Question about M-Audio Sputnik Multi-Patter Large Diaphragm Vacuum Tube Condenser Mic Microphone
Power supply for my m-audio sputnik blows fuses instantly. Is this fixable or do I need to shell out for a new supply?
Blown main ac fuse
a FEW ways this happens.
If fuse blows instantly when set plugged into power either a generic fuse (lots of these fuses are special and a generic will pop for no reason) or a dead short on the primary side of the power supply.
If fuse blows instantly when turned on a short either in secondary side of power supply or something it feeds.
First to try is get the exact fuse used (buy a pair) and see what happens.
beyond that if secondary side (when set is turned on) have an expert look at the set.
Apr 29, 2012 | Televison & Video
After about 8 great years, my sub died. i tried a different plug but no luck. the light is out and i have no sound. is there any chance that this is a fuse issue, or something else that may be fixable?
Sometimes replacing the fuse alone can fix the problem.
But if you replaced the fuse and blows when you power up the unit then its a clear indication that you have shorted parts on the power supply or on the main output I.C.
It is needed to send for repair because like what you have said it's been 8 years of service so it might also have a dry joints on the main board.
It is quite fixable just look for a qualified technician to isolate the problem.
Pls rate my help...
Thanks for using fixya...
Jan 14, 2011 | Audio Players & Recorders
Black screen no video no audio suddenly now
This set is a 50" plasma. first check the AC power fuse on the filter board then: if it is bad: check the power supply by marking and, removing all the cables; (so you can put them back in the correct spot) except the filter board to power supply cable; that connects to the Power supply board. Then: replace the blown AC fuse and, re-power: If the power supply blows the fuse: again, the power supply is bad and, must be replaced or, repaired. If the fuse does not blow: turn off the set then: on again, reconnecting and, disconnecting each board cable in turn, untill the fuse blows again this cable leads to the bad board; replace or, repair the board that blows the AC fuse every time the bad board is connected, irregardless of which other cable to the power supply may be connected also; or, not.
Jun 05, 2010 | Toshiba 50HP66 50 in. Plasma Television
JVC RX-318 keeps blowing fuses
could be several things, speaker wires touching,shorted output transistors, a shorted rectifier diode,bad filter caps in the power supply,those are the most common
Jan 06, 2009 | JVC RX-318 Receiver
Pyramid ps-36kx
Generally, the fuse only blows when the rectifiers fail. In other Pyramid supplies, they use a square, 4 terminal bridge rectifier. They probably use the same thing in your supply.
Let me know if you have any other questions.
Nov 15, 2008 | Pyramid - PS21KX 20 Amp Power Supply Car...
When the power switch is touched upon start up, the fuses in the power line that is connected to my power supply (RS-35M) instantly blow. The needle in the meter on the power supply pegs instantly also,...
dont use anolog meter use digital meter otherwise you will be confused connect a series lamp with power supply will stop blowing fuse then check 4 diodes if short then replace if not then check transisters if faulty replace then problem will be solved
Aug 12, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Have a nearly 30-year old Akai stereo receiver AA-R30. Power light just stopped turning on. Opened up case and found main fuse between AC power cord and power transformer blown. When I replace the fuse,...
Look for shorted output transistors or possibly shorted rectifier diodes. An immediate fuse blowing up usually means that the power supply is the problem. Keep us posted.
Dan
Apr 08, 2008 | Audio Players & Recorders
Blows fuse with no load
Sure sounds like your power supply has a short and should be replaced.
Oct 30, 2007 | Codegen POWER SUPPLY CG|PS-350XA-12 RT...
Diamond Audio Amp 1200.1 D5 Blows Fuses When Connected to Power!
if there was a misconnection polarity, you coud check fo shorted diode at power entrance circuit.
May 16, 2007 | Diamond Audio D5-1200.1 Car Audio...
173 people viewed this question
Top M-Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
SHIVAJI YADAV
SHIVAJI YADAV
Carlos L. Burgos
Carlos L. Burgos
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
