Question about Singer 8280 Mechanical Sewing Machine
My face plate will go backwards and put the needle all the way down but when I turn it away from me it is like something is stuck. The needle will not go down.
    Genius:
  • 1,788 Answers
DO NOT TURN AWAY from you. You will mess up the timing and then you will need professional service. Why are you trying to go backwards? To reverse sew, you have a lever
Posted on Jan 01, 2011
The needle has got stuck and does not come up when the handwheel is turned counter clockwise.
I would take it to the Sewing Shop. You've probably damaged whatever the needle has wedged itself into ...plus the needle and maybe the mechanism that drives the needle up and down.
Mar 16, 2015 | Singer 2250 Tradition
My bother power sewing machine has lock up the wheel will not turn
Try to turn the hand wheel backwards possible thread stuck on the needle hook by the bobbin. Take the bobbin out and remove the face plate and clean machine.
Jan 31, 2015 | Sewing Machines
Frequently, while I am sewing, the needle hits something below the guide plate and gets stuck. I have to remove the guide plate and then the needle will release. What is the problem with my machine?
If the needle gets stuck with no thread, The needle is hitting something. Could be needle not up all the way or something needs adjusting. If it gets stuck with thread. It is probably an upper thread tension or threading issue.
Apr 05, 2014 | Juki DDL-8300
Needle stuck
the machine is out of time & will have to be retimed at a sewing machine shop
Mar 20, 2012 | Singer Sewing Machines
Needle problems
Firstly check you have put the needle in the correct way! It is just so easy to do it wrong. If the needle plate/opening for bobbin is at the front then the flat side of the needle faces away from you. If the needle plate/opening for bobbin is at the side then the flat side of the needle is placed to your right. If after checking this and using a new needle it is still missing then the timing is out and you need to take it to be repaired-it is not something you can do yourself.
Dec 03, 2011 | Sewing Machines
Shark europro 60- 384 not needle getting stuck
Hi, I will try to help you. I am hoping it is not the timing but let's try this:
1. insert a new needle 80/12, flat side facing away, of course.
2. Use a cotton or something not too heavy to test it.
3. Make sure that the feed dog is feeding the fabric not being forced.
4. remember to make sure that the needle is inserted all of the way up in the shaft.
5. Clean it, thoroughly by taking off the face plate under the needle with a screw driver because it can get jammed up with lint and cause breakage. You cannot always get it with just brushing out the bobbin area. Mine had so much it looked like a piece of felt because I didn't know about doing that until some dear sweet soul told me.Now oil it according to your manual.
Sometimes, it is in the threading, bent needle or a burr in the face plate hole where the needle goes. If, you need a copy of your manual, I happen to have one that I would be glad to email you for no charge. My sister in law has the same machine and her buttonhole sizing does not work.
I wish you good luck and hope that I helped you with the inexpensive ideas.
Feb 20, 2011 | Euro-Pro Sewing Machines
I am wondering if I need a throat plate to sew. Everytime I start sewing, it gets clogged up and makes buzzing noises. I cut the tight threads, start again, and then it happens all over again. So, Is there...
Yes, you need the throat plate, Somehow you are not threading it right. Do this, change your needle, flat side facing away from you, totally rethread, with the presser foot up, pull the threads, it should move smoothly, now put the presser foot down, the thead should barely move when pulled. This normally will seat the thread in the tension discs. I don't know what else to try without being able to see the machine.
Jan 14, 2011 | Sewing Machines
Needle hits plate and breaks or bends wont line up
If your needle is hittle the face plate, then it is out of time.. I would take it to your local repair center.
Apr 24, 2009 | Brother LS-2125 Mechanical Sewing Machine
Singer 8280 Mechanical Sewing Machine Logo
74 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
