Question about Trekstor DataStation maxi m.u SATA 3.5" 500GB portable hard drive black 500 GB USB 2.0
When I click on my icon(which has a ? mark on the side) this message comes up. The drive or network that the shortcut TREKSTOR (E).Ink refers to is unavailable make sure the disk is properly installed or the network resource is available and then try again. 1st of all I don't have the disk anymore we have moved and I can't find it. How do I do the Network resource?
    Brigadier General:
  • 10,406 Answers
If you don't have the Trekstor, then just delete that ICON (the one that causes the problem when you click on it).
Or, find the Trekstor, and connect it to your computer, and click the ICON.
Posted on Dec 31, 2010
Some downloaded icons all of the sudden when clicked won't work and a message comes up and says, "Not installed." But this is not true!
the icon is a short cut
delete the faulty icon
right click to properties
locate file
locate file in programs on the main drive
and re place its shortcut back on the desktop
Apr 29, 2017 | The Computers & Internet
The icons wont come up
Problems with desktop shortcuts and icons
Shortcuts on the desktop do not work or are broken
Desktop icons are broken or have not been used in 3 months
Startup items do not work or are broken
System maintenance tasks
Free up disk space by repairing disk volume errors such as bad sectors, lost clusters, cross-linked files and directory errors click start run type cmd then type chkdsk/r/f which will scan for and attempt to recovery any bad sectors and automatically fix any corrupt files on your hard drive there are many ways of running the chkdsk utility
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any bad sectors
then select check now start should schedule this task when restart
it will only schedule on restart if its the Primary hard drive with an operating system on it
do not do anything while the chkdsk utility is in progress any input may damage your computer
Free up disk space by removing error reports and troubleshooting history older than 1 month
Set the correct system time and synchronize system clock with the time server
You receive the following errors:
Windows update error 0x80072F8F
the item that this shortcut refers to has been deleted
hope this helps
Jul 05, 2012 | Computers & Internet
I cannot oppen my yahoo icon
If you are referring to the YM shortcut on your desktop, please check if the icon still points to YahooMessenger.exe. Right click on the icon and click properties. If you had installed it on the default path it should have "C:\Program Files\Yahoo!\Messenger\YahooMessenger.exe" on the Target field at the Shortcut tab.
In case you had installed it on a different path, you may search for "YahooMessenger.exe" on your PC, and change the Target field accordingly, depending on the path of search result.
Hope this helps.
P.S. I'm using Windows XP.
Feb 17, 2011 | Yahoo Messenger
How do I use the network resouce to fix my problem?
Connect the Trekstor to your network, and be sure that it has an IP-address.
On Windows, click Start
Click Run
Type \\192.168.xxx.yyy
where this is the IP-address assigned to the Trekstor.
The windows that opens will be a window onto the Trekstor's files.
Dec 31, 2010 | Trekstor DataStation maxi m.u SATA 3.5"...
Screen says 'Press the OK button to replace ink cartridge' but when I do, it shuts off. Then comes right back on to the same same message. Can't figure out the problem.
You can always do it thru the utility.
click on start, click on printer n faxes
You will see your epson icon with a check mark, double click on that icon, click on printer tab, then slect printing preferences, printing preferences utility will come up. click on tab, Click on the Maintenance Tab as shown below, then select ink replacement icon. I have a red bullit on it for you to see. Follow thru to changing cartridges. It will move the ink station to the proper stop.
If you find this helpful pls rate me.
Mar 29, 2010 | Epson CX8400 All-In-One InkJet Printer
How do I know WHICH of the ink cartridges is out?
I found this on the Epson Web Site. If you find this information helpful, pls rate me.
You can download the Reference Guide with pictures and all.
http://files.support.epson.com/htmldocs/r220__/r220__rf/index.htm
Windows
You can check the amount of ink remaining in the ink cartridges using EPSON Status Monitor 3 or the progress meter. Refer to the sections below for details.
EPSON Status Monitor 3 Access EPSON Status Monitor 3 in one of the following ways.
  • Double-click the printer-shaped shortcut icon on your Windows taskbar. To add a shortcut icon to the taskbar, see the section below.
    font26.gif See Monitoring Preferences
  • Open the printer software, click the Maintenance tab, then click the EPSON Status Monitor 3 button.
A graphic displays the remaining amount of ink.
If any of the ink cartridges installed in the printer is broken, incompatible with the printer model, or improperly installed, EPSON Status Monitor 3 will not display an accurate calculation for the amount of ink remaining in any of the ink cartridges. Be sure to replace or reinstall any ink cartridge indicated by EPSON Status Monitor 3.
Pls rate me. Thanks and Good Luck.....
Feb 09, 2010 | Epson Stylus Photo R220 InkJet Printer
Is the Samsung Zirez Pleomax 80GB Portable Hard drive compatible with Mac's. Reason being that my inspirion laptop now doesn't recognized the portable drive. Worse case if the drive is faulty is there a...
Yes, the portable harddrive is compatible with a MAC Product Features
  • Quick & easy to install Features USB 2.0 &1.1 interface connections allowingit to freely switch roles as local storage device
  • 2.5-inch External HDD
  • Fast & Small 480 Mbps for high-speed performance and smooth data transfer Ultra-slim attractive design everybody wants to have
  • Compatible with PC, Mac & Linux
  • Portable Carry & use either at your desk or on the go Simple & convenient plug & play automatic recognition
http://www.amazon.com/Samsung-Pleomax-Zirex-Portable-UHD2-5-80G/dp/tech-data/B000BB69AS/ref=de_a_smtd/179-8912138-6919333 This error is probably caused by a bad shortcut. The ".Ink" you refer to is really ".lnk" (the first character of the extension is a lower-case "L," as in link, not an "I"). Shortcuts use "lnk" as their file extension.
This kind of thing can happen if you install software from a networked drive and then later detach from that network, which is a common situation if you use a laptop computer that you disconnect from your office network and take home. To find the shortcut, follow these steps: Open Windows Explorer and press Ctrl-F (hold down the control key and press F) to bring up the Find dialog. Select "Local Hard Drives" in the Look in dropdown, and enter ".lnk" (or whatever the error message reported for the name of the bad shortcut) in the Named field. When you click the Find Now button, Windows will search your hard drives for the shortcut and display what it found.
Jan 09, 2010 | Samsung Zirex Pleomax 80GB Portable Hard...
My scan feature became disconnected during a power outage.
Make sure ToshibaScans.Ink is not set as read or write only file.
Go to the file, right click,properties, check to make sure boxes are not marked, then hit apply.
Jul 21, 2009 | Toshiba e-Studio 205 Copier
Whenever we click on the MyBook icon a message pops up that says: The drive or network connection that the shortcut "Shortcut to MyBook" refers to is unavailable... So I go to My Computer to try and access...
Type in the address in the bar above:
 http://www.         ???
delete the shortcut and make a new on after you get to where you want to be.
Jan 17, 2009 | Computers & Internet
Trekstor DataStation maxi m.u SATA 3.5" 500GB portable hard drive black 500 GB USB 2.0 Logo
76 people viewed this question
Top Trekstor Computers & Internet Experts
Marcin
vojvodabudva
ray gallant
Are you a Trekstor Computer and Internet Expert? Answer questions, earn points and help others
