Question about Husqvarna Chain Saw 20" Bar
How do I adjust the oiler on my 455 rancher, Husquavarna?
SOURCE: how do adjust the oiler on the older husqvarna 61 rancher
If it's a rancher model it has a non adjustable oil pump
Posted on Feb 23, 2009
steve_lima
  • 181 Answers
SOURCE: I have a 455 Rancher got it slightly used. It had
the rancher uses a plastic oiler gear to a metal gear.the plastic gear always looses in the battle.pull the clutch off and clutch drum.under the drum you will find the plastic gear.replace it and all should be well again
Posted on Feb 25, 2009
  • 143 Answers
SOURCE: Bar oiler not working
The chain oil pump must be worn. The pump is fitted behiend the clutch and chain drive.Remove this by turning clockwise.
Posted on May 17, 2009
  • 30 Answers
SOURCE: Adjusting automatic oiler. Chain is over-heating
check for blockage in feeder pipe, try draining oil tank and clean with fine grade oil or wash out using engine clean by wynns. hope this helps
Posted on Jul 08, 2009
dontbother10
  • 2220 Answers
SOURCE: 455 rancher will not oil, replaced complete oiler,
An IPL with oiler components and part numbers can be here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Our job is to provide the knowledge and illustrations available to help you determine which oiler component has likely failed. Your job is to apply that knowledge and make the final determination. If you aren’t comfortable doing that then your only option short of saw disposal is your friendly local chainsaw seller/mechanic. You might be pleasantly surprised at how reasonable they are.
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw’s oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
  2. If no, continue with 2.Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Posted on Nov 08, 2009
Youtube
first inspect the worm drive gear that makes the oiler work. this is located behind the clutch and drum. also inspect the bar oiler holes for blockage.
Jul 27, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 455 rancher, chain getting too loose to tighten after one days use age. Bar oil topped off with every fill up of gas. Bar cleaned in the groove, etc. New chain. The bar will no longer adjust to...
indicates incorrect length chain in use
the adjustment slots should be about 1/3 when fitted moving close to 1/2 when adjusted
the correct adjustment is when the chain in the center of the bar is lifted up the bottom segments of the chain are still in the bar groove
make sure that the oiler hole is not blocked from saw dust and chips
Aug 08, 2017 | Husqvarna , No.455 Rancher, 20" Gas -...
How to adjust automatic oiler on 455 husqvarna
I'm sorry, but I'm not aware of any adjustments that can be made to the oiler. Just make sure the ports are clean so that the oiler doesn't get clogged and that the oil lines are all clear and you should be good.
Nov 13, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I can not find a bar to fit the rancher 55. This
The 50/51 and 55 always had the same bar mount, the bar was part no. 508912164 for 15" 508912172 for 18" and 508912180 for the 20", the oil is not fed through the bar adjuster hole.
Aug 18, 2011 | Husqvarna 455 Rancher 555cc 35 hp 20"...
Husqvarna 455 Rancher - oil coming out of muffler and not oiler. Just emptied gas and remixed new batch so that should not be issue. It was working fine until I took off chain cover to clean and got brake...
Re-clean the engine case and loose parts. Start the engine with the bar removed--oil should ooze out of the side port where the bar fits to, but nowhere else. Clean the bar drive end oil passages--especially the two small channels that go out to the chain groove on both sides. If you seem to be pumping excess oil out, there should be an oil volume adjustment screw either in the back case or just underneath the case near the lower run of chain. Turn the screw CW to lessen the volume of oil. Hope this helps!
Jun 27, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Want to change oiler setting for chain
The proceedure is in your manual if a 455, not all Huskys have adjustable oilers. It is probably has only 3 positions, forcing it may render it inoperative.
HusqvarnaUSA.com
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; black numbers on silver tag 90s; silver numbers on black tag 80s)
Provide a model and serial number and I will look up your manual and IPL for you. HTH
Lou
Feb 26, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
455 rancher chainsaw does not pump oil to the chain
If you look under the machine by the chain you'll see a flat head screw (next to the sprocket) which controls the bar and chain oil flow . Try to turn the screw and check if there's any oil flow to the chain . If not you will need to replace the oil pump (part # 537 10 55-02 which will cost you about $35.00) Hope this help
Aug 23, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Adjusting automatic oiler. Chain is over-heating not getting enough oil. 455 Rancher
Jun 30, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a 455 Rancher got it slightly used. It had oiler issues when I got it took it to the shop they installed a new one 3 months later the oiler isn't working,any fix for this?
Feb 21, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
515 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
