Question about Whirlpool Inglis IP8200 Dryer
How to replace thermal fuse - Whirlpool Inglis IP8200 Dryer
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Below is a video to walk you thru the repair.
Posted on Dec 31, 2010
  • Whirlpool Master
  • 8,220 Answers
Unplug dryer. Remove back dust cover. One screw to remove:
how to replace thermal fuse - themobilian_621.jpgthemobilian_620.jpgthemobilian_622.how to replace thermal fuse - themobilian_623.jpg><img src=themobilian_624.jpg
Manual and more HERE
Do all kenmore ovens have a thermal fuse?
As far as I am aware, no ovens have a thermal fuse. However, you live and learn, some do, but mine doesn't.
Oven Thermal Fuse (part #WP3196548 and others)- How To Replace ...
Video for Kenmore oven thermal fuse? 3:02
https://www.youtube.com/watch?v=BF-cmB9xBSk
Aug 23, 2012 - Uploaded by AppliancePartsPros
Buy the new Oven Thermal Fuse http://www.appliancepartspros.com/App... Follow these simple step-by-step ...
Kenmore Electric Range Replace Thermal Cut-Out Fuse ... - YouTube
Video for Kenmore oven thermal fuse? 5:51
https://www.youtube.com/watch?v=Ihqo1QyYwaQ
Nov 14, 2013 - Uploaded by RepairClinic.com
This video provides step-by-step instructions for replacing the thermal cut-out fuse on Kenmore and ...
Oven Thermal Fuse - 9759242 for Whirlpool, Sears, Kenmore
https://www.amazon.com/Oven-Thermal-Fuse-9759242-Whirlpool/dp/B019S0D482
Rating: 5 - ‎1 reviewNew non resettable oven thermal fuse replaces Whirlpool, Sears, Kenmore, Estate, Roper, KitchenAid, 9759242. Replaces part numbers: AP3879224, 4452223, 1061375, AH974726, EA974726, PS974726. ... 4452223 NEW OVEN THERMAL CUT OUT SAFETY FUSE for Whirlpool and KitchenAid….
How to Replace an Oven Thermal Fuse | Repair Guide Help - Sears ...
https://www.searspartsdirect.com/...oven/how-to-replace-an-oven-thermal-fuse.html
This wall oven repair guide explains how to replace a thermal fuse. The fuse trips to protect the wall oven from excessive heating. If the fuse blows, the oven won't heat. You can reset some fuses with the press of a button; this guide explains how to replace one that can't be reset. Replace the thermal fuse using a ...
How to Replace Thermal Fuses in Kenmore Ovens | Hunker
https://www.hunker.com › ... › Home Appliances › Other Home Appliances
Nov 15, 2011 - Kenmore ovens are manufactured by Whirlpool and distributed by Sears, Kenmore's parent company. Whirlpool and Kenmore ovens have a thermal fuse that is located in the control panel of the appliance, which protects the oven control board from overheating. On Whirlpool and Kenmore ovens, it is not...
ovens have thermal fuse Google Search
Apr 04, 2018 | Kenmore Kitchen Ranges
Free fuse box diagrams
Parts #: W10317343
Substitution: WPW10317343 $145.98 at sears
Parts #: W10354052
Substitution: WPW10354052 $125.92 at sears
Part #: W10317347 front LED board $230 at sears
Many ovens have a bi-metal thermal fuse-also called a thermal limit switch-that protects the oven from overheating. The oven thermal fuse trips when the temperature in the oven gets too hot. After the thermal fuse trips, the oven won't heat. If the thermal fuse trips after the self-cleaning cycle, try resetting the fuse by turning off electricity to the oven, removing the exterior back panel, and pushing the reset button. If the fuse tripped during normal operation, replace it. If the problem persists, the electronic oven control board might require replacement. Reset the thermal fuse after replacing the control board.
Jul 15, 2014 | KitchenAid Ovens
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
I have a Kenmore Dryer, Model 96292110. It runs, but it does not heat the air. I have checked the circuit breakers. They are fine.
If your Maytag dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers,thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F.
Thankfully, troubleshooting the thermal fuse in a Maytag dryer is easier than it sounds.
Instructions And Things You'll Needed.
  • Screwdriver,Towel,Electrical tape,Replacement thermal fuse, if necessary.
1 Clean out thelint screen in your Maytag clothes dryer. Lint buildup can cause your dryerto overheat, triggering the thermal fuse to disrupt power to your dryer'sheating mechanisms. Take the lint screen out of your Whirlpool dryer and washit in warm water. Dry the screen thoroughly before replacing it.
2 Look behindthe dryer to check its flexible exhaust hose for kinks or obstructions.Disconnect the exhaust hose from the back of your dryer and clean out any lintthat has built up.
3 Go outside andcheck your Maytag dryer's exhaust vent for obstructions. Lint buildup, birdnests or other obstructions in the outside exhaust vent can trigger yourdryer's thermal fuse.
4 Disconnectyour dryer from its power source before attempting to access its thermal fuse.
5 Access the thermal fuse in your Maytag dryer byremoving the back panel. Remove the screws that hold the back panel in placeand it should easily come free.
6 Look betweenthe dryer's blower housing and exhaust to locate its thermal fuse. The thermalfuse in a Whirlpool dryer looks like a white plastic strip that has two wiresconnected to it.
7 Bypass the thermal fuse in your Maytag dryer whileyou perform a quick diagnostic test. Use electrical tape to tape together thetwo wires connected to the thermal fuse. Reassemble your dryer and plug it backin. Set the dryer to a timed heated drying cycle and press "Start."If the dryer produces heat with its thermal fuse bypassed, it means the thermalfuse needs to be replaced.
8 Replace a blown thermal fuse in your Maytag dryer.Disconnect the power and remove the back panel. Remove the electrical tape thatyou used to perform the diagnostic test and disconnect the wires from thethermal fuse. Remove the screws that secure the thermal fuse to the dryer anddiscard the blown fuse. Attach the replacement thermal fuse by replacing andtightening the screws. Attach the wires to the new thermal fuse.
Thanks for using fixya.
Jul 31, 2011 | Kenmore Dryers
Thermal fuse replacement
Replacing a thermal fuse
Note: Disconnect the power source to your dryer before you conduct this or any other repair. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Testing a dryer's thermal fuse is much like testing its thermostats. Follow these steps to replace your dryer's thermal fuse.
The wires leading to the thermal fuse are connected using metal slip on connectors. Remove the wires by pulling on the connectors, and not the wires themselves. It may be a good idea to use a pair of needle nosed pliers to help you
May 30, 2011 | Kenmore 63952 Electric Dryer
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    How do i replace the thermal fuse
    Hello there
    Unplug your dryer from its electrical outlet. make sure that all electricity has been disconnected from your dryer before moving on
    turn off the gas valve that supplies gas to your dryer. Remove the gas flex line at the shut-off valve using an adjustable wrench.
    Remove your dryer's back panel. take out the screws on the back of the dryer and the panel will come free. set the panel and screws aside until you are ready to replace them.
    locate the thermal fuse between the dryer's blower housing and exhaust. the thermal fuse looks like a white plastic strip with two connected wires.
    unplug the wires connected to the thermal fuse.
    remove the screw that secures the thermal fuse to your dryer. set the screw aside and discard the broken thermal fuse.
    replace the thermal fuse screw to attach the new replacement thermal fuse to your dryer.
    reconnect the wires to the thermal fuse.
    Mar 08, 2011 | Kenmore 77082 Gas Dryer
    Removing a part form a Whirlpool Electric Dryer
    The thermal fuse is located on the outside of the blower housing. To get access to the thermal fuse you will need to remove the back panel of your Whirlpool dryer.
    How do you check it:
    Before you do any repairs on your dryer, you will need to disconnect the dryer from the wall outlet.
    After removing the back panel, remove one wire from the Whirlpool dryer thermal fuse and take a reading between the two terminal on the thermal fuse.
    The reading should be 0 ohms, if the reading is infinity, the thermal fuse is bad and it must be replace. When you find a bad thermal fuse, you will need to replace the operating thermostat too.
    The operating thermostat opens at 155 degrees and the thermal fuse blows at 196.
    These means that operating thermostat did not open at 155 and that is why the thermal fuse failed.
    Jul 12, 2010 | Whirlpool Dryers
    sony part# 191002393. try mcm electronics on the web.
    May 11, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
    Electric dryer wont start
    Just replace the thermal fuse for now. You have gotten good use from this machine. But, this is also may be the beginning of the end. Thermal fuses are not expensive either. These things just go out at no uncertain times.
    Feb 01, 2009 | Whirlpool LER5636P Electric Dryer
    Whirlpool Inglis IP8200 Dryer Logo
    776 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal De
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
