Question about Dryers
Amana electric clothes dryer won't heat up - Dryers
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Dec 31, 2010
Dryer heats but won't dry clothes completely
Inspect and clean the dryer is what I would do. most times it is a faulty blower wheel causes your symptoms.
Feb 16, 2013 | Amana Dryers
AMANA GAS DRYER, MOD.#LEA1OW/LGA10AW . CLOTHS WILL NOT DRY-IGNITER LIGHTS, BUT GO OUT BEFORE BURNER COMES ON.NO HEAT.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Amana Dryers
I have a Amana clothes dryer model no NDG78700AWW. The dryer tumbles but it is not producing any heat. Any thoughts on the problem?
heatman101
Aug 07, 2011 | Amana NDG7800AW Gas Dryer
Dryer starts but wont dry cloths can hear gas valve click ,vent starts to get warm then cools off sounds like blower/gas is lit but no heat amana ngd7200tw
heatman101
Jun 28, 2011 | Amana NGD7200TW Gas Dryer
My Amana heavy duty dryer will not get hot
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 05, 2010 | Amana NDE6800AYW Electric Dryer
I have the Amana LG-8219W2 Gas Dryer. It is tumbling, but not drying. Any suggestions are welcome!
heatman101
Jun 23, 2010 | Amana DLE330RAW Electric Dryer
Dryer is not heating up
This is a simple dryer design. The limits and heater are all mounted on the heater assembly. 9ce9b7a.jpgGet the front off and take a look see. AMANA DRYER
May 04, 2010 | Amana NED5500TQ Electric Dryer
AMANA LEA60AW ELECTRIC DRYER, DOES NOT DRY CLOTHES FULLY
Your heating element is dying. A new element runs 'bout $40. It'san easy fix. Couple screws .
Mar 05, 2009 | Amana ALE643RB Electric Dryer
Amana dry wont dry
partially bad heat element. some models have a double element maybe half of it is burned out
Nov 17, 2008 | Amana NDE2335AY Electric Dryer
Dryers Logo
162 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
