Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Constantly throwing error codes....F51 code is now showing
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Follow this link for in depth explanation of this error code.
Posted on Dec 31, 2010
What does an error code F51 on a whirlpool cabrio washer mean?
Cabrio F51 Fault (Stored Fault Code F51) The Cabrio's F51 fault code flashes on the washing machine's display when there is a motor rotor position sensor (RPS) failure.
Check for good contact at the control Board and at the RPS. Sometimes disconnecting and reconnecting the RPS plug connection several times will clean off corrosion that may be affecting the contacts.
Here is an earlier Fixya answer addressing the query:
Whirlpool cabrio error code f51 what does it mean
Sensor is item 20 below. Clean it.
Nov 27, 2017 | Whirlpool Washing Machines
Whirlpool cabrio washer showing F51 error code
Hi Craig,
Just saw this post come up among F51 error codes (as it will show previously posted and answered questions ) and wanted to add some info I have regarding this exact issue you may or may not already have, no harm in posting either way.
The F51 typically indicates a failed "RPS" has been detecected...but it can be the result of other issues...just for future reference and if anyone has not come accross this before.
The scenario you describe is usually associated with a item stuck under the tub or a loose stator or a faulty "RPS" device or connection at the "RPS"...but I don't know if you checked that yet or if you know how, thus the error F51.
**The repair tip below is directly from Whirlpool**
F51 is usually associated with the rotor and stator/RPS assembly and quiet often it is initiated due to a loose rotor or bad RPS...I'd start by checking the bolt.
There is a repair tip regarding this which suggest checking the wires to the RPS and then the rotor, while insuring the center bolt is really tight via applying some "lock tight".
I actually see a lot of these and most times it's a loose rotor bolt, that is where I always start my diagnosis. Here's an exert from my files directly from Whirlpool...
You may want to check the rotor, I've seen the center bolt become extremely loose, thus causing the F51 error, this is where and what to look for shown below...
...but either way that should help out with the repairs and good luck.
Regards,
Macmarkus :)
Dec 21, 2011 | Whirlpool Washing Machines
WHAT DOES CODE F51 MEAN ?
The F51 error is a RPS (rotary position sensor) board failure where the control board looses contact with the RPS during the machines operation. The RPS uses hall effect sensors to determine the speed and direction of the drive motor, allowing the control board to constantly monitor the motors operation. Because this error is a communication error and not a mechanical error with the motor itself (that would be and F52 error) we can limit our trouble shooting to the three items that make up the RPS circuit, the control board, the wiring harness, and the RPS itself.
Jan 29, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio WTW6700TW1 only fills little bit, won't turn or agitate, buzz sound/humming noise,code F51 flashes??
Jan 16, 2011 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
F1 & F51 error on my Kenmore Elite Oasis HE washer
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Feb 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool Cabrio HE washing machine displays error code F51. What is it and hw to I fix it?
I work for an appliance repair company and I had a recent service call for the same exact situation on this washer. I also know that Rotary Position Sensor is linked to the F-51 error code. I have found that this is not always the case. On this paticular call the F-51 error code was caused by a piece of clothing (sock, wash cloth, etc.) being stuck or jammed between the internal basket and the outer tub. I removed the cloth and the washer ran fine, so give that a check first before you spend the money.
Jul 27, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
249 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
