Question about Creative Labs Computers & Internet
Sound quit workong, card will not enable. Installed new card, same thing. What's up?
  • 374 Answers
First we have to determine whether or not you have the required drivers installed in order for the operating system to communicate with your sound playback device. Following is the keyin sequence for Windows XP - The key-ins will differ somewhat for other Windows operating systems:
Click on START
Right Click on MY COMPUTER
Tnen click on PROPERTIES followed by HARDWARE and then DEVICE MANAGER.
Double click on SOUND, VIDEO and GAME CONTROLLERS
Your sound playback device (Soundblaster) should be listed. And there should NOT be a yellow exclamation mark in the left margin (If there is, this is an indication that the device is not working properly - see CORRECTIVE ACTIONS below.
Double click on your sound playback device.
In the device status box you should see the statement "This device is working properly"
If you get any other messages indicating that drivers are required or need to be updated, see CORRECTIVE ACTIONS below.
If everything look OK, click on the "X" in the upper right corner to close device manager.
If everything was OK in device manager we will now see if the operating systen is sending sound to your playback device.
Click on START
Click on CONTROL PANEL
Select the Classic View (If not already displayed)
Click on SOUNDS AND AUDIO DEVICES
Double Click on AUDIO DEVICES
Click on the AUDIO tab.
In the Sound Playback dialog box your sound device should be listed. If it is not, click on the pull-down menu and select it if you can..
If it is NOT listed, see CORRECTIVE ACTIONS below.
If it is listed, perform the following tests:
Click on the SOUNDS tab
Set the Sound Scheme to WINDOWS DEFAULT
Click on APPLY and OK
In the Program Events dialog box, click on any event that has a speaker Icon to the left of it
Underneath the Program Events dialog box you will see a small box with a triangle inside
If the triangle is black that means that the operating system has recognized your sound playback device (sound card).
Click on the triangle.
You should hear the sound through your speakers (the triangle will change to a rectangle while the sound is playing)
After the sound plays the black triangle will re-appear.
If the triangle is black and changes to a rectangle when you click on it and you DO NOT hear sound through your speakers either your speakers are plugged into the wrong jack or you have a problem with your speakers. Test or replace the speakers.
If the triange is gray that means that the operating system does not recognize your sound playback device (sound card). See CORRECTIVE ACTIONS below.
CORRECTIVE ACTIONS
If your playback device is installed and enabled and either you have an error indication, drivers are not installed, or device manager reccommends a driver update, you will have to download drivers from manufacturer's web site. For soundblaster your link is http://www.creativelabs.com/support
Also, if the drivers are installed and you no have no error messages, but you do not hear sound when you click the black triangle, you may have a hardware conflict between your sound card and another device. At this point, you will require some help from a qualified PC technician.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
Posted on Dec 31, 2010
I put in a new sound card and now my computer wont start up past the lenovo screen and i need to fix it so i can work
The first thing to do is remove the sound card to see if the computer works without it. If you are still having problems starting, then you'll have to look for a different reason the computer won't start. Quite possibly you disconnected something when you installed the card. Check for that.
Nov 05, 2011 | Lenovo 3000 J Series 2.10G Xpp PC Desktop
Audio sound not ***
Right click my computer then properties then hardware then device manager then see if the sound drivers are installed properly if not installed properly you will see a question mark if disable you will see red X id disable enable the if the driver is marked with yellow question mark then reinstall the driver if the driver is installed and no marks indicated go to the speaker icon in the task bear and open the volume control and see wether mute is enabled if enabled disble them
Oct 18, 2011 | IBM AUDIO CARD ASSEMBLY 07H0017 Sound Card
I've got hp dx2480 business pc sound driver is perfectly installed but there's no sound
Sep 24, 2011 | Compaq Audio card Sound Card
I need a sound card becouse there is no no sound
If you have installed your drivers, and made sure the correct default playback device is enabled (control panel / sound )
you would have to get a USB audio device.
They are quite cheap, try this out http://www.cclonline.com/product-info.asp?product_id=49179&tid=frooct
Sep 16, 2010 | Acer Aspire 5315 Notebook
I have no sound on my computer and it just sudddenly quit.
If your sound card is builtin please check its enabled in your bios. And if yes check the device manager for any error in your sound card driver. if then you have to download new driver. reply for other suggestions
Apr 05, 2009 | Dell OptiPlex GX260 PC Desktop
I am not hearing any sound at all though i have increased every volume buttom
You check your system information if sound driver was installed, type dxdiag in your run command. Wait till a tool bar about your system info will appear then check your sound driver if installed. If it was not installed. you have to install a sound driver. Look at your sound card installed and download from internet any necessary sound card driver compatible to your sound card hardware and mother board. Just try this,. I have solved many computers by following this procedure.
Oct 19, 2008 | Compaq Creative Sound Blaster PCI 128...
No Sound
did you install anything before this problem started? if yes try to uninstall it. if not, check device manager if your sound card drivers is still installed and if it is enabled. to go to device manager right-click Computer then click Manage. look for device manager then sound.
if it's enabled and there are no problems to the sound card go to control panel then Hardware and Sound. click on sound then check if the default digital output device is selected and enabled.
if it still won't work last option is do a system restore. set the restore date before the time the problem happens.
May 27, 2008 | Gateway GM5620 PC Desktop
Problem with Windows XP recognizing Creative Sound Card
It sounds like a software problem. Though you did the right thing by entering the bios & disabling the onboard sound. That should have been enough. Did you uninstall the old intergrated sound drivers before adding the 24bit card? Just about all the drivers & upgrades for your 4600 through Dell is Creative software & thats why your having a tough time. I would put everything back to how it was. Re-enable the intergrated sound & reboot! Run system restore & check that every thing is running right!! Look at this dell web site for the sound drivers you have at this link:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
If you must, install a upgrade for your intergrated sound. Just so you can uninstall it after a reboot. Re disable the sound in the bios. Do not install your new card yet. While back in windows device manager you should be missing a PCI device. Shut down install the new sound card. Hopefully windows will want the drivers & all runs fine. If still no it could be a bad card (i know what your thinking but it's possible). The only thing left is the regestry is using the wrong PCI device.
Dec 26, 2007 | Creative Labs Sound Blaster Live! 5.1...
No sound when recording
Well, looks like you went through all the steps, but I'm wondering about one thing... If you goto: Start -> Control Panel -> Sound and Audio devices There are 5 tabs at the top, 2 of which you'll be paying attention to "audio" and "voice". On these tabs are the record settings, which you will want to have the drivers for the m-audio in the record processes. For instance, I have 4 options in the record process: Logitech (mic built into camera) SoundMax (sound card) Bluetooth Audio (bluetooth server) BlueTooth High quality audio (bluetooth server) Out of the 4, I have logitech enabled in the record area (which isn't the right thing as the camera doesn't work anymore...jeez, found something that I need to fix on my PC now...)
Mar 11, 2007 | KWorld DV/AV Expert TV Stereo...
Computers & Internet Logo
47 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Shawn DuRee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
