Question about Sharp VL-E785U 8mm Analog Camcorder
I have a Sharp Viewcam VL-E785U and it will no longer eject the cassette tape. What do I do? It works fine otherwise.
  • 3,083 Answers
The chances are that a switchcontact or motor is not engaging, and the unit will have to be opened up to be fixed.
Oftentimes, with these older units, switch or relay contacts become oxidized over time, and fail. It sounds crazy, but one fix (without having to open the camcorder) is to give it a bump with the palm of a hand. I used to do withis with my old Olympus, and that's the only way I could get it to work, without spending a few hours taking it apart.
You can always go by a tv or camera repair shop and see what they think. Get an estimate before having it repaired, since it might be better just to upgrade.
You can contact Sharp for support here:
http://www.sharpusa.com/CustomerSupport.aspx
Good luck, and hope this helps.
Posted on Jan 02, 2011
What type of cassette do i need for a sharp VL-A10 viewcam 8
You need to use a tape that says 8mm or Video8 only. I have provided a link to the type of tape that we would use.
http://www.amazon.com/Sony-MP-Video8-tape-120min/dp/B0009WUCG6/ref=sr_1_7?s=electronics&ie=UTF8&qid=1284056100&sr=1-7
There are tapes that say Hi8 and Dig8 on them. These tapes will not work properly in your camcorder because they are the wrong format. Your camcorder would probably chew the tape at some point if you tried to use this kind.
Hope this has helped.
www.austintelstarservices.com
Sep 09, 2010 | Sharp Viewcam VL-A10U Camcorder
Sharp video camera VL-AH50
Did you try cleaning the tape head?
Feb 22, 2008 | Sharp Viewcam VL-NZ50U Mini DV Digital...
Cassett does not get inserted
Put a head cleaner tape in camera and run it for 20 seconds ever few months.
May 29, 2010 | Sharp Viewcam VL-Z1U Mini DV Digital...
My Sharp VL-Z3U show a message that says,:Unit In Safe guard Mode
I was able to reset camcorder and problem cleared up. Thanks.
Nov 20, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp VL-Z1 will not load the cassette...
Modification is available to fix this problem, contact sharp repair facility.
Oct 18, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
DEW message keeps coming up on camera
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
May 22, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp Viewcam VL-AH151U keeps saying "eject cassette" why is that? How or where can i send this to get fixed?
Assuming the record tab is in the correct position, download the manual for the VL-AH150U, very close to the 151U.
Page 10 of the manual shows the normal reasons for the "eject cassette" message. If not, I would call Sharp support at
1-800-BE-SHARP (237-4277) for referral to a local repair center.
Let me know if this helps.
Jan 18, 2009 | Sharp Viewcam VL-AH151U Camcorder
"DEW"
Good Luck,
Luwangula
May 05, 2008 | E.Digital Sharp VL-Z7E Digital Viewcam...
My Camcoder says eject the cassette
Use a Sony head cleaning tape they work perfectly and you let them run there 10 second corse. Then your sharp will run perfectly...
Dec 20, 2007 | Sharp Viewcam VL-Z7U Mini DV Digital...
VL NZ50U
hello i have a probleme like you with my VL DP3S
First you must cleaner the head with a cassette cleaner 5 sec max. if it's not ok you must consulting a specialist
Oct 22, 2007 | Sharp Viewcam VL-NZ50U Mini DV Digital...
Sharp VL-E785U 8mm Analog Camcorder Logo
Top Sharp Video Cameras Experts
NOEL
NOEL
David Payne
David Payne
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
