Light violet displey monitor - Computers & Internet
  • 374 Answers
First check the 15 pin monitor cable connector on the rear of your computer. Be sure that it is fully inserted. If the connector has hold down turn screws be sure they are hand tight. If that doesn't fix it, Isolate the problem to either the monitor or the computer by connecting a different monitor to your PC. Then if the problem is still there you will need to take your computer to a service tecnnician. He may be able to resolve the problem by installing a video card in place of your on-board video.
Regards,
Yavacotech
Posted on Dec 31, 2010
The monitor won't show the sp mode
what is the sp mode?????
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 30, 2016 | Konica Minolta bizhub 350 All-In-One Laser...
Travelmate 4150 displey light
I have Acer laptop battery as07b41,the basic information shows for yo,please click here!
May 15, 2012 | Acer TravelMate 4150LMi Laptop Charger...
INTEL M B DG41RQI ONE BEEP ON START BUT NO DISPLEY PROCESSOR FAN IS RUNNING
Please check weather the cpas lock and num lock led are blinking thrice. If so juct change your monitor and check with other screen.
Jul 23, 2011 | Computers & Internet
Can`t find the external displey
You can switch to anexternal monitor (display) by two methods. 1. Connect the externalmonitor to the laptop's video port, power up the external monitor first and thelaptop. The video information will automatically switch to the externalmonitor. 2. If you power up thelaptop first then you can switch the video output to the external monitor bypressing the Fn key and one of the Function keys, depending upon your make andmodel laptop. You can also toggle between the external monitor or both LCDscreen plus the external monitor or back to LCD screen only by pressing the Fnkey plus one of the function key. Here is a list of keycombinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Mar 03, 2011 | Computers & Internet
Hi, the red color desappered from the monitor, I can not adjust it, is this problem with a displey or with computer
If only one color is not working - it is usually just the connector of the screen or the monitor cable itself that is faulty. Remove the Monitor Data cable that plugs into your PC and check that NO pins are bent or pushed into the socket - then re-insert the VGA connector into the PC and make sure that the part of the cable that plugs into the monitor itself is also secured properly. That should solve the problem. If not - it could be the cable itself - bend the cable at the connector to check for a lose wire inside. If the color suddenly comes back - replace the data cable to the monitor.
Hope this helps
Good Luck
Feb 07, 2011 | Planar PL2010M 20" Flat Panel LCD Monitor
Use the monitor then only blue and violet color show not show all colors
it is a problem of connection loose in board parts of monitor. it is called colar fade . it is repair by eletronic technican only. thanks
Nov 11, 2010 | Samsung SyncMaster 753S 17" CRT Monitor
A wide horizontal bar is coming in the middle of the screen with a violet color
check for magnetic fields around the monitor or else try degaussing the same or else replace ....
Feb 23, 2010 | NEC MultiSync 1920NX 19" LCD Monitor
Nokia 6630 white light displey foult
the lcd needs to be replaced on the phone.
May 30, 2009 | Nokia N73 Cellular Phone
When i log on to my windows profile the screen
try reset the display settings click right on the desktop
choose diplay parametrers.
Mar 13, 2009 | HP w2207 Monitor
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
