Question about Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
Water is leaking from the freezer down into the refrigerator at the front, but freezer is freezing.
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
It seems your drain tube from the freezer is clogged or frozen. this tube is used during defrosting.
since the unit cant drain, it drains into the refrigerator.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 31, 2010
Testimonial: "Sounds right. Thanks. "
I have a KitchenAid side by side fridge, type 25SSA, water is leaking from bottom of ice maker down front of freezer and into ice bin, how do I stop leak?
Is the refrigerator and the ice maker level? Does it appear that the ice maker is over filling or slowly overflowing due to a leak in the Click here=> W10408179 Refrigerator Water Inlet Valve? Look in the rear of the ice maker where the water fill tube enters the ice maker do you see water freezing and running down to the ice bin from there? Let me know.
http://appliance911seabreeze.com/
Nov 14, 2015 | KitchenAid Refrigerators
Water freezing on floor of freezer and leaking on to floor in front of freezer?
I have narrowed my similar problem (with a KitchenAid) down to a leak in the ice maker refill line. To test if this is your problem also, scrape the ice out, then turn off your ice maker (raise the lever as if it is full) and see if ice no longer forms down at the bottom over the next few days.
Feb 18, 2011 | Jenn-Air JSD2789GES Side by Side...
Ice is forming on the bottom of the freezer (Kenmore).
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator/freezer. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jul 24, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Maytag side by side refrigerator ice forms at the bottom of freez
Your drain is probably plugged. Remove the back panel in the freezer and keep squirting hot water down the drain hole with a turkey baster or something similar until it clears. The drain hole is located at the bottom of the coils in the freezer section. Your refrigerator goes into defrost every 8 to 10 hrs. When this happens, it melts the ice on the coils, which in turn, runs out the hole where the drain is. If something like algae is blocking or plugging the hole, it will plug up causing water to freeze over the hole. The water has nowhere to go but out the door.
Jun 02, 2009 | Maytag MSD2454G Side by Side Refrigerator
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Kitchenaid Icemaker leaking in big drips on front of freezer bins
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Nov 24, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba icemaker leaking/freezing in freezer section
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Oct 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
341 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
