Question about Sony Playstation 3 (PS3) Console
Rsod in model CECHL01 - Sony Playstation 3 (PS3) Console
Red screen on ps3 and i can do nothing anymore
Hi darkstaf,
This is similar to the red light problem but the reason you get a screen is because the GPU has overheated.
You just need to stop the heat build up getting to the main chips and you will be able to play your games again.
To do this you have 2 choices:
Send it in and they will fix it for you although something to bear in mind that it will take 4 weeks and cost you $150 for the fix.
Or you can use a good PS3 Repair guide and fix it yourself.
A word of warning before attempting any home repair solution:
CLICK HERE TO CHECK OUT A FULL REVIEW OF ALL THE PS3 REPAIR GUIDES FIRST
I hope this helps.
Mar 16, 2011 | Sony Playstation 3 (40 GB) Console
For the Ps3 whit RSOD...ok but i have put off my hdd and i have send this one to my friend to try to ''Format it'' and the PC dont ''see'' the hdd i think its only the hdd is dead! i will try to change...
The computer won't "SEE IT" because the drive is encrypted. You can still format the drive but you'll need to use Windows Disk Manager.
Or Disk Utility if you or your friend has an Apple computer.
If you've got a RSOD the problem probably isn't related to the hard drive but the console has overheated.
You can keep all your info if you DON'T format the old drive, just pop a new or used SATA drive into the console and try to boot, if you get video then YES it's the drive, if you get the same results then NO the console has a hardware problem.
Hope this info helps!
Nov 02, 2010 | Sony PlayStation® 3 (60 GB) Console
Want read games but reconizes dvd worked fine until yesterday
PS3 won't load games means blu-ray drive errors and need some maintenance. Do you know, send back to game shop is too expensive and waste your time. Learn the correct repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn :
DIY PS3 Repair Guide
Not only such game reading problem, you can repair other red and yellow light related issues as well.After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
Jul 27, 2010 | Sony Playstation 3 (PS3) Console
How to play ps2 games on ps3 80gb cechL01
if it is the original 80GB that is NOT SLIM, then it can't play list of like 400 games.
If it is slim, then I do not think that it can play PS2 games.
Feb 13, 2010 | Sony Playstation 3 (PS3) Console
The on / off switch needs replaced on a PS2 player. Where can we purchase the switch?
I have several, what is the model of your PS3,
CECHP01, CECHL01, CECHK01, CECHE01, CECHA01, CECHH01 etc. If you like you can email me directly. ElectronicRepair@comcast.net
Oct 23, 2009 | Sony PlayStation 2 (PS2) Console
PS3 does not detect controller even with a USB cable
hold down the ps button. and then connect a usb cable .
Sep 03, 2009 | Sony Playstation 3 (PS3) Console
Hard disk's file system is corrupted
Hi if you have the ps3 with the model # cechh01 or cechk01 or cechl01 this happen a lot you need to install the new update in a usb memory card and follow the instructions on the ps3 go to sony for instructions on how to download the update in a removable usb if you have the older models you need to format the hard drive or install another one and format the old drive in another ps3 and this can fix your problem
Mar 13, 2009 | Sony Playstation 3 (PS3) Console
Samsung sync phone
first thing is take the battery out of the unit and let it sit for 30 minutes.
if that does not work, your phone has done what we called "flashed its memory" and you need a replacement unit.
Jan 01, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Sony Playstation 3 (PS3) Console Logo
186 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
