Question about Gateway FPD1976W LCD Monitor
When I turn on my gateway computer my monitor will turn on but will says "no signal RGB". is it my motherboard thats going bad?
  • 374 Answers
Your monitor is not receiving a video signal from the computer. If it's a problem with your on-board video, it may be possible to fix it by installing a new video card. However, at this point we don't know what is wrong with your computer. It could be the power supply, motherboard or processor. A technician will have too look at your computer to tell you what the problem is.
Regards,
Yavacotech
Posted on Dec 31, 2010
  • Gateway Master
  • 6,771 Answers
If the monitor comes on with the Gateway logo and follows with no signal, the monitor is probably okay. If the computer seems to run with no display then I would suspect the video graphics card, but there are a lot of variables that I do not know. I suggest a computer repair store to check your system with an estimate.
Gateway Dx 4300 - black screen and message "No signal RGB"
soumds to me that a setting has been changed on the monitor itself. play around with those and im sure you will find a fix keep RGB in mind
Jan 31, 2013 | Computers & Internet
What would be the best thing to do if my computer goes No signal and RGB with a red green and blue background and screen turns off by it self
go to safe mode and try to reduce the resolution to like 800x600 and see if that would fix it. if the monitor is good you should be able to see everything on the screen. if so, then you have to find out what's the max resolution the monitor will take and adjust to that setting.
good luck!!
Sep 01, 2011 | Gateway FPD1975W 19" LCD Monitor
Installing new Samsung BX2250 21.5 widescreen monitor, don't have the appropriate DVI outlet on my computer to match HDMI to DVI cable supplied with unit. Monitor is stuck on "Check Signal Cable...
Your monitor has Analog RGB, DVI and HDMI inputs. Any other hook ups will require additional cables and/or adaptors. It also has 2 additional audio inputs. I can't answer your question without knowing what kind of outputs you do have on you computer system. Most desktops have DVI out and would probably be your best bet using a DVI to HDMI adaptor with a HDMI cable out to your HDMI in on your monitor.Rgb cable would use svga out on your computer. The best way to get an answer would be to let me know the make and model of your computer system with avaiable outputs, if you know what the outputs are or, repost with additional info included.
Dave
Apr 30, 2011 | Samsung Computers & Internet
Gateway FPD2275W LCD monitor lost "Red" signal of RGB display
Not really, first check your connections, normally when you loose red a pin broke off the VGA connector.
If the panel died then its probably not worth while. The red panel is however, under the most stress.
Jul 09, 2010 | Gateway FPD2275W LCD Monitor
My flat panel moitor displays RGB no signal. I
If the other monitor has no signal as well, this proved the video card is faulty and needs to be replaced.
Dec 03, 2009 | Gateway Computers & Internet
RGB No Signal Message
First you need to check the cable at both ends, inside and out. Make sure it is plugged in, to the proper connector and that there aren't any bents pins. Now put this monitor on another computer, a laptop will do. Does it come on now? If so then your video card in your machine is bad. If still bad then the monitor has lost it's signal input. This will have to be repaired by a pro. I repair these all the time and it's not as expensive as you might think.
May 30, 2009 | Gateway FPD1975W 19" LCD Monitor
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
No RGB imput signal
You need to change the input signal, get into the menu on your monitor and change the signal from rgb to dvi, hdmi or vga dipending on what cable you using for connection.
There is NO rgb connector on that monitor
Good luck
Dec 05, 2008 | Balance CM2015 15" LCD Monitor
Just beeping
Have you done something on your computer before that happen? Maybe change your display resolution? or video card?
Oct 24, 2008 | Gateway GT5654 Desktop PC
CTX
Neichi could this monitor be set to receive dvi signals and not rgb even if he has the rgb hooked into the monitor? so in menu select rgb input?
Mitch, monitors don't conflict with windows generally usually they(windows os) will install a basic generic driver to run the monitor, and you should do this when changing monitors before you hook up the new one, your description really lacks any concrete description where are the "black and blue errors" what do they look like last I have had problems with modems interfering with video so I would remove the modem and see if the problem goes away.
Apr 27, 2008 | Gateway FPD2275W LCD Monitor
Gateway FPD1976W LCD Monitor Logo
186 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
