Question about Baldwin 5445.003.PASS Classic Lever, Lifetime Polished Brass
Thumb latch will not open front door boldwin door
I need information on how to replace (or service) the door latch mechanism on my merc. I have realigned the door (and realigned the striker rod) and it will still not close. The latching system does not...
Removal
  1. Disconnect battery ground cable (14301).
  1. Remove front door trim panel (23942) and watershield from front door (20124).
  1. Mark the location of the bolt retaining front door glass run front retainer (21572). Remove the bolt.
  1. Check all rod connections against the appropriate illustration. Correct any disconnected or loose connections and check operation before replacing parts.
  1. Remove power door lock actuator (218A42).
  1. Disconnect the rods from the front door latch (21812). The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed at this time because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove front door latch control cylinder rod (22134) from the door lock cylinder (21985).
  1. Remove front door latch remote control and link (21818).
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) if so equipped. Remove the front door latch from the front door.
  1. NOTE: Do not damage anti-theft shield.
    Remove anti-theft shield from the front door latch.
  1. Remove front door latch remote control link, front door latch control cylinder rods and door open warning lamp switches from front door latch where applicable.
Installation
  1. Follow removal procedure in reverse order.
  1. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Description 1 Front Door Latch Control Cylinder Rod 2 Front Door Latch Remote Control Link 3 Bushing 4 Door Latch Shield 5 Power Door Lock Actuator 6 Front Door Latch Control Cylinder Rod 7 Front Door Latch 8 Latch (1 Req'd) 9 Screws (2 Req'd)
Feb 13, 2011 | 1997 Mercury Cougar XR7
My front loading washer door will not open. How can I open it?
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer door wont open
Jul 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet door locked cannot open it
Jun 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet washer was out of balance and almost fell over during the spin cycle. The washer was shaking and the front door came open during the spin cycle. Now the front door will not latch and stay...
May 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: how do we open a whirlpool front loading machine w...
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Trying to remove door latch on 1995 thunderbird. Car has power locks.
inside or outside latch? please rate
Section 01-14A: Handles, Locks, Latches and Mechanisms 1995 Thunderbird, Cougar Workshop Manual
REMOVAL AND INSTALLATION Latch, Door Removal and Installation
  1. Remove front door trim panel (23942) and watershield from front door (20124). Refer to Section 01-05 .
  1. Disconnect the rods from the front door latch (21812) . The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) , if so equipped. Remove the front door latch from the front door .
    Remove anti-theft shield from the front door latch .
  1. Remove front door latch remote control link , front door latch control cylinder rods , and door open warning lamp switches from front door latch , where applicable.
  1. To install, reverse Removal procedure. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Part Number Description 1 21852 Front Door Latch Push Button Rod 2 21940 Front Door Latch Remote Control Link 3 386656-S Bushing 4 21978 Door Latch Shield 5 218A42 Power Door Lock Actuator 6 22134 Front Door Latch Control Cylinder Rod 7 21812 Front Door Latch
Remote Control Assembly Door Latch
  1. Remove front door trim panel (23942) and watershield. Refer to Section 01-05 .
  1. Remove screw and washer assembly retaining front door latch remote control and link (21818) to front door (20124) .
  1. Rotate front door latch remote control and link to remove from front door latch remote control link (21940) .
Sep 27, 2009 | 1995 Ford Thunderbird
My door wont open,any ideas?
Sep 08, 2009 | Washing Machines
Can't open front door of washing machine Bosch wvf 2402
Apr 12, 2009 | Washing Machines
Front loader door not opening
Mar 31, 2009 | Washing Machines
Baldwin 5445.003.PASS Classic Lever, Lifetime Polished Brass Logo
263 people viewed this question
Top Baldwin Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Baldwin Electrical Supply Expert? Answer questions, earn points and help others
