Question about Price Pfister Plumbing
I do not like the way the spray function of my faucet works. The spray is very thin streams that are very strong and it sprays so hard that it ricochets off the pans and sink and gets everything wet. Consequently I am reluctant to use it very often though I would like to have a good LESS VIOLENT! spray. Can I get another piece to replace the one I have? I don't have the model number and i can't find it on your web site, though the Clairmont looks very similar; I purchased it a year ago at Home Depot and I love it, except for the spray!! Please advise. Thanks Ida DeField
  • 83 Answers
The problem may be some debris is caught on the aerator
part of the sprayer...try removing piece at the end of the sprayer and inspect
Posted on Dec 31, 2010
Have a Blanco single-handle pull-out faucet with single-stream and spray option. Spray option can be turned on and off with a twist switch on top of the faucet. Our faucet is now stuck on spray option and...
Unscrew the part where the water comes out and remove the enterior parts paying close attention to how and the order in witch the come out so you can clean everything good and put it back together and pay close attention to the twist switch and how it operates. This shought fix the problem your having.
Jun 30, 2011 | Blanco Classic Single Handle Faucet with...
I have a pull out spray kitchen faucet and the spray faucet leaks around the pin that changes the water from a spray to stream. Can I get a replacement for the spray/stream head?
take old sprayer with you and you should be able to get one at a hardware or even at homedepot.most sprayers come apart. maybe the rubber ring is bad on inside of sprayer.
Apr 21, 2011 | Plumbing
KWC Domo faucet sprayer won't switch between spray and stream
Having installed and fixed kwc domo faucets for years I'd probably take the spray head off of the hose, then look into the bottom of the spray head and see if the check valve is still there. It probably is. I used to use a thin screwdriver to pry the check valve out out.It will come out. You need to work at it a bit but these hold back a lot of water pressure and catch any crud coming down the water lines.
TL
Mar 17, 2010 | Plumbing
Hansgrohe 06566860 Metro Single Hole Kitchen Faucet periodically makes noise and reverts from needle spray to full spray by itself. Have to press on needle spray indicator on top of sprayhead 4 or 5 times...
make sure the hose under the sink, ( the one that goes to the faucet) has not gotten twisted around anything. sounds like it is losing pressure. it takes steady pressure for the stream to maintain that "needle" spray.
Feb 15, 2010 | Hansgrohe 06649860 Solaris Single Hole...
I have a kitchen faucet by hansgrohe, 06801860. When I turn on the water, some of the spray comes on, when I press for the spray, a thick stream of water comes in the center. I would love to have spray...
your sprayer ''picks up''it's supply from the flow to your faucet.spray heads wear out & are not repairable.replacement hose & sprayer assembly can be found at home improvement stores.if you can see the other end of the hose where it attaches to the faucet,it's not too hard to replace.you don't have to turn off the water at the meter.
Sep 22, 2009 | Plumbing
Delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Dec 07, 2008 | Delta 473-WHSD-DST Saxony Diamond Seal...
Plumbing Logo
144 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
