Question about Vizio VBR231 Blu-Ray Player
KEEPS EJECTING DVD AND SAYS NO DISC - Vizio VBR231 Blu-Ray Player
5 Suggested Answers
  • 4102 Answers
SOURCE: dvd player will not read disk
have you tried getting a lense cleaner as they sometimes get alot of dust and will stop signal from disk to the laser if this dont solve the prolbem then you are looking at replacing the laser unit itself if the cleaning dont work and you think you are capable of taking the casing off make sure you switch it off first this should send the laser to the center of the laser tray if you take the case off and it is not in the center it might just be that it has got jammed now sometimes gently pushing it back to the middle will get it working again if it is already in the middle then it could be that the laser needs replacing but if not in middle push gently dont gerk it it should be quite stiff to push any way when you push back to middle try a disk with the casing off but please make sure you dont touch anything whislt it is plugged in if nothing works then it probably is the laser but before you do anything as soon as you get the case off switch it on and put a dvd in and make sure the disk is spinning if not laser unit is nakered and need replacing let me know how you get on hope this is some help to you
Posted on Nov 26, 2007
SOURCE: It keeps ejecting the disc and saying disc error
1. Power up unit with no disk in the tray
2. After "no disc" shows on the front display, press PAUSE on the remote
3. Press in order: 1, 4, 7, 2 on the remote (short keypresses). A new screen will show up, EEPROM settings with a green background
4. Write down the EEPROM string for backup/restore purposes in case you screw up. My string was 55 53 00 45 02 55 64 FF (compare with the default string of the 312, which is 55 53 00 45 14 55 64 FF).
5. To enable VCD playback, move the cursor to the "45" (4th group of characters from the left; use the remote up/down arrows to move right/left) and enter "46" or "47" instead, then press ENTER to commit
6. To enable SVCD playback, move the cursor to the "64" field (second from the right) and enter "FE" instead. To enter "F" press "6" on the remote and keep pressed. To enter "E" press "5" on the remote and keep pressed. After you're finished entering "FE" press ENTER on the remote to commit
7. Press PAUSE on the remote to exit the EEPROM screen
8. Power off, then power on again the player
9. It now plays SVCDs and/or VCDs depending on the codes you entered.
The final EEPROM strings with both VCD and SVCD enabled are:
55 53 00 46 02 55 FE FF and
55 53 00 47 02 55 FE FF
(either works)
NB the replacement of 64 by FE was in the past wrongly labeled as Macrovision hack. That's not true. What it really does is enable SVCD playback. If you only do the #5 above, you'll only get VCD playback. If you only do the #6 above, you'll only get SVCD playback. If you do both, you'll get VCD and SVCD playback.
(SVCD playback was especially important to me because I have several hundreds of them - mostly TV shows recorded on my TiVo, then exported to the PC and converted to SVCD)
The other hack for the DVB-312 also works on the 412 (see the configuration screen):
1. press SETUP on the remote
2. Go to "TV Aspect" and move the cursor to "16:9"
3. Press in order: 1, 3, 9, 7, 1, 3, 9 on the remote, then press ENTER
The info showing on that screen for the DVB-412 is:
Model: Zenith ZV8020001
Region: 1
Chip ID: M3355A-B
Servo ver: S101_43180
Microcom ver: V1.50A MP
PROM: 55 53 00 45 02 55 64 FF
Factory reset... done...
(the PROM I listed above is before the VCD/SVCD hack)
Posted on Mar 29, 2008
  • 163 Answers
SOURCE: lg dvd vcr combo keeps
The optical pickup (laser) needs cleaning or replacing.
SUPER
Posted on Dec 15, 2008
aocomp
  • 56 Answers
SOURCE: the disc keeps ejecting
(normally) it's just the obstruction sensor. if cleaning it out with air doesn't work, you might have to open it up and clean the tracks and sensor.
Posted on Apr 16, 2012
Disc keeps getting rejected
see the cause and remedies and fix it: God bless you
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
see the block d. attached.
Jul 20, 2012 | Televison & Video
Panasonic dvd player in car
see the cause and remedies:
  7. rollers in PLAYER car, is worn or defective.
  8. use clean disk cleaner for to clean the OPU optical pick up or lens. see the block similar to dvd player conventional
Jul 20, 2012 | Panasonic Televison & Video
Dvd wont load up.. keeps sayin no disc
The most common reason for the DVD not reading discs is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your DVD plate, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your DVD including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your DVD on your TV Combo going again!
Hope this help...
Jun 05, 2010 | Televison & Video
Opens and closes repeatedly
hello,
The most common reason for the player opening and closing itself is a bad drive. The following website sells the drives and does installs:
This drive should fix any reading issues you are having with your player, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your player including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your player going again!
Hope this helps...
Jun 01, 2010 | Apex Digital AD-1125 DVD Player
Samsung dvd vr330 combo keeps trying to load a blank dvd-r
HI Not fixed yet but reading some of the answers that appear to be very common I am going to try a dvd cleaner on the machine so hope it works
thanks for tue info
crawfordj939
Jan 31, 2010 | Samsung DVD-VR330 VCR and DVD Recorder
Sony DVD Player keep ejecting CD/DVD tray - not detecting any disc.
if it keeps on opening up and wont close then the tray dectection switch is broken.....you need to get a new player.
or ifs its not reading the disc the laser mech is probably stuffed....time for a new one!
Aug 13, 2009 | Datel Max Media Manager Pro for Sony PSP
Not finalizing a dvd
Try going back to the menu and go to dvd disc record portion of it. It may have options to initialize and finalize disc.
May 25, 2009 | LG RC797T
Disc does not load keeps ejecting disc
clean the player
the track that the loader runs on is dirty, hists the dirt and reverses to prevent damage
Sep 20, 2008 | Dual XDVD8182 Car DVD Player
Vizio VBR231 Blu-Ray Player Logo
597 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
