Question about Cycling
Shimano deore adjustments - Cycling
    Brigadier General:
  • 8,546 Answers
My Shimano Deore DX mountain bike up / down shifter is malfunctioning. Any help will be appreciated.
Maybe start here and if you can't figure it out, take it to a Bike Shop. Ther's only so much useful mechanical advice one can remotely lend with no details.
Jul 03, 2010 | Shimano Deore Xt Thumb Shifters 7...
Shimano Deore LX Chainring alignment
The large ring should be a no-brainer. There should be a nub on the outside surface that aligns with the crankarm to keep the chain from dropping between the crank and the arm.
The rings also have their tooth counts etched into them. They all line up.
Mar 29, 2010 | Shimano Deore LX Mountain Bike Front...
New shifters for deore xt x7 delrailer
Shimano make an "EZ fire" which is an integrated shifter/brake lever combination and cheaper than buying seperate shifters and levers.
e.g.
http://www.tredz.co.uk/.Shimano-Acera-8-Speed-EZ-Fire-ShiftersBrake-Lever_24339.htm
Feb 07, 2010 | Shimano Deore Xt Thumb Shifters 7...
Shimano Deore LX right hand rear shifter
HERE is Shimano's exploded-view diagram of the shifters, but it really only gives you a ballpark idea of the assembly. You will have to piece the rest together from memory, i suppose. Sorry, i could not find more information for you.
Hope this helps a little,
matt
Oct 07, 2009 | Mountain Shimano Deore Bicycle...
How do I replace rear shifter cable in shifter lever? Older Shimano Deore XT
ok this is a little hard to explain in words but the important thing is to make sure the chain is on the biggest cog, pull the cable through the deralier tight and fasten. don't pull it too tight however. you may need to fine tune using the h/l screws but if it was in tune before then it shouldn't need too much adjustment.
Oct 03, 2009 | Shimano Deore Xt Thumb Shifters 7...
Deore front derailer cable stay hex nut access
Try unhooking the chain from the ring and pulling the derailleur out far eough to get at the bolt. Make sure your limit screws are adjusted for the travel yuou want and take up the slack. You can use the cable adjuster on the shifter to tighten it or loosen it as necessary. Make sure the adjuster has enough to go in the direction you need. I don't know which model Diore you are talking about so this is the best advice I can give you.
Jul 04, 2009 | Shimano Deore Xt Thumb Shifters 7...
Cycling Logo
88 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
