Question about Magellan Maestro 4000 GPS
My Magellan Maestro 4000 wont turn on and I know its not my ac inlet thing plz help!!!!
    President:
  • 1,111 Answers
Plug it in if your sure the charger works, then press and hold the power button for up to 10 seconds. if that fails, read below
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050, 5310 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Posted on Jan 25, 2011
My maestro 4000 wont boot up
Bill
Jan 02, 2011 | Magellan Maestro 4000 GPS
Magellan maestro 4000 no sound
I did an update on a Maestro 4000 and it seems that I lost my sound.
Mar 09, 2010 | Magellan Maestro 4000 GPS
Magellan maestro 3140 wont power up/start anymore??? Is it dead?
hi ohh_bambino plug it in and let it charge for awhile using a know good charger, like the car charger. it has a indicator light to let you know its charging.
now press and hold the power button for up to ten seconds until it starts. if that fails
this is a very common problem for the models listed below.
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get help to repaired it, here
or buy the port here
if you need further help, just let me know.
bill
Nov 19, 2009 | Magellan Maestro 3140 GPS Devices
I can't tell if my magellan maestro 4000 gps is charging.
this could be happening for a few reasons but the most common is that its probably not charging.
before checking anything else, plug your 4000 in to a known good charger, then press and hold the power button for up to ten seconds till it starts.
if that fails, its likely not charging
this is very common problem with this and many model magellans.
Nov 09, 2009 | Magellan Maestro 4000 GPS
Power cord is not charging unit. There seems to be a loose fit in the socket of the Magellan Maestro 4000. Is the problem with the charger cord or the Maestro 4000 socket?
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
Oct 09, 2009 | Magellan Maestro 4000 GPS
My maestro 4000 cuts off during normal operation
its possible the unit is running off the adapter and loses contact and shuts off. this is a common problem on these type of magellan gps. typically they need a new power port so the battery will charge up and the adapter wont lose contact.
May 16, 2009 | Magellan Maestro 4040 GPS Receiver
I have charged my Magellan Maestro 4000 for 8hrs and still cannot get the power to come on
hi monicarmccar
this is a very common problem with your model gps
Bill
Apr 29, 2009 | Magellan Maestro 4000 Handheld GPS...
Brand new Magellan Maestro 4000 does not turn on or indicate powe
I had the same problem and I solved it by cutting a few strands of speaker wire and twisting them together and inserting them into the center of the generic car gharger end which plugs into the Maestro 4000, It seems that the 4000 has a very small center conducter on the GPS itself and by adding a few strands of speaker wire about 1/2" long into the plug before pluging it into the 4000 it allows it to makes contact with the small power inlet conductor which is smaller than most generic cigarette lighter 5vdc power cords. I did this to mine and it powered up right away. The other solution is to buy the actual car power cord from Magellan which has the proper size connecton and makes proper connection all the time.
Dec 24, 2008 | Magellan Maestro 4000 Handheld GPS...
Magellan maestro 3100
hi ksayenga
Bill
Jun 24, 2008 | Magellan Maestro 4000 Handheld GPS...
Magellan Maestro 4000 GPS Logo
60 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
