Question about Cameras
Kenwood TH-F7E manual - Cameras
  • 536 Answers
Strange that you put a question about a transceiver into the digital cameras section, but I'm game!
I found it: (click here) [radioamateur.eu]
Posted on Dec 31, 2010
How do i open a kenwood th-234 battery pack? all the manuals i have seen shows a release lever in the battery pack. mine do not have one.
If you are talking the battery pack itself, it is possible you have a NiCd battery instead of the Alkaline battery shell. If your battery does not have the locking tab to press on the battery pack, look for the part number and description on the battery itself and see if it matches what is in the user guide.
http://manual.kenwood.com/files/B62-0790-10.pdf
Best regards.
May 13, 2016 | Kenwood Radio Communications
How to modify kenwood th234 from channel mode to vfo mode?
[PDF]Page 1 INSTRUCTION MANUAL KENWOOD ...
o Contains 60 memory channels programmable with desired frequencies and ... o Do not modify this transceiver unless instructed by this manual or by ... BASIC TRANSCEIVER MODES . ..... 1 Press [VFO] to select VFO mode. P1'I switch, and ...
[PDF]INSTRUCTION MANUAL - Kenwood
manual.kenwood.com/files/TH-D7-English.pdf
memory channel to be named using up to 8 ... Do not modify this transceiver unless instructed by ...... In VFO or Memory Recall mode, use the keypad to select a ...
Modifying the Kenwood TH-78a handheld transciever
www.welcomehome.org/rainbow/.../kenwood/kenwood-th78-mods.html
Nov 17, 1995 - (When William's early-model TH-78 was upgraded his mods (removed .... channel (if in memory recall mode) or last frequency (if in VFO mode).Missing: th234
Dec 21, 2015 | Phylrich Mirabella 3/4 Inch Thermostat,...
Why does my kenwood TH-K2 fm transceiver will not transmit
Users Manual (download if you don't have it)
TX I
NHIBIT
You can inhibit the transmission to prevent unauthorized
individuals from transmitting, or to eliminate accidental
transmissions while carrying the transceiver.
1 Press [MENU].
2 Turn the Tuning control to select Menu No. 25 (TXI).
3 Press [MENU].
4 Turn the Tuning control to select "ON".
5 Press [MENU] to store the setting or [PTT] to cancel.
"TX INH" appears and an error beep sounds if the
transceiver tries to transmit while TX Inhibit is ON
May 11, 2014 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
Kenwood 220 hand mixer manual
Hi Charlie,
You query was posted on the two way radio forum by mistake, could you re-post on the kitchen ware forum, so you can find the answer there.
Cheers,
Peter
Mar 18, 2013 | Kenwood TH F6 A 144/220/440 Handheld...
The volume control on my KENWOOD TH-78A no longer functions
first of all check the volume control see if a wire broke off. but i suspect a cold solder joint on that volume control switch. if not check the board for a small crack.
Apr 10, 2009 | Kenwood PB-18,...
Unlocking Kenwood TH-22AT
http://www.radiomods.co.nz/kenwood/kenwoodth22.html
Dec 20, 2008 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
KENWOOD TH-22AT WITH LOW VOICE
Drill a hole in the front panel. The mic is behind the front panel. Be careful.
Aug 12, 2007 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
Cameras Logo
75 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
