Question about Sunny Health & Fitness Sunny Twist Stepper Stair Climber With Handle Bar
How do i hook the cable to the pulley - Sunny Health & Fitness Sunny Twist Stepper Stair Climber With Handle Bar
How do I reattach the deck to my riding lawn mower
do you have a pto lever that tightens the belt? if so theres a bracket on top and in the back that holds the cabble but first you must attach the spring to the pulley that's on a arm that releases and tightens the belt, there is a hole on the arm closer to the pulley itself hook that up and pull with a little strength and put the end of the plastic of the cable in that bracket and with a carter key holds it in position and then try your lever then make sure nothing is rubbing or under a strain, hope this give you some idea of what to do
May 16, 2015 | Garden
Blade engager is disconected under the mower where the cable comes out. theres a spring at the end of the cable and i do not know where it hooks.
There are four pulleys on your deck. The two larger ones drive the blades, the two smaller ones are idler and tension. The idler is on the left, the tensioner is on the right. On top of the small one on the right, in and forward of the one that drives the right blade, this is the tension pulley. With the deck fully lowered, feel the skinny metal piece that rises out of the middle of it, at the top there is a hole. A bee clip goes in the hole. The spring on the end of the cable hooks over this rod and the clip keeps it in place. Your clip either has broken or become dislodged. Look on the mower deck for it. If you can not find it the clip is very similar in size to the one that holds the cable in place on the back of the deck. If necessary, remove this one and test fit it in the hold above the tensioner pulley and go to the hardware store for a replacement.
If youare unable to locate a replacement, let me know and I will describe for you how to order one.
Jul 25, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Thin belt on back of drum broken how do you replace and repair??
When you say the thin belt I assume you mean the drive belt.
Hook the new belt on the motor pulley and onto the main drum pulley as far as it will go, hold it on the pulley with a few cable ties. Rotate the inner drum anti clockwise and this will draw the belt onto the pulley and snap the cable ties as it revolves. Use a genuine Hotpoint belt because they contain a carbon fiber content which is designed to counter-act against static electricity, a fault first noticed in these machines some years ago (it can cause the neons to flash and irregular faults to occure)
Click these links for Hotpoint WMA & MW workshop manuals and error codes
Mar 17, 2010 | Hotpoint WMA76 Front Load Washer
Yeah hello there , im trying fitt a belt two hotpoint washing machine wf100p , i havn't taken the back off putting the belt on the motor first the on two the drum wheel gradualy turning the wheel to put...
You are doing the right thing. Hook the belt onto the motor pulley, then onto the main pulley as far as it will go, use a few cable ties to hold it on the pulley and turn the drum anti clockwise, the cable ties will snap as the pulley turns. Hotpoint have made a tool for putting these belts on but you woudn't want to pay out just for one belt.Belt fitting Diagram link
Mar 16, 2010 | Hotpoint Aquarius WF000 Front Load Washer
How do i fit the drive belt on a hotpoint wma74 washing machine
Hook the belt over the motor shaft and feed it onto the drum pulley as far as it will go,hold it in place on the pulley with the aid of cable tie clips, then rotate the inner drum anti clock wise by holding the inside of the inner drum. This will draw the belt onto the pulley and the cable ties will snap as the drum rotates.
Mar 04, 2010 | Hotpoint WMA74 Front Load Washer
My older dyna mark riding mower has the cable to the blade engagement hanging underneath it cant seem to find where it hooks back up any ,the cable has an O ring on the end .
LOKK AT THE SMALL PULLEY THAT THE BELT IS WRAPED AROUND THE BOLT HOLDING THAT PULLEY ON SHOULD BE LONGER IT SHUOLD GO ON THAT BOLT YOU WILL NEED TO HAVE A WASHER ON BOTH SIDES SO PUT A WASHER ON THE BOLT THEN THE CABEL THEN A WASHER THEN PUT A CORTER KEY INTHE HOLE TO HOLD IT IN PLACE AND THAT SHOULD YA UP IF NOT LET ME KNOW AND ILL LOOK AT SOME OTHER ONES TO SEE HOW THAY HOOK UP
Nov 08, 2009 | Garden
IBM Selectric II Will type letters, but will
Several possible causes. Needs lubrication most commonly. Sometimes the velocity cable is hung up on the left side and under the carriage. remove the ribbon and shine a light down on the left side and look for a cable hung up on the pulley, make a hook with a paper clip and lift the cable up and past the pulley
Aug 31, 2009 | Office Equipment & Supplies
My IBM Selectric II types the wrong letters. No matter which key I press a different letter will be typed. But there is consistency in that the wrong letter will repeat over and over again so its not...
Sounds like the cable might have slipped off the pulley, with the cover off, check all cables to the carriage assy. You need a tool like a spring hook to gently slide the cable back on to the pulley.
Jul 24, 2009 | IBM Wheelwriter 30 Typewriter
How to replace Ice Door Solenoid
I got help from repairclinic.com , and didn't see any reference to a solenoid. I fixed my GE fridge, its model is #TFX27FJB,,,,Free!!!! The replacement part would have cost 46.60.
On inside of freezer door, behind ice dispenser, there is a panel about 7x9
(plastic) that you can gently pull the tabs free and remove the panel. You will see the mechanical stuff. There are 2 gear like (pulleys) that are in the center area,supposed to be connected by a part that is about 3-5 inches long , like a small wire cable with hook type ends, think it's called "lanyard cable" , mine was broken, so I patched it with some scrap wire,,,one end hooked to one pulley and the other to other pulley(gear). When my ice door quit closing after getting ice,this cable had broken, What I did was find a small wire, to fix the break,, using as much of the original cable as possible, make sure that total length is same as original. Hook one end to one pulley and wrap it around it, it has to be wrapped a certain way, I can't remember counter-clock wise or vise-verso, till it will take up all slack, and just reach and hook to the other. I think it is a spring that opens door, and then the gears turn to close it, that is why it has to be wrapped with no slack.
It cost nothing and it works great now,, the repairclinic.com will show you specs so you can see what you are doing.
I didn't want my food to thaw, so I had a large piece of Styrofoam that I cut to fit in door jam, to keep food safe.
Good Luck
Hope this helps.
Barbara H.
Mar 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Dishwasher ''soft drop door'' mechanism came apart - door now drops
I had a similar issue as described by mc1bean. One day my Jenair dishwasher door just fell down. The right side spring was fine. The left side spring was still hooked into the door hinge but the cable was laying on the floor in 2 pieces. Over time it wore down and broke. I ordered just the soft drop cable. Now I could not find any installation instructions how to install the soft drop cable. After a few tries I think I got it right. Here are the instructions for hooking up the right side spring with the cable. The spring has to be hooked into the door hinge at the notch closer to the door. The end of the cable with the hook has to be hooked into the other side of the spring. The cable should lead from the bottom around the pulley up to the door hinge again. Now the other end of the cable has to be hung into the door hinge on the notch further away from the door. There is some slack, but it is not quite enough for the cable to get over the pulley when in rest position and undo itself.
I hope this helps others who have the same issue.
Feb 10, 2009 | Dishwashers
Sunny Health & Fitness Sunny Twist Stepper Stair Climber With Handle Bar Logo
Top Sunny Health & Fitness Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Sunny Health & Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
