Question about Spectra Logic Hello Kitty 13" TV
I bought a used hello kitty radio tv 2002. emerson radio co. i have cable hooked up to it but channels won't go past channel 25. how do i program my tv with the remote?
I have an Element ELEFT502 50 HD Digital tv. I am trying to connect my cable line to the TV but cannot get the past the auto scan screen
put the co axel cable in the back , bypass this tv programming stuff put your tv on channel 3 or 4 and use the cable remote , no tv channels just cable
Feb 26, 2015 | Element Televison & Video
My emmerson tv won't change to the channel i need so i can hook up my dvd
Is the player hooked to the cable/coax fitting or the audio/video jacks?
Apr 24, 2012 | Emerson Televison & Video
I've lost the instructions for changing the channel on the our Hello Kitty KT2022 walkie talkie. It would seem simple (obviously someone played around with it and figured it out) but we can't seem...
To change the channel on the Hello Kitty KT2022 Walkie-Talkie:
-Tap the power button. The channel will blink.
-Use up/down arrows.
-Tap the power button again to save the channel selection.
The entire manual can be downloaded from here:
http://www.spectraintl.com/images/stories/pdf/hk/KT2022%20Manual.pdf
Oct 19, 2011 | Spectra Hello Kitty Mini FRS Two Way...
Does emerson model #20s5b have a switch to convert from cable to satilite?
It's in the channel programming menu. It should say, "Cable/Ant" or "Cable/Air" If you want a roof antenna with local channels, change it to "Air/Ant" Then click auto program with the antenna hooked to it to scan for free local channels.
Jun 16, 2011 | Emerson Televison & Video
I have a visco TV and I cannot get it off of channel 1. The remote does not work so I bought a universal remote but it still won't work. I tried to codes for NEC and Polariod as suggested by others,...
There should be channel buttons on the TV itself, try using those. Also, you may want to try changing the input from the Cable Box.
I am curious as to why the remotes don't work. Also, how did it get onto channel one. Did you get the TV used?
Here is a link to the AV Science Forum. It seems other people have challenges with this TV as well.
http://www.avsforum.com/avs-vb/showthread.php?t=745952
May 19, 2011 | Televison & Video
How do I program my television channels to get all my channels through the vcr?
Hello. Hook up your cable or satellite wire to the VCR and then hook the VCR to the TV. Leave the TV on channel 3 or channel 4 all the time and change channels using your VCR. Thats it.
Regards, Joe
PS kindly rate my answer. ty
Jan 21, 2010 | Televison & Video
I have a emerson 32 inch tv ewf2702. The remote does not work
try scanning your TV channels down or up depending how close you are to the first or last channel you have programmed, if you continue to move past those settings you should come to the game channel for your TV, if it does not go into your menu>channel settings>manual settings, scan to the game channel and make sure it lists as active if not make it so.
Dec 07, 2009 | Televison & Video
Problems hooking up a VCRplayer
Hello..try to turn on the test signal generator switch it is marked test at rear of vcr...and chose av¨rf channel on your tv i.e the 0 or 9 channel than search for the vcr and memorize on tv...alt you can playback a tape ..pre-recorded without the test signal and make the search...alt 2...use a direct av-cable between vcr and tv..which is best and put tv in av mode...good luck...Ron
Mar 11, 2008 | Televison & Video
Emerson VCR and new TV don't hook up
hey i sort of hav the same problem except, i cant access the "channel" with my sons game stuff on it
if i click menue then it just givs me "Picture" "Channel Set" "Language" "V-Chip Set-Up" "Captions" and if i click channel set i get "CH{TY}" "CH{CATV}" "CH{DTV/TV}" and v-chip asks me for an access code. and i got this tv from a friend and he lost the remote. i only hav an iO Digital Cable remote. help me plz
Oct 28, 2007 | Emerson EWD7003 DVD Player
Spectra Logic Hello Kitty 13" TV Logo
26 people viewed this question
Top Spectra Logic Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Spectra Logic Televison and Video Expert? Answer questions, earn points and help others
