80 Answers
if the unit has the original hard drives inside (i never one with 10 000 rpm drives though), the problem might be caused by a power issue.
Please verify the power supply by plugging it into the wall then listening to it. It should be silent. If there is a high pitch noise or hissing, it is defective and needs to be replaced.
If replacing the defective power supply did not solve your issue or if the power supply did not have any issue at all, the internal components will need to be inspected.
If you replaced the internal drives with 10 000 RPM drives, it might be why the drives do not get enough power.
Regards,
Posted on Jan 12, 2011
I am trying to set up the LaCie d2 quadra. I follow the steps in the manual but nothing is loading to My Computer.
you will need to go in Disk Management and format the drive first then it will be available in My Computer.
Regards,
Dec 30, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie d2 Quadra is inert: service/repair or buy new one?
Check with LaCie's support site at http://www.lacie.com/us/support/ and it's a good idea that you write down the serial number of your external disk.
Jul 09, 2010 | LaCie (300770) 250 GB Hard Drive
Doesn't work
am not so sure if this is a similar issue with iomega2_bing.gif external drive in which the drive wont show up on My Computer but when the external drive was plugged into an ubuntu machine the drive was being detected and working just fine.
Please try to do the same. plug your external drive to an ubuntu machine and lets see if it can be detected. If it is then the hard disk has a similar issue with iomega drives. check this link for the solution.
Apr 05, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Does not mount, Fan not spinning. 500gb D2 quadra
take the drive out and put it in a external case and see if that helps. if not the drive is dead.
Dec 13, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
LaCie d2 Quadra 500 GB HD dropped, now makes strange chime/alarm
Modern hard drive motors can easily become seized after an impact. The only DIY solution I am aware of is the use of a heat gun over the back of the drive motor. The build up of heat within the motor is sometimes enough to free it.
If the drive was running the problem may be due to a phenomenon known as "sticktion" where the drive head is actually stuck to the disc surface. If this is true then you need a data recovery company.
Nov 19, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Blu light flashing
This is most probably a faulty power cable, a common fault on La Cie apparently. Another cable got my disk working fine!
Nov 12, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Problem with LaCie 500 GB d2 Quandraq
Contact Lacie support for a new power supply. I had the same problem, contacted Lacie support, they sent me a new power supply with power cord and all is well now.
Sep 22, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Drive not showing up on my desktop
i'm not sure i can solve this problem--which started for me tonight as well with my lacie d2 quadra 500 gb--but i can share a possible explanation i've found online: apparently, they have lots of problems with their power supplies. see if the power adapter (the black brick) is making a hissing sound, or if there is a ticking sound coming from the drive itself. i have both these sounds. i am hoping all my data is safe and that my i.t dept. will be able to fix it with a new power supply on monday.
Sep 21, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
226 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
