Question about Frigidaire ATF6000ES Front Load Washer
What would cause a water leak from the bottom
    Problem Solver:
  • 6 Answers
Sounds like a clogged water pump. I have Kenmore model 417.44102300 (by Frigidaire) and in searching for solutions to my loud thumping during spin, have come across online threads that discuss the water pump being clogged [with sludge]. You can google my model and "water pump" and you should see some forum solutions show up. It seemed like an easily fixable problem, even if you are not technically adept.
Posted on Dec 31, 2010
Whirlpool God 26cu ft French Door Refrigerator Model # GI6FDRXXY02 is leaking water on the kitchen floor. The water appears to be leaking in the front & water is leaking on both sides. Has anyone ha
There is usually a condensation pan at the bottom of a fridge. This can fill with water and over flow, causing what is happening. Also, the ice maker could be causing the problem because the water connections can leak at the back where they connect to the house water system.
Feb 03, 2015 | Whirlpool Refrigerators
Water leak from the bottom of washer
Hi friend, thank you for your post!
I understand that water is leaking from the bottom of your Frigidaire washer. There are many components that could cause a washer to leak the bellow (gasket), leak from drain hose, drain pump, or water valve. Since it could be any one of these underlying issues I would recommend having a technician come out to diagnose and repair your appliance. Hope this is helpful. -Matt
Jul 30, 2014 | Frigidaire Washing Machines
Water leaks at bottom of fridge
The same thing happened to me then I noticed ice had formed at the bottom of our fridge. It was covering a drain hole so water was leaking out the front of fridge instead of going to the drain pan or wherever the hole goes. After I chipped out the ice and cleared the hole with warm water the leak stopped. I also fixed another leak coming from bottom of fridge caused by a loose brass connection on water line going to the door.
May 25, 2014 | Hotpoint HSS25GFP Side by Side...
Water coming out of the bottom of the machine
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
Sep 27, 2012 | KitchenAid KHWS01PMT Front Load Washer
Water is leaking from bottom on the side of
sounds like you may want to check your condensation pan which may be full and causing overflow each day.
Aug 14, 2009 | Amana ABB1927DE Bottom Freezer...
Water accumulates at the bottom of the freezer unit and leaks
You must clear the drain of anything that would cause water to pool up after each defrost cycle. Check your door gaskets for wear. Air entering the ice box can cause excessive frost.
Jul 06, 2009 | Refrigerators
Water leaking from bottom of washer
Tub Seal is leaking and needs to be replaced
Jun 11, 2009 | Washing Machines
Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Jan 12, 2009 | Bunn VPR Coffee Maker
Freezer leaking water
The drain is plugged just below the coils in the back of the freezer. My fridge had the same problem and I found the hose (which can be accessed from the rear bottom) was plugged with mold. Also, i noticed the hose was connected to the water holding pan and was too close to the bottom and easy to plug. I removed it from the connector and just let it dangle in the holding pan.
Aug 30, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire ATF6000ES Front Load Washer Logo
110 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
