Question about JVC GR-D275 Mini DV Digital Camcorder
I have a macbook that does not have a firewire port to connect the camera to import video. Is there an adapter for usb?
  • 536 Answers
Unfortunately, even if there were a USB adapter, the USB port would not be able to keep-up with the data transfer speeds of the DV-Out over firewire from the camcorder.
Sorry for the bad news. I wish that I could have provided better news.
Thanks for using FixYa and Happy New Year.
Posted on Dec 31, 2010
Hi, I'm wondering if you can help, I have a Sony DCR-TRV340E camcorder and wish to take the video footage from one of the tapes and record/stream it onto my MacBook pro. I've tried using the USB cable...
*reason for not streaming the video: its because you're using the wrong type of cable to stream it to a macbook
*type of cable needed: you need a firewire cable to stream videos from your camcorder to your macbook.
*please make sure to check if your macbook has a firewire(IEEE) port on it and also make sure what type of firewire port it has( 4 pin or 6 pin firewire port)
*check your macbook specification for a firewire port and make sure to check how mny pinslot it has before buying a firewire cable.
* the other end of a firewire cable would surely fit the camcorder and the other end would depend on the firewire port available in your macbook.
* you would also be needing an application on your macbook that would record streamed videos.
Jan 13, 2011 | Sony Handycam DCR-TRV340E Digital...
Connect JVC GR-D240ek to vista laptop
Hi and welcome to FixYa,
A firewire to USB will not work. It has to be firewire to firewire. A JVC GR-D240ek uses 4-pin, IEEE 1394 compliant Digital Video Connector [DV OUT] to connect a 1394 cable (also known as a FireWire or i.Link cable) to a laptop equipped with an equivalent IEEE 1394 port. Please note that some laptops firewire port could either be 4 pins or 6 pins.
Soon as that connection as shown above is established, you can use Windows Import Video to capture / download the videos.
Other notes (from the same Windows Help link above) :
  • You can also open Windows Import Video by using Windows Movie Maker. After you connect ... your DV camera, and your computer, start Windows Movie Maker, turn on your DV camera, put it into playback mode, and Windows Import Video should open automatically.
  • You can also open Windows Import Video by using Windows Photo Gallery. After you connect ...your DV camera, and your computer, start Windows Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Photo Gallery, click File, click Import from Camera or Scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
  • You can also open Windows Import Video by using Windows Live Photo Gallery. (This options requires you to install Windows Live on your computer.) After you connect your...your DV camera, and your computer, start Windows Live Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Live Photo Gallery, click File, click Import from a camera or scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
Verify that the laptop's firewire port is 100% up to specs and totally compliant to IEEE 1394.
God luck and thank you for using FixYa.
Jun 18, 2009 | JVC GR-D240 Mini DV Digital Camcorder
I have a Panasonic PV-GS59 mini-dv camcorder- I shot some video and plugged the usb into my macbook pro. I tried every setting to on the camera to get the computer to read the video. Nothing works. The...
This type of camera usually downloads video over a Firewire (DV, IEEE1394) connection. Some mini-DV cameras have a USB connection but it is used only for stills.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. As you have a MAC, you may already have a port.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My Samsung mini-DV camera came with the correct lead. I did not need a driver, just some sort of video editing software that can accept input. Even Windows Movie Maker that ships with Windows will work.
Jan 13, 2011 | Panasonic PV-GS59 Mini DV Digital...
I have a new macbook pro and want to use a diamond bvumd3 to have 3 independent displays. my external monitors are both Dell 2310 with 1920 x 1080 capability. I have the bvumd3 connected into my macbook...
You would have to purchase separate BVUMD3 devices in order to get multiple extended monitors. Since each BVUMD3 has one DVI port with a USB hub, the DVI port is the only port available that allows video. Using a VGA splitter will not work with our device since each DVI port is allowed to carry only one video signal through to the monitor. You could purchase separate BVU195 devices if you do not need to use the USB hub on the BVUMD3.
Dec 27, 2010 | Diamond Multimedia Diamond BVUMD3 USB...
Video capture software for sony DCR TRV340E handycam
Dear, how can I import my videos from Sony DCR-TRV340E to MacBook (OS X, Snow Leopard) via USB? (MacBook has no FireWire port) !!! Thank you in advance for your answer. Petar
Sep 15, 2010 | Sony Handycam DCR-TRV340E Digital...
How do i copy recorded video unto my computer
Add a firewire port to your computer and get that working. Then, using a firewire cable connected to the DV port of the camcorder (not USB), you will connect to the firewire port you just installed and import the video.
USB is used only for transferring stills from the memory card or maybe using the camcorder as a web-cam.
To get the video off the miniDV tape, you need to use firewire (IEEE1394a, i.Link... all the same thing).
Mar 19, 2010 | Panasonic NV-DS65 Mini DV Digital...
Panasonic GS500 download on Macbook without Firewire
A serial model of Your cam has an USB2 port too. Try USB streaming.
Sep 14, 2009 | Panasonic PV-GS500 Camcorder
I have a new Macbook, but it doesn't have a
Buy a USB card reader, this will show your card (which you used in the camera) as a normal disk in finder
Jul 02, 2009 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Sony DCR-DVD105 Transfer to Macbook
I have a firewire from sony 105 to macbook pro--DOES NOT WORK--adapter i used from Sony mini 7" dvd player -- thought I had it fixed :( old camera out of time....
Apr 23, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Im trying to import videos from my mini dv tape on my digital Video camera JVC GR-290u i plugged in a usb cord from my camera to the computer but nothing came up. when i switch from video mode to memory...
As it's a DV (Digital Video) camera you should use the IEEE 1394 Firewire socket if it has one. Then use a DV capture program.
If you dont have a Firewire port on your PC you can buy a card like this one which will connect you Camera to your PC.
http://www.amazon.com/D-Link-3-Port-IEEE-Firewire-Adapter/dp/B00004XRD3
Mar 13, 2008 | Cameras
JVC GR-D275 Mini DV Digital Camcorder Logo
70 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
