Question about Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum
The steam does not come out of the bott but on the sides water also comes out of the bottom. this is the first time we have used it.help
  • 3 Answers
I to, have this problem. If you take this mop apart you will find a destroyed O-ring. this needs to be replaced for the mop to work correctly. hope this helped!
Posted on Apr 25, 2015
  • Euro-Pro Master
  • 43,501 Answers
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Posted on Jan 03, 2011
I have a GENER8 steam mop i can not get it to steam it get hot but no steam, i have cleaned out the bottom foot but nothing can you help
There is probably a blockage preventing water from entering the steam generator.
Mostly with domestic steam equipment the water gravity feeds and it doesn't need much to stop the flow - often just a collapsed tube or a wayward blob of sealer.
Unfortunately to find the culprit the appliance will probably need partially dismantling.
Sep 23, 2016 | Vacuums
Repair Polti VT Evolution steam cleaner doesn't work
Steam nozzle/lines are probably clogged. The minerals in the water will eventually clog up the system, you need to use only Distilled water whenever possible to eliminate as many minerals from the water as you can. If the screws are spinning and not coming out, you will have to pry up slightly on the cover the put pressure on the inner parts so they will come apart. Easiest way is to push something like an old credit card betwen the seams and pry up carefully. go slow and easy so you won't break anything.
Aug 20, 2014 | Vacuums
Steam mop is not working, even after replacing the filter. Only used three times.
Rejoice with me! I called the helpline and they told me to unplug, then stick a needle into the hole on the bottom where the steam comes through. I did that, then plugged in and turned on the steam. Black liquid came out and a little steam came out. I shut off the machine, unplugged and used the needle again. This time, a geyser of steam went up into the air from the machine! It was clogged and just needed a couple of pokes. I put the steam plate back on and just cleaned my kitchen!
Jan 26, 2014 | Oreck VersaVac Bagless Vacuum / Steam Mop
Have shark steam cleaner. Brown sticky smelly water started coming out after using 5 or 6 times. Nothing has been added to water.
add some white vinegar in the water let it boil them empty and repeat about 3 times , when you finished using it always make sure you empty it..
Aug 17, 2013 | Euro-Pro Ultra Steam SharkTM II Hard...
Using my hoover steam vac tonight and too much water coming out. once it's turned on, water and shampoo continuously come out underneath until tanks are empty. looks to be leaking from left side bottom as...
make sure that you have filled everthing properly and the hoover steam is in a good condition. or check else is there any loose coonections in the bottom of the hoover, which makes the tank empty.
if the problem persists take it to service.
Feb 25, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
The water tank is getting really hot,steams come out the sides of it but no steam is coming out the bottom.
I was having the same problem. No steam out the bottom. I took the whole thing apart and cleaned it...inside and the mop heads. I now get water to the heads but steam is still coming out the sides of the unit and leaking. I took it apart again and this time had my husband look at it. He found a tube with a spring in it...the spring had punctured the side of the tube and was leaking inside the machine! I am really upset by this as the machine never really worked right from the beginning but I really did not know it was not supposed to work this way. Now the machine is over a year old. I will be calling tomorrow and complaining but am not very optimistic that they will do anything and from what I have been reading will NEVER buy another one!
Sep 03, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
It is clogged...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
heatman101
HEATS UP BUT NO STEAM?
heatman101
n
Jul 16, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Need video or large diagram instructions for what to put together
heatman101
ui
May 15, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
No more steam coming out.
The channel between the steam chamber on the pump side and the exit chamber of the steam chamber is probably plugged, I opened up the chamber at both ends and cleaned it out with CLR and a heavy wire.
Apr 19, 2009 | Bissell 1867 steamMOP Stick Vacuum
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
131 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Greg Cann
Greg Cann
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
