Question about JVC XL-MV303 CD Player
When I insert cd, in either 1, 2 or 3 slot and then it says no disc and opens...
    Top Expert:
  • JVC Master
  • 74,136 Answers
Hello
Your JVC CD player has some mechanical trouble. It does not load CDs fully into the tray. Either tray loading motor or its belt iis faulty. Replace the belt first and see it helps you. If not replace the loading motro. For both, you have to open and disassemble your CD player. If you are able to do it, and have confidence, proceed. OK
Happy New Year.
Posted on Dec 31, 2010
Just bought this used car and the CD load is very sensitive and will only let me load 1 out of every 6 I try. Is this normal?
Try a dust cleaner but do not shake the can. Just insert the shaft into the removed cd slot and shoot some air in there, then try a cd cleaner disc to clean the disc lens. If the disc player is just shooting them out also try removing and unplugging the radio assembly and shaking the radio, slot facing down maybe something is lodged in the cd input area...kids love that slot...
Mar 08, 2016 | 2007 Acura MDX
No power to the disc changer, how do I manually eject the magazine
There is a manual eject slot on the side of the CD changer. You will need a small flat head screwdriver or a pry tool to insert into the slot.
Oct 11, 2012 | Kenwood KDC-C715 10 Disc CD Changer
Discs not playing
Don't know this issue with this particular player, but have had other Technics (Matsushita, Panasonic...) CD players doing something similar to this. In most cases, those were carousel players instead of single disc players like yours. These units had optical sensors that determined the presence of CDs in each tray slot by determining whether light was blocked from its LED to its sensor when a disc was present... no light at sensor meant that there was a CD in the slot. The sensors interpreted a shadow as an indication of a disc in the tray. I've had these sensors fail and not be able to determine that a disc was blocking its light signal... the players didn't "see" discs so they wouldn't play them. Solutions varied, but cheapest, easiest solution was often to open the player and blind the sensor completely with a piece of black electrical tape. Most of these sensors I have encountered got too sensitive, so that any light at all inside the player was seen as an empty slot. Blinding the sensors "fixed" most of these players, but disabled the ability to really tell that any given tray slot was empty.
Or, since it is an old player, there is also the possibility that it has simply run its course and the laser assembly has failed.
Good Luck.
Jul 24, 2010 | Technics SL-PG480A CD Player
We can't get the factory 6 disc cd player to load more than 1 disc. What is the sequence for loading additional discs?
The following is the owner's manual for your 2004 Dodge Neon:
http://www.dodge.com/en/owners/manuals/index.html?year=2004&nameplate=Neon
P.99 describes how to load discs:
1. Select and press any numbered button without an illuminated light above it.
2. Insert the CD while the light above the chosen button is flashing and the two lights on either side of the slot are illuminated.
3. Upon insertion, the CD will begin to play, and both the button light and the lights in the corner of the loading slot will illuminate.
4. Repeat the process for loading any additional CDs. The CD playe rwill stop while additional CDs are loaded.
Playing Discs
The radio will show the CD number, the CD track number, and the Track Time Elapsed while the radio is in the CD mode. IF more than one CD is loaded in the changer, the changer will automatically play the next disc after playing the last track of the current disc.
Wow, that's a lot of typing.
I didn't know the 2004 Dodge Neon had such a nice changer.
Good luck.
Jul 04, 2010 | 2004 Dodge Neon
Got dynalink V1456VQE modem need to install please help how to
internal modem installing:
1.Switch off the power,and remove the power card from the cpu.
2.Get the cpu separately.
3.unsqrew the sqrews and open the system box
4.you can find the white color slot in the mother board.
5.fix the modem with that slot (Modem Board has the single cutting).it must be fitted with the PCI slot.Slight press down.
6.then ON the system,
Start->all programs->control panel->system
->Hardware->Device Manager
now you can see more items on screen,also you can found the modem which you have installed.
Your new modem is ready to use...
7.If your modem came with cd,then insert the disc in cd/dvd drive .Gently Installed the cd...
8.Then Restart the computer.
External Modem Installing:(We do not need to open the system case)
Type 1:(Using Ethernet Cable)
1.Insert the ethernet cable(RJ 45) in the modem,and connect the other end of the cable to cpu.
2.insert a power adaptor in the modem jack.
3.insert the phone line in modem phone jack.(RJ 10)
4.On the system and Modem.
5.Your new modem is ready to use...
Type 2:(Using USB cable)
1.Insert the USB cable in CPU,and connect other end of the cable to modem .
5.You must install the driver software cd came with your modem
6.Restart the computer
7..Your new modem is ready to use...
Feb 13, 2010 | Dynalink (V1456VQH) Modem
The CD/DVD slot won't open
Locate a small hole on the front bezel of the drive - it is usually close to the pushbutton, but there are exceptions.
You will need a piece of straight, strong wire of a diameter that would easily fit in that hole. I usually find a bigger paperclip and straighten it out using flat pliers - the length of 30-50mm (1-2 inches) of the wire must be really straight.
Turn off the power to the computer.
Now You need to insert this wire into the hole, keeping it perpendicular to the front. Soon you will feel some resistance, but with slightly more pressure you should feel something moving inside, as you insert it deeper. If you feel that the wire is scratching something instead of pushing the latch, withdraw it and try again.
Finally the tray will begin to slide out a bit, and soon the wire will not want to go any deeper - now you can grab the protruding tray edge and gently pull it out all the way, and retrieve the disc.
When you power up the computer the tray should close automatically, provided that the drive has power.
Please don't forget to come back with a testimonial if helped.
Dec 30, 2009 | Computers & Internet
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
JVC XL-MV303 CD Player Logo
254 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
