I have 4 gb of ram in a hp pavilion a6200n but the computer only see 3.37 please help
  • Anonymous Dec 31, 2010
    I have window 7 it is a 64-bit
    Brigadier General:
  • 10,406 Answers
This is one limitation of the 32-bit Intel CPUs and compatible motherboards and the 32-bit version of Microsoft Windows.
Upgrade your hardware to a 64-bit CPU, and to the 64-bit version of Windows Vista (or Windows 7) if you want to use the "missing" RAM.
Posted on Dec 31, 2010
I am looking to get a new hard drive for my pc.
Add more ram is it uses a lot of graphics it might be slow adding more Computer ram will make it faster.
HP Pavilion a6228x Computer Memory.
The HP Pavilion a6228x Computer takes the PC2-5300 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2 Memory Type, and comes installed with 2.0 GB (removable) of Memory.
You can upgrade your HP Pavilion a6228x Computer to up to a maximum memory capacity of 8.0 GB Memory, the system has 4 sockets to install Memory, already with 2.0 GB (removable) standard memory installed.
For best Pavilion a6228x Computer performance use the maximum amount of allowed Memory per slot for your Computer.
If you're not sure if a module is right for your system, use theCrucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always ask for a guarantee on the compatibilitybefore making any purchase and try to buy for working pairs if possible
Dec 26, 2013 | HP Pavilion a6228x PC Desktop
I have an HP Pavilion a6200n. Takes several tried to turn the computer on.
Well I recommend you to contact HP first they have the part numbers and stuff and they can help for quiet a low fee per service, because if you go over a computer store they probably will sell you a generic one and probably it will not fit.
Jan 24, 2012 | HP Hewlett Packard Pavilion A6200N PC...
Hp pavilion a6200n/2-beeps/shuts down
2 beeps should indicating be a memory error. If you are comfortable with doing minor things you should be able to confirm and fix this. If this unit is still under warrenty this is definitly something that is covered. Make sure that you know if it is covered before you open the case. This can possibly void warrenty if the seals are broken.
To check you need to open the case and then remove all but one memory module. Then reboot and see if it works. If not you need to swap out that memory module with a differant one. If one module has gone bad it will cause the error and stop it from booting. As soon as the bad one is out then it will start. Just replace it with the same type. This is a good excuse to upgrade and put more ram in. it is cheap right now and really helps for stability in windows and speed.
To remove the ram module there is a clip along each side. You push these aside and the module will tilt at and angle then it will slide out of the connector. To putit in there is a notch s it only fits in one way. You place it in the connector and then give it a little back and forth wiggle and then push it so the locks on he edge snap ito place. The wiggle movement is a little trick to make sure it is in the right place and making good contact.
Apr 17, 2010 | HP Hewlett Packard Pavilion A6200N PC...
What is the maximum memory for this computer?
This computer (HP Pavilion a620n) has 2 x 184-pin DDR DIMM sockets and supports up to a maximum 2 GB of memory. It supports unbuffered PC2700/2100 non-ECC DDR SDRAM memory. (Also known as DDR333 and DDR2100 respectively)
Oct 27, 2009 | HP Pavilion a620n (PC028A) PC Desktop
What is the ram limit of HP Pavilion 061 DW234A-ABA A530N I have two sticks of kingston 512 in it right now but want to put in two sticks of 1 GB each. Can I? Nvidia 7800 GS OC with 500 watt power supply,...
From the HP specifications page for Pavillion A530N:
Memory type DDR Memory speed PC 3200/2700/2100/1600 Memory sockets Two DDR DIMMs (184-pin) Maximum HP/Compaq approved memory Two x 512 MB DDR-DIMMS, 1024 MB total (1 GB)
Mar 10, 2009 | ASUS Computers & Internet
Can i upgrade my Ram and hard disk in my HP pAvilion dv4000?
according to the specs you can install up to 2 gb of memory and the manual states that a 100 gb hard drive was an option. not sure if you can go higher then that.
Robert
Please take a moment to rate this solution thanks
Jan 29, 2009 | HP Pavilion dv4000 Notebook
Yellow light blinking next to blue on/off light
The "tin can" symbol below the yellow light signifies a hard disk. The yellow light is a hard disk activity indicator, it is nothing to worry about. It is just tell you that the computer is accessing the hard drive.
Jan 27, 2009 | HP Hewlett Packard Pavilion A6200N PC...
Computers & Internet Logo
110 people viewed this question
David Payne
David Payne
